I've got a volume setup for /data as well with my file path set to /data/alexa/auth.json. When I deploy the change I get "EACCES: permission denied, open '/data/alexa/auth.json'" which is obviously a permission issue, but I'm unclear as to where since my NR container updates /data without issue.
I followed this thread in the beginning but after a few days of not reading I suddenly have hundreds of unread posts lol so I'll just jump to the end and ask.
Anyone seen a significant hub uptime reliability after offloading your webcore/RM rules to node-red?
Yep me too.. on 2 of my 3 production hubs. My third one, a C5 is only for internet/cloud services and has both Zigbee and ZWave turned off. I've never had any issues with that one other than some overheating problems which were my fault.
My performance has definitely improved since moving to node-red and deactivating RM. I don't have a lengthy uptime stat for you though since 2.2.2 and resulting hotfixes have been released lately.
Can you guys tell me whether RBE nodes are supposed to reset (ie. forget the last msg) across all flows when only re-deploying a single flow? I've just noticed this in the past couple of days. I have a few sequences where an RBE node is set up to block certain Pushover notifications until a change in payload. I'll be working on some things on one flow, and I'll click Deploy, making sure that I've selected "Modified Flows," so I wouldn't expect that to have any impact on the other flows. But every time I re-deploy, I end up receiving notifications from the other flows that should have been suppressed by the RBE nodes.
Depends on how you are deploying... There are 3 options when deploying - selected with the dropdown on the deploy button:
full deploy
modified flows
modified nodes
(and restart flows, but that isn't technically a "deploy" is it? )
If you are doing a Full Deploy, then yes, they will reset. I typically do Modified Nodes only, unless I know for sure the whole flow needs to be restarted, then I will do Modified Flows.
Full Deploy
This will re-deploy all flows in the workspace regardless of whether or not they have been modified.
This means that currently running flows are interrupted and restarted.
Result
Inject nodes will fire.
Context variables reset
Flow and Global Variables are not reset
Modified Flows
Only flows that contain modified nodes will be redeployed.
Flows that haven’t been modified will continue to run without interruption.
Result
Inject nodes in that flow will fire.
Modified Nodes
Only nodes that have been modified will be redeployed.
Nodes that haven’t been modified will continue to run without interruption.
Result
Inject nodes in that flow will only fire if they have been modified.
Context variables not reset
Restart Flows
All deployed flows will be redeployed.
Yeah, I've generally been using "Modified Flows," and that's what I was using at the time, so I wouldn't expect the other flows to be affected. That's why I'm surprised that I'm seeing what I'm seeing. I'm going to investigate further tomorrow. Now that I think about it, I don't think it's only the RBE nodes being reset, but also my startup inject nodes on some other other flows being triggered, so it's really as if the flow is being re-deployed, even though I haven't modified it. It doesn't seem to be all other flows, though. I have startup inject nodes on several flows, but only a couple of them seem to be getting triggered. It's too late for me to do more digging tonight, though.
