Turn off the power-saving stuff on the receiver.
When you control from the child devices do you see anything in the log?
A couple of users have reported that they needed to reboot the HE hub to get the telnet connection to the receiver to work.
Also, open the log in a separate browser tab, enable debug logging on the parent (DenAVR) and the child (Onkyo AVR Main) devices, then click the Initialize button on each device. Then check the log to see if there's anything telling in the debug output.
EDIT: looking at the screenshots it appears you're using the Onkyo Multi-Zone driver. You may want to look at this thread
just noticed today that something happen... the log is filled with 5 entries a second with this error:
parse() is applicable for argument types: (java.lang.String) values: [ISCP!1NTM00:01:03/00:05:28]
Possible solutions: main(java.lang.String), use([Ljava.lang.Object;), wait(), run(), run(), grep() (parse)
it seems this occurs when using the build in spotify... it seems it shows the timestamp of the current song, and runtime for that song.
any ideas what to change to get rid of this excessive error logging?
