@tomw here is it!
{"type":"SHSW-25","mac":"84F3EBE4C29E","auth":false,"fw":"20200827-065456/v1.8.3@4a8bc427","num_outputs":2, "num_meters":2, "num_rollers":1
{"device":{"type":"SHSW-25","mac":"84F3EBE4C29E","hostname":"shellyswitch25-E4C29E","num_outputs":2, "num_meters":2, "num_rollers":1},"wifi_ap":{"enabled":false,"ssid":"shellyswitch25-E4C29E","key":""},"wifi_sta":{"enabled":true,"ssid":"default","ipv4_method":"static","ip":"192.168.1.50","gw":"192.168.1.10","mask":"255.255.255.0","dns":null},"wifi_sta1":{"enabled":true,"ssid":"default","ipv4_method":"static","ip":"192.168.1.50","gw":"192.168.1.10","mask":"255.255.255.0","dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellyswitch25-E4C29E","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","enabled":true},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"1GNU4v","name":null,"fw":"20200827-065456/v1.8.3@4a8bc427","factory_reset_from_switch":true,"discoverable":false,"build_info":{"build_id":"20200827-065456/v1.8.3@4a8bc427","build_timestamp":"2020-08-27T06:54:56Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Rome","lat":45.465500,"lng":9.186520,"tzautodetect":true,"tz_utc_offset":7200,"tz_dst":true,"tz_dst_auto":true,"time":"14:30","unixtime":1600612237,"led_status_disable":false,"actions":{"active":true,"names":["btn_on_url","btn_off_url","longpush_url","shortpush_url","out_on_url","out_off_url","btn_on_url","btn_off_url","longpush_url","shortpush_url","out_on_url","out_off_url","roller_open_url","roller_close_url","roller_stop_url"]},"hwinfo":{"hw_revision":"prod-2019-03", "batch_id":1},"mode":"relay","max_power":0,"longpush_time":800,"relays":[{"name":null,"ison":false,"has_timer":false,"default_state":"off","btn_type":"toggle","btn_reverse":0,"auto_on":0.00,"auto_off":0.00,"max_power":0,"btn_on_url":"","btn_off_url":"http://192.168.1.134:39501/button/0/released/","out_on_url":"http://192.168.1.134:39501/switch/0/on/","out_off_url":"http://192.168.1.134:39501/switch/0/off/","longpush_url":"http://192.168.1.134:39501/button/0/held/","shortpush_url":"http://192.168.1.134:39501/button/0/pushed/","schedule":false,"schedule_rules":[]},{"name":null,"ison":false,"has_timer":false,"default_state":"off","btn_type":"toggle","btn_reverse":0,"auto_on":0.00,"auto_off":0.00,"max_power":1000,"btn_on_url":"","btn_off_url":"http://192.168.1.134:39501/button/1/released/","out_on_url":"http://192.168.1.134:39501/switch/1/on/","out_off_url":"http://192.168.1.134:39501/switch/1/off/","longpush_url":"http://192.168.1.134:39501/button/1/held/","shortpush_url":"http://192.168.1.134:39501/button/1/pushed/","schedule":false,"schedule_rules":[]}],"rollers":[{"maxtime":20.00,"maxtime_open":20.00,"maxtime_close":20.00,"default_state":"stop","swap":false,"swap_inputs":false,"input_mode":"openclose","button_type":"toggle","btn_reverse":0,"state":"stop","power":0.00,"is_valid":true,"safety_switch":false,"roller_open_url":"","roller_close_url":"","roller_stop_url":"","schedule":false,"schedule_rules":[],"obstacle_mode":"disabled","obstacle_action":"stop","obstacle_power":200,"obstacle_delay":1,"safety_mode":"while_opening","safety_action":"stop","safety_allowed_on_trigger":"none","off_power":2,"positioning":true}]}
{"wifi_sta":{"connected":true,"ssid":"default","ip":"192.168.1.50","rssi":-58},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"14:31","unixtime":1600612276,"serial":1870,"has_update":false,"mac":"84F3EBE4C29E","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"relays":[{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"overtemperature":false,"is_valid":true,"source":"input"},{"ison":false,"has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"overpower":false,"overtemperature":false,"is_valid":true,"source":"http"}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1600612276,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1600612276,"counters":[0.000, 0.000, 0.000],"total":1600}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":1,"event":"","event_cnt":0}],"temperature":57.06,"overtemperature":false,"tmp":{"tC":57.06,"tF":134.71, "is_valid":true},"update":{"status":"idle","has_update":false,"new_version":"20200827-065456/v1.8.3@4a8bc427","old_version":"20200827-065456/v1.8.3@4a8bc427"},"ram_total":49504,"ram_free":35052,"fs_size":233681,"fs_free":140560,"voltage":233.22,"uptime":109742}
