Will pairing the Ring2s as S2 unauthenticated be enough? I'm guessing yes?
So far I've been pairing all the devices to the C7 with no security. Do you know if going from Ring2 extender S2 to no security is okay? I know there was a discussion about a repeater simply repeating frames so it likely wouldn't matter.
Maybe a followup question - instead of no authentication should I actually be pairing the devices as S2 unauthenticated? Given the Rings preference for S2 I'm wondering if other things work better under S2....
I think he was using PIN to mean the Zwave Device Specific Key code used to S2 authenticate the device (which is sometimes obtained by scanning a QR code with your phone)
Yes, during my troubleshooting of that node, I did remove the SmartStart entry. When I had removed it and was ready to reintegrate the switch, I added it back to SmartStart and it worked as intended.
If it is one of the newer "S2" ones, you should see the pop up for security and the DSK PIN. However, this doesn't always happen, especially when it's a ways from the hub--sometimes the device will simply pair in "insecure" mode without the S2 stuff.
If it's not, it will pair and you'll just get the prompt box where you enter the device name you want to use.
Quite true, eg most Aeotec devices have 2 pairing modes, secure and non-secure and they are triggered by either pressing the action button once (non-secure) or twice (secure).
