The flow is the one linked in the update post. It's not mine.
Summary
[{"id":"45d2924b.0eca5c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"2ebe5c49.1fb89c","type":"hubitat event","z":"45d2924b.0eca5c","name":"","server":"aeaecfe5.e3c678","x":290,"y":80,"wires":[["2c595ae4.72a4b6"]]},{"id":"4e3a65e.cead49c","type":"hubitat request","z":"45d2924b.0eca5c","name":"Get Devices","server":"aeaecfe5.e3c678","path":"/devices/all","x":270,"y":140,"wires":[["b821bd7b.0d9d3"]]},{"id":"d72f2565.13b258","type":"inject","z":"45d2924b.0eca5c","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":110,"y":140,"wires":[["4e3a65e.cead49c"]]},{"id":"b821bd7b.0d9d3","type":"split","z":"45d2924b.0eca5c","name":"Split","splt":"\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":430,"y":140,"wires":[["2c534ea5.d8a5da"]]},{"id":"2c534ea5.d8a5da","type":"switch","z":"45d2924b.0eca5c","name":"","property":"payload.attributes","propertyType":"msg","rules":[{"t":"hask","v":"battery","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":570,"y":140,"wires":[["63468155.01ed"]]},{"id":"63468155.01ed","type":"change","z":"45d2924b.0eca5c","name":"set value","rules":[{"t":"set","p":"topic","pt":"msg","to":"payload.label","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"payload.attributes.battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":140,"wires":[["5bf745e9.61a30c"]]},{"id":"5bf745e9.61a30c","type":"ui_chart","z":"45d2924b.0eca5c","name":"","group":"9ad6e619.cdab7","order":1,"width":0,"height":0,"label":"{{msg.topic}}","chartType":"horizontalBar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"100","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":true,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":910,"y":100,"wires":[]},{"id":"6ecf5c98.00a87c","type":"change","z":"45d2924b.0eca5c","name":"set value","rules":[{"t":"set","p":"topic","pt":"msg","to":"payload.displayName","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":80,"wires":[["5bf745e9.61a30c"]]},{"id":"2c595ae4.72a4b6","type":"switch","z":"45d2924b.0eca5c","name":"","property":"payload.name","propertyType":"msg","rules":[{"t":"eq","v":"battery","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":570,"y":80,"wires":[["6ecf5c98.00a87c"]]},{"id":"9ad6e619.cdab7","type":"ui_group","z":"","name":"Default","tab":"68d5add8.ad02a4","disp":true,"width":"6","collapse":false},{"id":"68d5add8.ad02a4","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
This is a partial list of what it produces..
Anyone know why the heading DS - Balcony appears under the title? I presume it's the first/last device to report. If I do a manual refresh of the dashboard, it disappears.
As for other use cases, I was thinking about doing it for switches (getting all my light switches onto the dashboard in one go), but it didnt work. Maybe I'd have to use a template node first. Not sure.
