Hi All,
Trying to get this working. I ran into subscription problem
on next page then drops to 100 calls a day
did they change from 1,000 to 100 or am I missing something ?
Hi All,
No, it's still free for the 1000 calls per day (Base Plan) and $0.15 for every 100 calls (or $0.0015 each) over the 1000.
This driver uses the One Call API, not the Professional collections API.
For those that were following the below directions make sure you only put the API key in under type. Took a bit of searching on this post but got it working. Thanks to everyone may have more questions
3
ThunderboltsRock
As best as I can remember:-
This what the tile looks like in my master dashboard:-
Hope that helps.
They could probably make it clearer than they do on that page.
But yes its still saying the same thing, you’ll pay $0.15 extra per 100 API calls only if you exceed the free limit of 1000 calls/day.
I thought you've included both APIs (2.5 and 3.0) It's still working for me absolutely perfectly.
I never entered a credit card when signing up. If it makes a difference, I signed up with OWM on 14 Apr 2022.
Versions 2.5 and 3.0 of the One Call API.
Not the professional collections API.
Is there a reason that the OW Icons are not centered such as this?
No. That is the weather icon set that is the default. You can replace any/all icons with your own. Just update the setting that tells the driver where to look for the icons.
Thank you! I've been trying to figure this out and it totally got it for me.
I've used OWM Weather for - years? and love it. I customized the crap out of it long ago - then @garyjmilne came along and built a huge tool worth all my pennies - Tile Builder. then. recently he added Grid as well and now you can effectively take over your tile!
See:
Good afternoon from Ireland. I live in Northern Ireland in the UK, and I am really struggling to get this working. I've obtained the API key from OWM and filled out relevant sections, but I cannot seem to retreive any data.
I've followed the instructions from ThunderboltsRock's post.
Any help would be appreciated.
Happy new year all (Athbhliain faoi mhaise daoibh in Irish).
Are you seeing any errors in the logs after saving the device preferences with your API key entered?
As @marktheknife said .... Enable Extended Logging, then look at the logs for clues as to what is happening.
Hi Matthew. Thank you for your help. The same 401 Unathorized error is repeated. I’ve tried generating a new API key and that had no effect.
Did you add a card and make it the free subcription plan? If you did not, it will not work and give that same error message.
See OpenWeatherMap-Alerts-Weather-Driver - #721 by syepes
and the follow on here: OpenWeatherMap-Alerts-Weather-Driver - #722 by Matthew
Thank you Tray_e and all. I'm not keen on given them a card detail for now. I'll try WSM4 for now and see if I can get that to work. Hopefully it will be accurate for the UK. The support and reponsiveness of people since I started using hubitat is amazing. Thank you all!
The current version of the OWM API won’t work without your credit card info.
If it helps, quite a few people in this thread have done the same thing, and no one’s been charged since it’s easy to stay below their daily limit for free API calls. It’s also possible to set a cap on the total number of daily calls to further protect yourself from an unexpected charge.
