I dont use BigTimer, but your onTime and offTime are both the same. I dont know how that works?
Wouldnt it always go out the bottom exit, since there can never be a time to turn on (since it turns on, and off and the exact same time).
If you go down 2 rows below that you'll see that they have different offsets. I have also tried setting the time 15 minutes apart with no offsets and the result is the same.
Sorry - I posted that in a hurry and didn't configure the bigtimer node correctly. The On msg should be "ON", and the Off msg should be "OFF".
My bad!
No, you had it as you say, it was I who used lowercase when I started from scratch. Besides, I'm pretty sure we can put anything in those fields. The issue is that NOTHING is coming out of the first output.
Leave the MQTT topic blank. But add the desired text to the MQTT ON msg and OFF msg (don't leave those boxes blank - that's the error I made in my hastily done post). I usually use the text ON and OFF respectively.
Because the first output is reserved for the MQTT output message. It's in those two MQTT message boxes that I usually put ON and OFF.
Edit - Like I said, my bad! I was in a rush and the sequence I posted has a misconfigured bigtimer node. Was hoping to get my C-7 migration done, but in the end, didn't do it because it was nice day and I did some yard work instead.
WHAT??? FFS!!! Nowhere does the sidebar doc say MQTT!
The first output sends out a message at your set ON or OFF times
It is in the web page although it is not at all clear (to me).
BigTimer has 3 outputs, the first of which triggers when there is a change of state and presents one of two messages (for, for example, MQTT or other control mechanism)
But you are correct and here is what I have now:
And the output is as you say:
So, mystery solved but, IMO, this is on the dev for not being clear.
Thanks, @aaiyar!
will do. I was watching a movie with the wife
I assume you're replying to me and there's no longer a need. See my previous post
Title - Elgato Key Light control
Summary - This flow links the Elgato Key Light and Elgato Key Light Air to Hubitat, enabling me to control my lights via Alexa, Apple Homekit, and a button controller under my desk. Bliss!
Setup:
Advanced users: You can also control the Elgato light from your own flows by sending commands to this flow's link node. The link is lower latency that sending commands via a Hubitat node.
This flow requires the node-red-contrib-simple-gate and no-op nodes. You can install both of these directly from within Node-RED by visiting the 'Manage Palette' menu.
[{"id":"53317764.a2d868","type":"inject","z":"b09ee1db.07242","name":"poll device's API every 5s","props":[{"p":"IP_address","v":"192.168.0.9","vt":"str"}],"repeat":"5","crontab":"","once":true,"onceDelay":"2","topic":"","payloadType":"str","x":200,"y":340,"wires":[["470bef3e.2003f"]]},{"id":"8baa3909.667a28","type":"change","z":"b09ee1db.07242","name":"set IP address","rules":[{"t":"set","p":"IP_address","pt":"msg","to":"192.168.0.9","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1580,"y":160,"wires":[["bd2b535f.5699b"]]},{"id":"d0b2d0da.8428","type":"comment","z":"b09ee1db.07242","name":"Left Light","info":"","x":80,"y":60,"wires":[]},{"id":"4b4ef25f.a9357c","type":"inject","z":"b09ee1db.07242","name":"Initialize","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":140,"wires":[["4a706ebb.a6e76"]]},{"id":"b7add235.f359","type":"hubitat command","z":"b09ee1db.07242","deviceLabel":"Left VC","name":"","server":"f0222da5.5a5e7","deviceId":"2385","command":"","commandArgs":"","x":1800,"y":340,"wires":[[]]},{"id":"4a706ebb.a6e76","type":"hubitat device","z":"b09ee1db.07242","deviceLabel":"Left VC","name":"","server":"f0222da5.5a5e7","deviceId":"2385","attribute":"","sendEvent":true,"x":280,"y":140,"wires":[["d610c795.73d208"]]},{"id":"470bef3e.2003f","type":"http