When I attempted to update my firmware the interface said I was already on the latest and I made the mistake of assuming, even though it was as plain as day that I was on a 2019 firmware.
One of the two devices still says it's on the latest firmware, time for me to research how to force the update.
I can also configure the actions manually, not a problem, it's just that it's not working as expected. Relay is reporting on HTTP instead of on, as I explained above.
I'm having the same problem. It appears to be an issue of "status" in the dashboard. If I create a switch tile for each of the two Shelly 2.5 channels, I can turn each one on (while watching the Shelly web api) and the light comes on. However, the dashboard never updates so I cannot use the dashboard tile to turn either channel off (nor see the status of either).
System Driver. And after further testing, I realized that while I can turn anything on (including with a rule), I can turn neither channel off, even with a rule.
And before I followed Dongood's URL action instructions, nothing worked.
With the system driver, I get child devices that will turn on (through the dashboard, device page or rule) but won't turn off.
When I install using the "user" driver, I do get alot more information on the device, I can poll, etc. But on and off do not work, even if I disable the I/O URL actions.
very strange, maybe there is an issue because you have made 2 device's with the same IP or used 2 different drivers on 1 device or maybe it is a shelly 2.5 issue.
If I was you I should start all over again (I guess you are on the latest Hubitat 2.2.4.158 firmware)
delete the problem device or devices in Hubitat
factory reset the shelly 2.5 & reinstall it in the Shelly app
BrunoVoeten,
Thanks for the help! I did exactly what you said step by step (except I haven't upgraded back to latest yet). I can now turn devices on and off through the device list. I can still turn the devices on with the dashboard, but I still can't turn the devices off with the dashboard. But frankly, my dashboard often gives me the wrong status for various devices, so I don't trust it.
However, the Shelly can be turned on and off with an app, which is all I was after.
I'm reluctant to flash back to latest firmware now that you have it working !
