Sequence
[{"id":"83a88897.e4cb58","type":"group","z":"d527bfaa.c3979","name":"On/Off w/Motion","style":{"fill":"#ffff7f","label":true},"nodes":["6f219364.b4821c","efeedf23.3f0d5","f1423ee3.2923b","97f24f13.25512","fe9afb30.56d878","56c03c9c.dfbbe4","9acd7411.c18c08","19bef9ac.4def06","4c18299f.8bb308","416ab02a.572b","e812a1ca.d86b","a5044674.f5a008","aa381ed6.6d9dd","c6636192.f819a","f7f46737.666868"],"x":174,"y":1749.0000009536743,"w":1170.9999237060547,"h":209.00024318695068},{"id":"6f219364.b4821c","type":"hubitat device","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Office Bench Motion","server":"c0da6dea.8576a","deviceId":"2375","attribute":"motion","sendEvent":true,"x":300,"y":1820,"wires":[["f1423ee3.2923b","a5044674.f5a008"]]},{"id":"efeedf23.3f0d5","type":"hubitat command","z":"d527bfaa.c3979","g":"83a88897.e4cb58","deviceLabel":"","name":"On","server":"e03140c5.bed32","deviceId":"1431","command":"on","commandArgs":"","x":665.9999847412109,"y":1850.0000009536743,"wires":[["f7f46737.666868"]]},{"id":"f1423ee3.2923b","type":"switch","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Active/Inactive","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"},{"t":"eq","v":"inactive","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":495.99998474121094,"y":1850.0000009536743,"wires":[["efeedf23.3f0d5"],[]]},{"id":"97f24f13.25512","type":"hubitat command","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Off","server":"e03140c5.bed32","deviceId":"1431","command":"off","commandArgs":"","x":1268.9999237060547,"y":1910.999451637268,"wires":[[]]},{"id":"fe9afb30.56d878","type":"hubitat device","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Office Desk Motion","server":"c0da6dea.8576a","deviceId":"2251","attribute":"motion","sendEvent":true,"x":310,"y":1880,"wires":[["f1423ee3.2923b","9acd7411.c18c08"]]},{"id":"56c03c9c.dfbbe4","type":"hubitat device","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Office Bench Motion","server":"c0da6dea.8576a","deviceId":"2375","attribute":"motion","sendEvent":false,"x":715.9999847412109,"y":1910.0000009536743,"wires":[["19bef9ac.4def06"]]},{"id":"9acd7411.c18c08","type":"switch","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Active/Inactive","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"},{"t":"eq","v":"inactive","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":495.99998474121094,"y":1910.0000009536743,"wires":[[],["56c03c9c.dfbbe4"]]},{"id":"19bef9ac.4def06","type":"switch","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Active/Inactive","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"},{"t":"eq","v":"inactive","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":915.9999847412109,"y":1910.0000009536743,"wires":[[],["c6636192.f819a"]]},{"id":"4c18299f.8bb308","type":"hubitat command","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Off","server":"e03140c5.bed32","deviceId":"1431","command":"off","commandArgs":"","x":1268.9999237060547,"y":1790.999451637268,"wires":[[]]},{"id":"416ab02a.572b","type":"hubitat device","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Office Desk Motion","server":"c0da6dea.8576a","deviceId":"2251","attribute":"motion","sendEvent":false,"x":705.9999847412109,"y":1790.0000009536743,"wires":[["e812a1ca.d86b"]]},{"id":"e812a1ca.d86b","type":"switch","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Active/Inactive","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"},{"t":"eq","v":"inactive","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":915.9999847412109,"y":1790.0000009536743,"wires":[[],["aa381ed6.6d9dd"]]},{"id":"a5044674.f5a008","type":"switch","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Active/Inactive","property":"payload.value","propertyType":"msg","rules":[{"t":"eq","v":"active","vt":"str"},{"t":"eq","v":"inactive","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":495.99998474121094,"y":1790.0000009536743,"wires":[[],["416ab02a.572b"]]},{"id":"aa381ed6.6d9dd","type":"stoptimer","z":"d527bfaa.c3979","g":"83a88897.e4cb58","duration":"1","units":"Minute","payloadtype":"num","payloadval":"0","name":"","x":1114.00004196167,"y":1797.000244140625,"wires":[["4c18299f.8bb308"],[]]},{"id":"c6636192.f819a","type":"stoptimer","z":"d527bfaa.c3979","g":"83a88897.e4cb58","duration":"1","units":"Minute","payloadtype":"num","payloadval":"0","name":"","x":1114.00004196167,"y":1917.000244140625,"wires":[["97f24f13.25512"],[]]},{"id":"f7f46737.666868","type":"change","z":"d527bfaa.c3979","g":"83a88897.e4cb58","name":"Send STOP","rules":[{"t":"set","p":"payload","pt":"msg","to":"STOP","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":905.9999847412109,"y":1850.0000009536743,"wires":[["aa381ed6.6d9dd","c6636192.f819a"]]},{"id":"c0da6dea.8576a","type":"hubitat config","name":"ZigBee Hub","usetls":false,"host":"10.13.9.11","port":"80","appId":"2532","nodeRedServer":"http://10.13.9.28:1880","webhookPath":"/hubitat/webhook__","autoRefresh":true,"useWebsocket":false},{"id":"e03140c5.bed32","type":"hubitat config","name":"Apps Hub","usetls":false,"host":"10.13.9.12","port":"80","appId":"899","nodeRedServer":"http://10.13.9.28:1880","webhookPath":"/hubitat/webhook___","autoRefresh":true,"useWebsocket":false}]
