I'd like to experiment with a pressure mat. Inside, maybe for a couch or bed. I've seen a couple of products by United Security Products, the 901, which seems heavy duty (for outside as well), but more expensive, and the SK630, which is cheaper, but looks less durable, but might do the job.
Couch, Bed. When in bed/on couch, restrict motion rule turnoff.
I know they're different sizes, but the small one, 901, gets more expensive quickly. Although the 630 is touted for outside use as well, I think the 901 would be more durable for that use. The 630 might be good enough, and cheap, but will it last?
The 901 would probably be good for that, but would it be big enough? The bigger ones are more expensive. But, if you need it, and they're the only game in town...
Every single one of my lighter-duty ones kicked the bucket after a couple years. Iβd probably opt for the more expensive one, knowing that the cheap ones are ... well, cheap!
I have 2 Withings sleep pads. They are excellent. Highly recommended. The sleep diagnostics are really good, and the integration from a community app here on the forum is also very good. They are a bit expensive but in my opinion worth every penny.
Yep! Mine is still working for me, and I'm coming up on two years since I bought it. But my couch only gets used once or twice a week, so I'm probably not a good tester for "heavy duty" use cases. It's pretty thin, and I'm not sure I'd trust outside, at least not where it gets as cold as it does where I live.
In related news, I'm glad that Gravatar I created like 10 years ago keeps following me everywhere...
Curious if anyone here knows, how do the pads listed above compare to force sensing resistors like the one here? Is one of them suited for a better use case or are those resistors really just for Arduino like setups, versus the pads which use already built contact sensor inputs?
It looks like you'd have to have some skills to make them work.
The idea of little force sensors under the feet of a couch or bed where you could get a weight for the person or persons on it, and maybe an identity, is interesting.
