Onkyo Receiver Custom Driver
This would provide the key bit of info needed to incorporate it into a driver.
Then I'm bored enough to do it RIGHT NOW.
Sniffing Traffic on an Android Emmulator running the Onkyo official app. TX-NR656 running the latest firmware.
Zone 1 Volume Up (I'll include hex payloads, if you need header data LMK, I have caps saved as well.) 1 Packet PSH, 1 ACK. Here are the PSH payloads since I don't think the ACK matters. Making assumptions and splitting into (EDIT:) 4 blocks of 12 because Hex.
495343500000 001000000008 010000002131 4d564c33390a
495343500000 001000000008 010000002131 4d564c33410a
495343500000 001000000008 010000002131 4d564c33420a
Looks like it's setting a fixed value instead of setting a particular 'Volume Up' command.
Zone 2 Volume Up:
495343500000 001000000008 010000002131 5a564c33450a
495343500000 001000000008 010000002131 5a564c33460a
495343500000 001000000008 010000002131 5a564c34300a
21314d56 has become 21315a56, so there's your 'Zone ID'
EDIT: Further digging in the ST archives suggests the 5a56 4c34300a 'ZVL' block is documented as a Zone 2 Volume command. Since it's formatted as 6 hex characters, I reblocked the dump to allign.
Here's a potentially useful doc.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjDsb_Sz77rAhUKZKwKHYPeCOYQFjACegQIAhAB&url=http%3A%2F%2Fredirect.onkyousa.com%2Fredirect_service.php%3Ftype%3Down_manuals%26file%3DISCP_RCV_103.xls&usg=AOvVaw2bFQX_fw3g0cbOUVCTtOw8
The protocol is described there.
Without knowing anything else, the data payload for your first example is:
0x4d564c3342 "MVL39" followed by a LF (0x0A). This seems to be setting Zone 1 volume to 59%
The data payload for your second example is:
0x5a564c3345 "ZVL3E" followed by LF. This seems to be setting Zone 2 volume to 62%.
Seem right? It looks like you can replace the hex values (i.e. 0x3345 in the second example) with "UP" or "DOWN". It isn't clear from the doc what the increment or decrement would be, though.
Reformatted slightly, I noticed a couple of apparent differences from the API doc:
49534350 00000010 00000008 01000000 21315a56 4c33450a
"ISCP"
HeaderSize = 0x10
DataSize = 0x08
Version = 0x01
above all seem as expected
difference:
There's an additional character (0x21 == "!") before the UnitType character (category ID) which seems as expected (0x31 == "1"). EDIT: this "!" as a Start Character is documented in the RS-232 section but not the ethernet section.
Assuming that 0x21 is always supposed to be there, I'd guess volume UP on zone 2 would look like this:
49534350 00000010 00000008 01000000 21315a56 4c55500a
and volume DOWN on zone 2 would look like this:
49534350 00000010 0000000A 01000000 21315a56 4c444F57 4e0a
@mike.maxwell Maybe Mike could take a look after the z-wave issues settle down.
Depending on how much functionality you need, you could totally do it yourself based on the example in this thread: Onkyo Receiver Custom Driver
If I was doing it, I'd make a setZone custom command to call to indicate the intended zone and then implement whichever operations you need for controlling the zones.
I'm still new here, but did you mean to link back to this very discussion? :stuck_out_tongue:
Yes, I meant this thread, quite literally. :wink:
The link was to some driver code that looked like a really good first start for someone that wanted to hack the additional functionality together.
I know for me, my biggest challehge is to be able to change volume on Zone 2 (outdoor speaks) without changing the primary input being used in the living room. So personally I wouldnt want to "change the zone", i'm looking for:
"I dont care whats happening just increase the Zone2 volume"
Yeah, I meant what you said. My wording might have been confusing.
I meant to have one set of commands like volume up, and then to have one command to indicate which zone to operate. That way you don't have to replicate all of the commands three times.
The API reference I found only called out two zones. Does yours really have three? Is that a common feature?
No, i only have 2. The "Zone 3" was a typo on my part.
I wonder if anyone here has thoughts on this thread?
[Onkyo AVR driver and Volume vs. Dimmer]
I'm not asking for or expecting HE to rework their factory driver... which looks like it's based on this work. I don't know how functional this code is or if's been abandoned?
Really all I want to do is combine volume and power in a tile so I reduce the tiles I need for each amp.
Maybe use a virtual switch and a rule to map over the volume to level and control power. Then at least you don't have to go writing your own driver to do what you want.
I thought of making a virtual dimmer and mirroring it to the onkyo volume. But I've got a c-4 running slower than snot most of the time and in similar situations just using dimmers I found the delay meant I was always chasing and overshooting. I'm in the process of building out a C-7 and want to do a better job with my rules so I don't loose my "poop".
Worth a try at least. Cheers.
For power you could have it turn on and off with your tv so you don't have to fiddle with power. I started doing this and it's worked great. I use to just leave it on all the time.
I control the power by the TV turning on or off.
I'm allergic to silence, so my amp is called on for both music and tv, but that backend logic is all sorted. I suppose my issue is really dashboard real-estate for ad-hoc adjustments to the environment. As I've got a dozen music players, nearly as many amps, all needing (wanting) power/volume. Which is a hard ask for a tiny little android ph screen unless you got a stylus. All the amp drivers I'm using respond to dimmer level/power, as do all the squeeze units, it's just the onkyo that's the outlier, hence the idea/question. But I hear ya and will likely pursue the mirror idea.