request","z":"b09ee1db.07242","name":"","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://{{IP_address}}:9123/elgato/lights","tls":"","persist":false,"proxy":"","authType":"","x":430,"y":340,"wires":[["cbadbe1d.2978c"]]},{"id":"bd2b535f.5699b","type":"http request","z":"b09ee1db.07242","name":"Send to Elgato light","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://{{IP_address}}:9123/elgato/lights","tls":"","persist":false,"proxy":"","authType":"","x":1770,"y":160,"wires":[[]]},{"id":"38162faa.2ed8b","type":"json","z":"b09ee1db.07242","name":"","property":"payload","action":"","pretty":false,"x":1430,"y":160,"wires":[["8baa3909.667a28"]]},{"id":"696ff7d9.3c2378","type":"switch","z":"b09ee1db.07242","name":"Which attribute changed?","property":"payload.name","propertyType":"msg","rules":[{"t":"eq","v":"switch","vt":"str"},{"t":"eq","v":"colorTemperature","vt":"str"},{"t":"eq","v":"level","vt":"str"}],"checkall":"false","repair":false,"outputs":3,"x":630,"y":140,"wires":[["718f005f.58adb"],["90a1f46f.7a8858"],["ce4bc53e.962008"]]},{"id":"ce4bc53e.962008","type":"change","z":"b09ee1db.07242","name":"level","rules":[{"t":"set","p":"level","pt":"msg","to":"payload.value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":200,"wires":[["172444c9.311cdb"]]},{"id":"90a1f46f.7a8858","type":"change","z":"b09ee1db.07242","name":"temperature","rules":[{"t":"set","p":"colorTemperature","pt":"msg","to":"$round(1000000 / \t payload.value,\t 0)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":160,"wires":[["8fd07e5c.1ccaf"]]},{"id":"718f005f.58adb","type":"switch","z":"b09ee1db.07242","name":"on/off","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":850,"y":120,"wires":[["b4852859.2e3838"],["5ed64180.92b54"]]},{"id":"5ed64180.92b54","type":"change","z":"b09ee1db.07242","name":"off","rules":[{"t":"set","p":"on_state","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":140,"wires":[["fcd023a7.161a5"]]},{"id":"fcd023a7.161a5","type":"change","z":"b09ee1db.07242","name":"Elgato on/off","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"payload.numberOfLights","pt":"msg","to":"1","tot":"num"},{"t":"set","p":"payload.lights[0].on","pt":"msg","to":"on_state","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1170,"y":120,"wires":[["38162faa.2ed8b"]]},{"id":"8fd07e5c.1ccaf","type":"change","z":"b09ee1db.07242","name":"Elgato color temperature","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"payload.numberOfLights","pt":"msg","to":"1","tot":"num"},{"t":"set","p":"payload.lights[0].temperature","pt":"msg","to":"colorTemperature","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1210,"y":160,"wires":[["38162faa.2ed8b"]]},{"id":"172444c9.311cdb","type":"change","z":"b09ee1db.07242","name":"Elgato brightness (min 2)","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"payload.numberOfLights","pt":"msg","to":"1","tot":"num"},{"t":"set","p":"payload.lights[0].brightness","pt":"msg","to":"$max([2,msg.level])","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1210,"y":200,"wires":[["38162faa.2ed8b"]]},{"id":"b4852859.2e3838","type":"change","z":"b09ee1db.07242","name":"on","rules":[{"t":"set","p":"on_state","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":100,"wires":[["fcd023a7.161a5"]]},{"id":"6b1d1975.5977f8","type":"link in","z":"b09ee1db.07242","name":"command injector for left VC light","links":["74eb1dea.81dfd4"],"x":315,"y":80,"wires":[["d610c795.73d208"]]},{"id":"d610c795.73d208","type":"no-op","z":"b09ee1db.07242","name":"","x":430,"y":140,"wires":[["696ff7d9.3c2378","74b4b7c2.f94bc8"]]},{"id":"b163f868.b841a8","type":"change","z":"b09ee1db.07242","name":"topic = control","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1020,"y":260,"wires":[["cbadbe1d.2978c"]]},{"id":"74b4b7c2.f94bc8","type":"trigger","z":"b09ee1db.07242","name":"Pause polling for 5s to prevent race condition","op1":"close","op2":"open","op1type":"str","op2type":"str","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":740,"y":260,"wires":[["b163f868.b841a8"]]},{"id":"cbadbe1d.2978c","type":"gate","z":"b09ee1db.07242","name":"","controlTopic":"control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"x":910,"y":340,"wires":[["f2ab6827.73a878"]]},{"id":"f6f76a93.e58278","type":"json","z":"b09ee1db.07242","name":"","property":"payload","action":"","pretty":false,"x":1190,"y":340,"wires":[["bcc4e21d.8ad46"]]},{"id":"bc098f02.ea80a","type":"change","z":"b09ee1db.07242","name":"level (min 2)","rules":[{"t":"set","p":"command","pt":"msg","to":"setLevel","tot":"str"},{"t":"set","p":"arguments","pt":"msg","to":"payload.lights[0].brightness","tot":"msg"},{"t":"set","p":"arguments","pt":"msg","to":"$max([2,msg.arguments])","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1550,"y":320,"wires":[["b7add235.f359"]]},{"id":"e6ef88a.1201978","type":"change","z":"b09ee1db.07242","name":"temperature","rules":[{"t":"set","p":"command","pt":"msg","to":"setColorTemperature","tot":"str"},{"t":"set","p":"arguments","pt":"msg","to":"$round(\t$round(2000000 * \t $power(payload.lights[0].temperature,-1),\t -2),\t 0)/2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1550,"y":360,"wires":[["b7add235.f359"]]},{"id":"bcc4e21d.8ad46","type":"switch","z":"b09ee1db.07242","name":"on/off","property":"payload.lights[0].on","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1330,"y":340,"wires":[["dddbd0df.054a9","bc098f02.ea80a","e6ef88a.1201978"],["f01ab922.1b5bf8"]]},{"id":"dddbd0df.054a9","type":"change","z":"b09ee1db.07242","name":"on","rules":[{"t":"set","p":"command","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1530,"y":280,"wires":[["b7add235.f359"]]},{"id":"f01ab922.1b5bf8","type":"change","z":"b09ee1db.07242","name":"off","rules":[{"t":"set","p":"command","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1530,"y":400,"wires":[["b7add235.f359"]]},{"id":"1102887a.76ec28","type":"comment","z":"b09ee1db.07242","name":"Note on pre-staging","info":"Hubitat's virtual light doesn't support pre-staging, so we don't send color temperature or level messages to Elgato lights when off or else it'll turn on","x":1570,"y":440,"wires":[]},{"id":"f2ab6827.73a878","type":"rbe","z":"b09ee1db.07242","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":1050,"y":340,"wires":[["f6f76a93.e58278"]]},{"id":"f0222da5.5a5e7","type":"hubitat config","name":"Hubitat","usetls":false,"host":"192.168.0.2","port":"80","appId":"2781","nodeRedServer":"http://192.168.0.4:1880","webhookPath":"/hubitat/webhook","autoRefresh":true,"useWebsocket":false}]
Title - Bose SoundTouch integration with Node Red
Summary - This flow has been copied, but enhanced from here (This guy is the true genius behind this, not me)
Setting up Groups for multiroom isn't working at the min, it didn't from the original flow either, but working on that. Will update as soon as I can. I'll more than likely make the Track details etc hideable via a button too. But works great on my iPhone anyway
To add your speakers, edit the "initialize" function and enter your speaker details.
flow.set('bose_soundtouch_systems', {"systems": []}, 'memory'); msg.payload = [ { "name": "Bose Speaker 1", "ipAddress": "123.456.789.123", "macAddress": "123456abcde" }, { "name": "Bose Speaker 2", "ipAddress": "123.456.789.123", "macAddress": "123456abcde" }, ]; return msg;
Picture -
Full flow
Select the dropdown to chose the speaker to control
Your saved presets are on the left
You can set the values of the L, M and H buttons for different volume levels.
