Punctuation
Hi im a newb here and had the same kind of issue with mine except router shut down can i ask have you reset the hub at all little button on the underside of the hub i think its the only round hole copper coloured button press and hold for 7-10 seconds (toothpick )light will flash and restart the process the other issue i had was (and i dont know if this was even relevant for me) is (was) i was using firefox browser i then tried edge and got it to connect more by luck than any other factor once connected i was greeted with device corrupted hubitat prompted for a soft reset it did this itself (basically) and after a while it sorted itself done an update and currently working although the few devices i have are not straight out the box compatiable so thats work in progress for me but my ethernet cable was and is plugged in
Periods might make this a little more readable.
clearly you read it im not perfect unlike yourself
Actually I quit after 3 or 4 "sentences" and gave up. Good luck.
It is actually much harder to follow what you’re trying to say with zero punctuation.
Not trying to be rude, that’s just the reality of written words, and why punctuation exists.
It seems like the issue you had was resolved by performing a soft reset?
I split this out of another topic so as not to derail it on the OP, and they reposted the message with punctuation there: New Hubitat, Stays Blue - #7 by corinnemallinson99
I've been truly amazed with the dictation feature on my iPhone (my first).
"New Paragraph" helps break things up too.
Here is a comprehensive list.
No, I have not memorized it.
The following summary was provided by chatGPT. Is it accurate?
A user shared their experience with a similar issue, where their router shut down. They suggested resetting the Hubitat hub by pressing the copper-colored button on the underside for 7-10 seconds, which will restart the process. They also mentioned that switching browsers from Firefox to Edge helped them connect, although this might have been by chance.
After connecting, the device showed a "corrupted hub" message, prompting a soft reset. The hub eventually completed an update and started working.
However, they noted that not all devices were compatible right out of the box, so that's still a work in progress for them. The Ethernet cable was plugged in throughout.
The question is, where are you stuck in the above process?
hi i have sorted my hub if that is what you mean. I was offering up what i had experienced
Great to hear! Thank you for sharing your experience.
