@cwwilson08 - AFAIK, on a successful inclusion you should always get the prompt box to enter the name of the device, regardless of security, etc.
In a case where the inclusion gets stuck on the "Initializing" stage the prompt to name you device won't appear, but the device sometimes does eventually have a successful inclusion (using "Discover" button on Z-Wave Details page after the inclusion attempt) and you can rename the device from its device page.
not always sometimes when repairing already existing zigbee devices i havent gotten it but it appears in the list of devices.. I agree you should get it but I think there are some issues still with re-pairing
I haven't re-paired any existing Zigbee devices, so haven't run into that yet. I would still expect/want the inclusion in case I want to rename the device right there during that step, rather than having to go to the Device page and rename it. Wonder how intentional that skipped naming option is.
As @BorrisTheCat says, when Zigbee devices are repaired/rejoined, they keep their device ID which means that the hub already knows this device. It will still show upon the inclusion list like a Zwave device would so you can click in to the device from there, but since it’s already known to the hub, it will be prepopulated with its name.
It also means that any automations that were using this device before will continue working with the rejoined device, something that cannot be done with Zwave devices.
Today I removed the 3 Aeotec Range Extenders 7's and replaced them with 4 Ring Gen2 Range Extenders. Everything went smooth with the exclusion/inclusions. Also each Ring had a tag in the box with its pin code. I performed a full Z-wave repair with only a few Z-wave network busy errors but was able to repair those devices individually. I even woke up the battery devices that showed failed or unavailable was able to get OK on all devices. As I type this not a single device is using any of the 4 range extenders but it will likely take a couple days for everything to settle in.
I did have a strange issue tonight, all my exterior bulbs (10) are programmed to turn off at 11:45 which they did but the dashboard/device status didn't update for 8 of them when I looked at the log it appears the HE thought it was only turning off the 2 patio lights many times over. Very strange indeed but again all 10 bulbs did turn off as they were supposed to.
I'm on a C4 and noticed the same thing with my porch lights yesterday. Many repeat "porch light is off"
Also I noticed if my power reporting devices, at the moment my motion lighting is supposed to turn on the lights, are outputting a slew of power reports, my motion lighting gets slow, although the log will tell me it turned on the lights instantly, I know it didn't because I had to pull out my pocket flashlight to see.
Sometimes it hangs at that message. There's a command to verify if it updated successfully somewhere in the forum, I'm mobile so can't look at the moment.
I'm having a problem including my Aeon Labs Doorbell to my new C7 hub (firmware version 2.2.3.145) . The doorbell seems to join with the S2 prompt as expected but the found driver / manufacture details are all wrong as are the parameters.
The Aeon Labs door bell works fine, and included with no issues on my Hubitat C5 hub so I thinks it's either a C7 or S2 issue?
Has anyone else experienced this problem. BTW I'm in the UK so in the EU zwave frequency range if that makes any odds?
Yes, sorry I should have explained, I'd already tried changing the driver from the initial one, to the correct Aeon Labs one, but it did not make any difference. It just does not seem to be paring in the way I would expect.
On my C5 Hub Devices Page the doorbell is listed as a master zwave device with two sub devices below it (Button and Siren) this all works 100%. On the C7 device page it just shows the one level with no sub devices...
