OmniLogic VSP speed attribute missing
I've tried several things but I can't get my vsp pump to stop saying the speed attribute is missing.
I even followed the chat where it was fixed but it still doesn't fix it for me. The pump still shows has Omnilogic VSP. Any help would be greatly appreciated along with any information that you require.
I'm assuming that my issue is an ID10t error.
What driver are you using for this device?
What chat?
Links to either/both (assuming this is custom code) would be helpful to understand more about the issue.
I tried this code second:
160x160 [RELEASE] Hayward OmniLogic pool equipment integration
Hayward OmniLogic smartapp Introduction With only a few weeks left in the pool season, I've completed the first release of my integration for Hayward OmniLogic pool controllers. The main goal of the integration is to be able to control pool equipment using Google Assistant and the Google Home app. Hayward only has a very basic and hard to use built-in integration with Google Assistant. With this smartapp you can control your pool equipment from your pool or spa, without having to touch anythi...
http://community.hubitat.com
240x120 GitHub - maartenvantjonger/omnilogic-smartapp at development
Hayward Omnilogic Smartapp for use with Samsung Smartthings and Hubitat - GitHub - maartenvantjonger/omnilogic-smartapp at development
Then this third which it supposedly had the fix in it which was farther down this page:
The issue that I'm dealing with:
Don
