Okay so this is a stab at trying to get generic pseudo HE grouping in NR... wanted to put this out there in case someone was interested. This will work across multiple hubs/maker instances but for now some "hard-coding" (manual node-editing) is required.
Basic installation..
- import subflows.
- delete erroneous HE hub configs.
- You will have to manually edit the HubGrpCommand, HubGrpEvents, HubGrpRequest nodes.
- Come up with a "hub id" for each hub. Can be any alphanum string at this point. deviceIds take the form
[hubId]/[deviceId]
and are separated by commas.
- Edit the HubGroup subflows and modify the existing nodes with your hub config and "hub id"' info.
Usage Notes:
- The basic idea is to set the deviceId property with all the HE node deviceIds you want to group separated by commas and in the form hubId/deviceId1,hubId/deviceId2... etc. Then use DevGrpEvent and DevGrpCommand subflow nodes like you would with the HE Device and Command Nodes.
- There are lots of properties of the nodes you can play around with.. specifically the "ACTION" properties - you can group "switches" (default) together or "contact sensors" etc - just have to define:
- TOPIC - The "name" of the group used in various messages etc.
- TYPE - "switch","contact" etc
- ACTIONS - "on/off","open/closed" etc
- When the event should fire using TYPE = "switch" / ACTIONS = "on/off" as an example
- ALL_Action1 refers to the "on" in "on/off" in the ACTIONS property while ALL_Action2 refers to the "off" part.
- Setting ALL_Action1 to true fires "on" events when all devices are "on"
- Setting ALL_Action2 to true fires "off" events when all devices are "off"
- If both ALL_Action1 & ALL_Action2 are set to true then when some switches are turned on or off the state is considered "pending" and no events will fire.
- Setting both ALL_Action1 and ALL_Action2 to false is "undefined" because any switch "on" or "off" would never trigger an action.
- SEND_ALL_EVENTS generates messages based on incoming events from the defined group.
- RETURN_ALL_MSGS returns the payload.value of the triggered individual device instead of the accumulated group. Good for door open alerts etc (when one or more door is open).
WARNING!!!
- This is still a work in progress so expect many bugs/headaches etc - use at your own risk.
- There are probably a 1000 much easier ways to do this.. but I am sadly prone to greatly over-engineering things.
- I haven't tested non "switch" TYPE groupings.. but as long as the responses are binary in nature (on/off, open/closed, active/inactive) they should work.
- The "groups" are simple predefined aggregations of the same type of device. No mixing of devices allowed.
- Importing the following subflows will add a bunch of HE hub configs you will have to remove.
- There are no instructions on node usage yet so kind of have to wing it for now.
Here ya go:
Groupings in NR - this is the original posting
[{"id":"4e1e6fde.a5bbf","type":"subflow","name":"HubGrpCommand","info":"","category":"","in":[{"x":40,"y":40,"wires":[{"id":"b47983a7.7b5f7"}]}],"out":[{"x":1220,"y":180,"wires":[{"id":"7c32f9e4.9fd4f8","port":0},{"id":"e076de00.f88b6","port":0},{"id":"320acf5d.6b427","port":0},{"id":"ef3ddba.1057c28","port":0},{"id":"b706dd3b.cf87a","port":0},{"id":"47e952f6.d8d37c","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"fb597717.109328","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Control Hub / CTRL","server":"bc9b2ba4.2458c8","deviceId":"","command":"","commandArgs":"","x":510,"y":60,"wires":[["7c32f9e4.9fd4f8"]]},{"id":"2a44d5ee.875b7a","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Main Hub / OMNF","server":"5664ca29.3af904","deviceId":"","command":"","commandArgs":"","x":510,"y":120,"wires":[["e076de00.f88b6"]]},{"id":"448a391d.a21278","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Main Hub - Zigbee / OZIG","server":"623daead.b1d2b","deviceId":"","command":"","commandArgs":"","x":530,"y":180,"wires":[["320acf5d.6b427"]]},{"id":"e719a313.c7d78","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Main Hub - Zwave / OZWA","server":"7631dfd4.02862","deviceId":"","command":"","commandArgs":"","x":540,"y":240,"wires":[["ef3ddba.1057c28"]]},{"id":"e65b768b.ab1f68","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Main Hub C7 / MNZW","server":"106ae29b.a1d83d","deviceId":"","command":"","commandArgs":"","x":520,"y":360,"wires":[["47e952f6.d8d37c"]]},{"id":"ddcc8d55.8b128","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Upstairs Hub / OUPS","server":"925818a7.4a4018","deviceId":"","command":"","commandArgs":"","x":520,"y":300,"wires":[["b706dd3b.cf87a"]]},{"id":"7c32f9e4.9fd4f8","type":"change","z":"4e1e6fde.a5bbf","name":"hub = CTRL","rules":[{"t":"set","p":"hub","pt":"msg","to":"CTRL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":60,"wires":[[]]},{"id":"e076de00.f88b6","type":"change","z":"4e1e6fde.a5bbf","name":"hub = OMNF","rules":[{"t":"set","p":"hub","pt":"msg","to":"OMNF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":120,"wires":[[]]},{"id":"320acf5d.6b427","type":"change","z":"4e1e6fde.a5bbf","name":"hub = OZIG","rules":[{"t":"set","p":"hub","pt":"msg","to":"OZIG","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":180,"wires":[[]]},{"id":"ef3ddba.1057c28","type":"change","z":"4e1e6fde.a5bbf","name":"hub = OZWA","rules":[{"t":"set","p":"hub","pt":"msg","to":"OZWA","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":240,"wires":[[]]},{"id":"47e952f6.d8d37c","type":"change","z":"4e1e6fde.a5bbf","name":"hub = MNZW","rules":[{"t":"set","p":"hub","pt":"msg","to":"MNZW","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":360,"wires":[[]]},{"id":"b47983a7.7b5f7","type":"switch","z":"4e1e6fde.a5bbf","name":"hub = CTRL \\n hub = OMNF \\n hub = OZIG \\n hub = OZWA \\n hub = OUPS \\n hub = MNZW","property":"hub","propertyType":"msg","rules":[{"t":"eq","v":"CTRL","vt":"str"},{"t":"eq","v":"OMNF","vt":"str"},{"t":"eq","v":"OZIG","vt":"str"},{"t":"eq","v":"OZWA","vt":"str"},{"t":"eq","v":"OUPS","vt":"str"},{"t":"eq","v":"MNZW","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":190,"y":200,"wires":[["fb597717.109328"],["2a44d5ee.875b7a"],["448a391d.a21278"],["e719a313.c7d78"],["ddcc8d55.8b128"],["e65b768b.ab1f68"]]},{"id":"b706dd3b.cf87a","type":"change","z":"4e1e6fde.a5bbf","name":"hub = OUPS","rules":[{"t":"set","p":"hub","pt":"msg","to":"OUPS","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":300,"wires":[[]]},{"id":"5f0d4ee4.54595","type":"subflow","name":"DevGrpCommand","info":"","category":"","in":[{"x":20,"y":80,"wires":[{"id":"12bc27d.a7615d8"}]}],"out":[{"x":1640,"y":80,"wires":[{"id":"5033935.2de806c","port":0}]}],"env":[{"name":"TOPIC","type":"str","value":"swGroupName"},{"name":"DEVICES","type":"str","value":""},{"name":"TYPE","type":"str","value":"switch"}],"color":"#DDAA99","status":{"x":1640,"y":220,"wires":[{"id":"eb697deb.09311","port":0}]}},{"id":"12bc27d.a7615d8","type":"switch","z":"5f0d4ee4.54595","name":"does