Setting up groups for multiroom (Not working currently but work in progress, the original flow didn't work either)
Flow -
Full flow here as it was too big for the post
Then make sure you submit an issue on their github (if you haven't already) so they consider changing the documentation. Complaining, but not telling the author, is less than useful.
In BigTimer - Scargill's Tech Blog the author says
The MQTT-compatible payload (ON and OFF msg) is the main output and you should put a value in there even if not using MQTT
There are comments at the bottom of that page as far back as July 3, 2020 at 9:31 am that cite the issue so it's not unknown to the author. He's actually dismissive of it, IMO.
Gotcha. Well, it's his stuff, so his decision. I guess if someone felt strongly enough about it they could fork his/her code and release a different version.
I’ve generally switched from using BigTimer to cronplus.
I have both and employ cronplus. I hadn't used BigTimer until helping @edhall1044 with his flow Node-Red Flow Samples/Sharing and I don't think I will anytime soon.
To his credit, I rewrote the ambiguous parts and he has already pushed the update.
That's cool. Good of you to do that. I always try to give them feedback/suggestions as much as I can. Sometimes they are receptive, sometimes not.
Wondering if I could get some help with a flow. I'm feeling fairly certain this would require a little coding with a function node, but since I'm not a programmer and don't code I don't really know where to start. What I would like to do is have a flow that fires when one of us is at a location (in this case the grocery store), retrieves a list from Alexa, and pushes it to our mobile device(s). I'm using @bptworld's Life360 with States app and I've got that part of the flow sorted out. I'm using the alexa-remote2 and Pushover nodes in NR. The problem is with how the list information is formatted:
`[{"completed":false,"createdDateTime":1605580187860,"customerId":null,"id":"38d09c0e-8c2c-4d11-86a4-eedf75dcf341","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605580187860,"value":"oatmeal","version":1},{"completed":false,"createdDateTime":1605580151939,"customerId":null,"id":"20dbf8d4-d924-4692-85ce-9598ecd25a30","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605580151939,"value":"flour","version":1},{"completed":false,"createdDateTime":1605580142216,"customerId":null,"id":"4ae6fe69-df6f-4487-bfad-8b2625b7a073","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605580142216,"value":"turkey","version":1},{"completed":false,"createdDateTime":1605549086848,"customerId":null,"id":"e364d22e-d30e-42c9-ae63-86bbc42cc2f1","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549086848,"value":"bread","version":1},{"completed":false,"createdDateTime":1605450913537,"customerId":null,"id":"0a2ccb00-2c41-45e5-b58e-6dddcc39d517","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605450913537,"value":"maple syrup","version":1},{"completed":false,"createdDateTime":1604623366703,"customerId":null,"id":"72a2036e-8bc2-4c63-8dab-79d98b159d55","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1604623366703,"value":"thousand dollars","version":1},{"completed":false,"createdDateTime":1604271069031,"customerId":null,"id":"8d77617d-08ee-407e-84e7-5244cfd3f1b6","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1604271069031,"value":"lunch meat","version":1},{"completed":false,"createdDateTime":1604269903573,"customerId":null,"id":"dbb191f4-55d2-456b-9105-40e000eb70ff","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1604269903573,"value":"onions","version":1},{"completed":false,"createdDateTime":1603722190668,"customerId":null,"id":"3d8daa39-c076-4bae-897f-38e1a7f40143","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1603722190668,"value":"onion