Power reporting on Zigbee outlet
I need a way to monitor (temporarily) power used by one device or one power strip. I have tried now a Peanut and a Sonoff S31. I have an issue. 2 hubs, 2 different options for the generic zigbee outlet.
Hub 1: C-5, 2.3.0.124
Hub 2: C-5, 2.3.1.129
Hub 1 has power options for the Peanut:
Hub 2 has no power options for the Sonoff, but same "Type" of generic outlet
Even with this, the Peanut never actually reports power as anything other than zero.
What should I use to get power readings on an outlet if these 2 models don't work?
I use the Sengled smart plugs. The one with the round ends. I believe the square ended ones do not report power. They were $35 for 2 on Amazon. I also have a few of the old SmartThings outlets that also report power.
New ZigBee Sengled NB7 plugs.
Have you looked into Kasa KP125 outlets? They are inexpensive and generally Wi-Fi devices handle power reporting better than mesh network devices running Zigbee or Z-Wave.
FYI - Peanuts need a firmware update before they can report power. And you will need a Securifi router to update the firmware.
Sonoff's don't have power reporting.
I also recommend the Kasa KP125 outlets. They integrate with Hubitat using this integration written by @djgutheinz
I thought Zigbee would be easy, I guess not. I'll have to order the Kasa and report back in a few days.
Not all zigbee plugs have power reporting. And, for no fault of yours, although the Peanut supports power reporting, it requires a firmware update before it actually reports.
I have 10 of the Kasa KP125, and I think @bobbyD has more than that. They work very well. And @djgutheinz's integration is fully local. Just one tip - you should reserve IPs for the plugs in your router's DHCP table.
Looks like Kasa is a no go. Must have bought the wrong model. Amazon messed me up, the page said 1-pack, energy monitoring, or I had an option for a 4-pack. I guess the 4-pack is a different model than the 1-pack on the same product page.
Yup, KP125 with power reporting looks identical to HS103 that doesn't have power reporting.
Every search for KP125 comes up with KP115, even on the Kasa site. I’m trying Singled next, will order the Kasa if that doesn’t work.
https://www.kasasmart.com/us/products/smart-plugs/kasa-smart-plug-slim-energy-monitoring-kp125
Also has energy monitoring.
This is the page I was looking at. Look closely at the model number on the box.
Target also has them in store in many areas if you want one today.
As does Best Buy.
Target has the 125 at 14.99, 3 off their normal price.
Kasa has a lot of products and has been evolving their product line through the years. For the EM single plugs KP115 and KP125, both handle 1800 W, 110 VAC. I think the difference is in the wifi. The later Kasa devices appear to be going going to the low power ethernet chips that go to a standby mode w/o activity. (I see this in my device testing during development for the new versus old Color Bulb models.)
My personal recommendation: get the HS115 if available. I know it consistently works w/o delays on the ping testing that I do. (As opposed to the newer Kasa bulbs).
Below is the current Kasa Family for plugs. I have the HS105, HS115, HS300 (Energy Monitor), HS107 and KP303.
The Sengled E1C-N87 arrived last night. Checked it out today and it works as advertised. My desk looks like a smart outlet test lab right now.
@ lkk3511 Did you get the Sengled to work ok with the Better Laundry Monitor? If not, what app?
No app, I just wanted to monitor for now. It worked.
