using the factory onkyo driver, unlike my community yamaha avr driver, doesn't respond to dimmer tile commands. Works fine when tile is volume. I prefer to use the dimmer tile as I also get info on, and can control, if its on or off. Saves me a tile.
Is there a way to either get the volume tile to do what the dimmer tile do (switch), or get the onkyo driver to respond to the dimmer tile command .. which I believe is 'level' as well as the distinct 'volume'?
Good for all, or at least bad for none?
Tagging @mike.maxwell who created these drivers and also an owner of an Onkyo. Hoping he will also get to adding Zone 2 support for all the AVRs too
Our inbuilt drivers do not use the switch level capability for volume, this is intentional given the intent of switch level is to control dimmers.
HE's choice, no problem, I had no expectation that HE would want to do so... I'm asking if there are options/tools within the ecosystem that allows such to be user developed... shy of building a complete competing community driver based on the older thread.