powder","version":1},{"completed":false,"createdDateTime":1601331690833,"customerId":null,"id":"61e850a0-5d79-49df-8464-f7c3e022bd05","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1601331690833,"value":"basil","version":1},{"completed":false,"createdDateTime":1600638029405,"customerId":null,"id":"fc5197f7-220c-4e01-8fbc-3869ac4ac740","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1600638029405,"value":"oregano","version":1},{"completed":false,"createdDateTime":1597233072569,"customerId":null,"id":"090b3e43-f619-48f1-9a56-621d356ff749","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1597233072569,"value":"creamer","version":1},{"completed":false,"createdDateTime":1597191981133,"customerId":null,"id":"1718efec-e222-4283-aef0-a6bc94dfb227","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1597191981133,"value":"ground mustard","version":1},{"completed":false,"createdDateTime":1596666447765,"customerId":null,"id":"3ba1b403-329e-4ef5-80d0-39688344674c","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1596666447765,"value":"pizza dough","version":1},{"completed":false,"createdDateTime":1588511145488,"customerId":null,"id":"dd1b3625-7372-4000-9dd2-b43c2e555710","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1588511145488,"value":"milk","version":1},{"completed":true,"createdDateTime":1605115641266,"customerId":null,"id":"17de5376-1bab-400f-9ece-92a1adf96d53","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549096580,"value":"strawberry jelly","version":2},{"completed":true,"createdDateTime":1604623428233,"customerId":null,"id":"1857df65-f794-4af6-a26b-9428b278470e","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549104607,"value":"thousand island dressing","version":2},{"completed":true,"createdDateTime":1604623227135,"customerId":null,"id":"e9988f85-01ad-4407-a442-f2edce498639","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549113639,"value":"ranch","version":2},{"completed":true,"createdDateTime":1604271075878,"customerId":null,"id":"5dc94a35-7a6b-43cf-9c18-14eaa7703e89","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1604271091480,"value":"sandwich bread","version":2},{"completed":true,"createdDateTime":1604271057936,"customerId":null,"id":"eaf189fd-a0a7-426e-9ffd-5cee44e05fa0","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549121102,"value":"cooking spray","version":2},{"completed":true,"createdDateTime":1604271048125,"customerId":null,"id":"80567e01-46f7-4bf2-877e-deb25c565cb6","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549137013,"value":"montreal steak seasoning","version":2},{"completed":true,"createdDateTime":1604271037505,"customerId":null,"id":"d7444d9c-0733-4394-924b-c25b6da42ac3","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549144137,"value":"chili powder","version":2},{"completed":true,"createdDateTime":1604271025890,"customerId":null,"id":"aa12ad6a-ee80-46d3-b732-8dd2c40ed377","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549156946,"value":"ketchup","version":2},{"completed":true,"createdDateTime":1604271014694,"customerId":null,"id":"aaa70104-d43a-419b-a616-3ca04defa46e","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1605549181130,"value":"garlic","version":2},{"completed":true,"createdDateTime":1601424088639,"customerId":null,"id":"223debcf-b8a5-4db5-a6b9-708de16f45f9","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1601900273349,"value":"cat food","version":2},{"completed":true,"createdDateTime":1596989102446,"customerId":null,"id":"cd866bbf-7198-4bef-b58b-8ff028921346","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1597191989069,"value":"sesame oil","version":2},{"completed":true,"createdDateTime":1596989093210,"customerId":null,"id":"d51f8d62-20d5-4c80-a4be-e34a92366d99","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1597191995266,"value":"honey","version":2},{"completed":true,"createdDateTime":1588511168529,"customerId":null,"id":"6e2de787-f49d-4962-b213-8d016a18cd94","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1596989125288,"value":"eggos","version":2},{"completed":true,"createdDateTime":1588511152251,"customerId":null,"id":"640a02fe-dfbc-446d-bab3-b5335cb44d4b","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1588513212176,"value":"barbecue sauce","version":2},{"completed":true,"createdDateTime":1588511137158,"customerId":null,"id":"b37420d1-489a-4deb-a949-afbbbb47777b","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1588513207143,"value":"brown