I've never really had time to explore @bangali's WATO app, tried a couple years ago and didn't get far before I realized my brain is too small.... I suspect it could do this in a flash if I could get past "huh?".... maybe I'll give it another go someday if I'm feeling lucky.
I've also been interested in giving smartly a go as a custom tile route, maybe this is my motivation.
Side question: you're just using a z-powerstrip on the TV with a power monitor like the zooz? That's working well to detect on/off quickly?
This is the one I use. It works well for powering on the receiver. I also have another rule to set the source to 1 when it comes on but that one is a little slower since it takes a few seconds for the receiver to fully power up and connect to the network.
I had to throw this in because guests always manager to flip sources somehow and cant figure out how to get it back. Especially when house sitting. Easier to just tell them to turn it off and back on again.
Any idea how i get to control the HDMI out? i have an TX-NR686 with 2x 4K HDMI outputs (one is connected to TV and the other to projector...
however the AV setting for "Both" doesnt work, it seems like the TV "wins" the output.. so i manually change to between "MAIN" and "SUB" with the Onkyo AVR app... i would really like to do it automatically from Hubitat...
it is this function (grabbed from yaml posted in this thread)
HDO:
description: HDMI Output Selector
values:
'00':
description: sets No, Analog
models: set1
'01':
description: sets Yes/Out Main, HDMI Main, HDMI
models: set1
'02':
name: [out-sub, sub, hdbaset]
description: sets Out Sub, HDMI Sub, HDBaseT
models: set1
'03':
description: sets, Both, Main+Sub
models: set1
'04':
description: sets, Both(Main)
models: set1
'05':
description: sets, Both(Sub)
models: set1
UP:
description: sets HDMI Out Selector Wrap-Around Up
models: set1
QSTN:
description: gets The HDMI Out Selector
models: set1
Well.. i found out myself... very easy
@mike.maxwell could you implement HDMI output selection in the native driver? this is the only thing i miss... i have solved it now by having 2 virtual devices, one using the native Onkyo AVR driver, and a custom where i have switched to code to below to support switching the HDMI output from MAIN to SUB or BOTH, which is on newer Recievers
metadata {
definition (name: "Onkyo Receiver (Family Room)", namespace: "cdallum", author: "Carson Dallum") {
capability "Initialize"
capability "Telnet"
capability "Switch"
command "MAIN"
command "SUB"
command "BOTH"
main "switch"
details(["switch","MAIN","SUB","BOTH"])
def on() {
log.debug "Powering on receiver"
sendEvent(name: "switch", value: "on")
def msg = getEiscpMessage("PWR01")
return new hubitat.device.HubAction(msg,hubitat.device.Protocol.TELNET)
def off() {
log.debug "Powering off receiver"
sendEvent(name: "switch", value: "off")
def msg = getEiscpMessage("PWR00")
def MAIN() {
log.debug "SET OUTPUT TO MAIN"
def msg = getEiscpMessage("HDO01")
def SUB() {
log.debug "SET OUTPUT TO SUB"
def msg = getEiscpMessage("HDO02")
def BOTH() {
log.debug "SET OUTPUT TO BOTH"
def msg = getEiscpMessage("HDO03")
/* This is where I construct the entire message character by character. Each char is represented by a 2 disgit hex value */
def getEiscpMessage(command){
def sb = StringBuilder.newInstance()
def eiscpDataSize = command.length() + 3 // this is the eISCP data size
def eiscpMsgSize = eiscpDataSize + 1 + 16 // this is the size of the entire eISCP msg
sb.append("ISCP")
// the following are all in HEX representing one char
// 4 char Big Endian Header
sb.append((char)Integer.parseInt("00", 16))
sb.append((char)Integer.parseInt("10", 16))
// 4 char Big Endian data size
// the official ISCP docs say this is supposed to be just the data size (eiscpDataSize)
// ** BUT **
// It only works if you send the size of the entire Message size (eiscpMsgSize)
// Changing eiscpMsgSize to eiscpDataSize for testing
sb.append((char)Integer.parseInt(Integer.toHexString(eiscpDataSize), 16))
//sb.append((char)Integer.parseInt(Integer.toHexString(eiscpMsgSize), 16))
// eiscp_version = "01";
sb.append((char)Integer.parseInt("01", 16))
// 3 chars reserved = "00"+"00"+"00";
// eISCP data
// Start Character
sb.append("!")
// eISCP data - unittype char '1' is receiver
sb.append("1")
// eISCP data - 3 char command and param ie PWR01
sb.append(command)
// msg end - this can be a few different cahrs depending on your receiver
// my NR5008 works when I use 'EOF'
//OD is CR
//0A is LF
[CR] Carriage Return ASCII Code 0x0D
[LF] Line Feed ASCII Code 0x0A
[EOF] End of File ASCII Code 0x1A
//works with cr or crlf
sb.append((char)Integer.parseInt("0D", 16)) //cr
return sb.toString()
// General App Events
def initialize(){
telnetConnect("192.168.1.220", 60128, null, null)
log.debug "Opening telnet connection"
def installed(){
initialize()
def updated(){
initialize()
Have a look at this driver.
It allows you to send raw ISCP values to the receiver.
...and also supports multiple zones.
EDIT: include screen shot of send raw command UI