sugar","version":2},{"completed":true,"createdDateTime":1587683134025,"customerId":null,"id":"8e1fe3d2-517f-4ec2-83a8-6d2e7a46a2d7","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1588511160254,"value":"salt","version":2},{"completed":true,"createdDateTime":1587251821871,"customerId":null,"id":"3c05bce3-4da6-4f55-bc24-78f92e651065","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1587308506519,"value":"waffles","version":2},{"completed":true,"createdDateTime":1587251810704,"customerId":null,"id":"2226fa8d-3cfa-4718-9fe8-97cccd7331bf","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1596989131294,"value":"ham","version":2},{"completed":true,"createdDateTime":1587040668876,"customerId":null,"id":"a9962118-c273-4413-89e7-d914ff4b71bf","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1588511175952,"value":"maple syrup","version":2},{"completed":true,"createdDateTime":1587040657621,"customerId":null,"id":"fce616eb-8228-4378-b586-f243195d6aac","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1587308517544,"value":"eggos","version":2},{"completed":true,"createdDateTime":1586902931669,"customerId":null,"id":"e614cbd5-7052-42a2-aae0-11585d9a88a0","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1587308512145,"value":"paprika","version":2},{"completed":true,"createdDateTime":1586470812036,"customerId":null,"id":"9b30b36c-97cd-4bff-ba92-fa9eb702e57e","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1588513216910,"value":"aluminum foil","version":2},{"completed":true,"createdDateTime":1585088030428,"customerId":null,"id":"2995c458-dc36-4484-ad41-a2ca98e21b48","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1587308530445,"value":"ground cumin","version":2},{"completed":true,"createdDateTime":1584915346072,"customerId":null,"id":"5e153934-4b35-4c67-a84f-04c79626cbac","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1586470835251,"value":"shortening","version":2},{"completed":true,"createdDateTime":1584915338997,"customerId":null,"id":"cd7fcadb-7d5e-4dd5-bf75-e475f38eef94","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1586470822733,"value":"chili powder","version":2},{"completed":true,"createdDateTime":1584915331697,"customerId":null,"id":"e94e6934-2ac4-46bb-ad45-bdcb5a9bcbd7","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1586470846115,"value":"mayonnaise","version":2},{"completed":true,"createdDateTime":1584915323746,"customerId":null,"id":"73c8e028-e2d5-439c-be7a-d4e9cff4e1cc","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1586470851914,"value":"ketchup","version":2},{"completed":true,"createdDateTime":1559249445656,"customerId":null,"id":"32959576-36fb-4473-9094-f596914ead38","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1586902947017,"value":"ketchup","version":2},{"completed":true,"createdDateTime":1553276093483,"customerId":null,"id":"26af8ee4-c7ab-436d-a005-ea07d0e229dd","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1586470857548,"value":"coffee","version":2},{"completed":true,"createdDateTime":1553276062110,"customerId":null,"id":"346d9f88-291f-43cf-9b0b-8d5da6639c9b","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1596989137210,"value":"bread","version":2},{"completed":true,"createdDateTime":1553036910802,"customerId":null,"id":"ea012473-64b1-440d-bba9-8d97e4abbfa7","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553276077664,"value":"toilet paper","version":2},{"completed":true,"createdDateTime":1553025145698,"customerId":null,"id":"563eff10-269a-4932-ab1c-e4da71f5d988","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553027726960,"value":"american cheese","version":2},{"completed":true,"createdDateTime":1553025106149,"customerId":null,"id":"e5d6a3cc-37ec-4a49-94e8-61a0c8902471","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553025112345,"value":"butter","version":2},{"completed":true,"createdDateTime":1553025083182,"customerId":null,"id":"0c84eb45-d06f-46f4-a6dc-7b258a4a4d2c","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553026415238,"value":"red potatoes","version":2},{"completed":true,"createdDateTime":1553025069708,"customerId":null,"id":"5eab44de-c612-422f-a0e9-10e813612690","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553027699654,"value":"creamer","version":2},{"completed":true,"createdDateTime":1553025016160,"customerId":null,"id":"5532783e-f8fc-4b59-962e-c4547c25ee36","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553027161404,"value":"cereal","version":2},{"completed":true,"createdDateTime":1553025001824,"customerId":null,"id":"6bf3be7f-96d1-4796-ae6b-9b815d4d8a10","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553027749997,"value":"ghee","version":2},{"completed":true,"createdDateTime":1553024985896,"customerId":null,"id":"8e716295-a08e-4f10-b290-3a7825e07ee8","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553026544868,"value":"green beans","version":2},{"completed":true,"createdDateTime":1553024897841,"customerId":null,"id":"104724bf-c2ef-42ea-9101-6b1dccb79974","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553026499972,"value":"shallots fresh thyme","version":2},{"completed":true,"createdDateTime":1553024889764,"customerId":null,"id":"0965c4cf-3cf0-4930-8e6a-fb12f6c3f1af","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553026477216,"value":"garlic","version":2},{"completed":true,"createdDateTime":1553024882286,"customerId":null,"id":"6f799077-02cf-4dc9-9c67-4f75344074c7","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553027006602,"value":"filet mignon","version":2},{"completed":true,"createdDateTime":1553024875024,"customerId":null,"id":"1461df4f-2c66-4076-b44d-1576cd23e909","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553026800513,"value":"bread","version":2},{"completed":true,"createdDateTime":1553024868381,"customerId":null,"id":"c237b0e6-de15-42b2-bae8-94015ff80aa7","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553027092269,"value":"juice","version":2},{"completed":true,"createdDateTime":1553024862196,"customerId":null,"id":"5809c83c-d607-4acb-9e3e-2c08456b3595","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553027092748,"value":"milk","version":2},{"completed":true,"createdDateTime":1553024854472,"customerId":null,"id":"74df9193-35d7-4d22-9000-2ad1fcf9982b","listId":"4c575edf-d412-4751-a343-8b63888d5bc5","shoppingListItem":false,"updatedDateTime":1553027651661,"value":"milk","version":2}]`
I would need to filter out the rest of that garbage and need the actual object values formatted out in a list. Is there an 'easy' way to do this? More fun would be to map the Life360 device to the Pushover device and send the notification only to that device that triggered the flow...but I'd be happy with just getting the list formatted right.
I do something similar in a function node (parse values from an array)...
var m = msg.payload
var t =""
for(x=0;x<m.length;x++){
t = "INSERT INTO events SET row_id="+m.row_id+", source='"+m.source+"',name =' "+m.name
t=t+ "', displayName='"+m.displayName+"', value='"+m.value+"', unit='"+m.unit+"', deviceId="+m.deviceId
t = t+", hubId="+m.hubId+", locationId="+m.locationId+", installedAppId="+m.installedAppId
t= t+ ", descriptionText='"+m.descriptionText+"', created="
var year=m.created.getFullYear()
var month = m.created.getMonth()+1
var date = m.created.getDate()
var hour = m.created.getHours()
var minute = m.created.getMinutes()
var seconds = m.created.getSeconds()
var sqlDate = year+"-"+month+"-"+date+" "+hour+":"+minute+":"+seconds
t=t+"STR_TO_DATE('"+sqlDate+"','%Y-%m-%d %H:%i:%s')"
node.send({topic:t})
The key parts are:
var m = msg.payload - copy the data into a variable (easier to manage)
var t ="" - create a blank text string (this would hold your list)
for(x=0;x<m.length;x++){ - this loops through each record
t = "INSERT INTO events SET row_id="+m[x].row_id+", source='"... - this is where I build the string, In your case, this may look something like below:
t=t+m[x].value+", " - this would take the value element of each record and build a comma separated list...(in your example data, it would look like "oatmeal, "
Hopefully, something like this would work for you...