msg.command exist \\n and is on/off?","property":"$exists(command) ? \t ($contains(command,/(on)|(off)/) ? true : false )\t: false\t\t","propertyType":"jsonata","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":210,"y":80,"wires":[["5716210f.80d6f"],[]]},{"id":"fd492199.dfaea","type":"join","z":"5f0d4ee4.54595","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":650,"y":140,"wires":[["5033935.2de806c"]]},{"id":"5033935.2de806c","type":"change","z":"5f0d4ee4.54595","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload_send","tot":"msg"},{"t":"delete","p":"deviceId","pt":"msg"},{"t":"delete","p":"payload_send","pt":"msg"},{"t":"delete","p":"response","pt":"msg"},{"t":"set","p":"topic","pt":"msg","to":"TOPIC","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":140,"wires":[["eb697deb.09311"]]},{"id":"eb697deb.09311","type":"change","z":"5f0d4ee4.54595","name":"payload = payload.value","rules":[{"t":"set","p":"payload","pt":"msg","to":"\t{\t\"fill\": (payload.value = \"on\" ? \"green\" : (payload.value = \"off\" ? \"blue\" : \"black\")),\t\"shape\":\"dot\",\t\"text\":'Command: \"' & payload.value & '\"'\t}\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1410,"y":220,"wires":[[]]},{"id":"caefe429.207cc8","type":"subflow:4e1e6fde.a5bbf","z":"5f0d4ee4.54595","name":"","env":[],"x":450,"y":140,"wires":[["fd492199.dfaea"]]},{"id":"5716210f.80d6f","type":"function","z":"5f0d4ee4.54595","name":"Gen related device msgs","func":"// walk thru device list and set commands\ndevList = env.get(\"DEVICES\");\ndevices = devList.split(\",\");\ntopic = env.get(\"TOPIC\");\nlen = devices.length;\n\nvar icnt = 0;\ndevices.forEach( o => {\n var dev = o.split(\"/\");\n var hub = dev[0];\n var devId = dev[1];\n\n var parts = {\n \"id\":topic,\n \"index\": icnt,\n \"count\": len,\n \"type\":\"object\",\n \"ch\":\"\",\n \"key\": o,\n \"len\":\"\"\n }\n\n var newPayld = {\n \"name\": \"switch\",\n \"value\": msg.command,\n \"displayName\": topic,\n \"deviceId\": devList,\n \"descriptionText\": topic,\n \"unit\": null,\n \"type\": null,\n \"data\": null\n };\n\n icnt++;\n msg.parts = parts;\n msg.deviceId = devId;\n msg.payload = {\"deviceId\": devId};\n msg.payload_send = newPayld;\n msg.hub = hub;\n \n //node.warn(o)\n\n node.send(msg);\n }\n);\n\n\n\nreturn;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":470,"y":80,"wires":[["caefe429.207cc8"]]},{"id":"9e28a145.80b4c","type":"subflow","name":"HubGrpRequest","info":"","category":"","in":[{"x":80,"y":200,"wires":[{"id":"8ef7fcff.46751"}]}],"out":[{"x":1140,"y":200,"wires":[{"id":"9abab016.1391","port":0},{"id":"ec167371.9e589","port":0},{"id":"40eaa66d.4bd218","port":0},{"id":"ef08a287.f93b4","port":0},{"id":"368409fd.864856","port":0},{"id":"ee11f083.f9355","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"9abab016.1391","type":"change","z":"9e28a145.80b4c","name":"hub = CTRL","rules":[{"t":"set","p":"hub","pt":"msg","to":"CTRL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":60,"wires":[[]]},{"id":"ec167371.9e589","type":"change","z":"9e28a145.80b4c","name":"hub = OMNF","rules":[{"t":"set","p":"hub","pt":"msg","to":"OMNF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":120,"wires":[[]]},{"id":"40eaa66d.4bd218","type":"change","z":"9e28a145.80b4c","name":"hub = OZIG","rules":[{"t":"set","p":"hub","pt":"msg","to":"OZIG","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":180,"wires":[[]]},{"id":"ef08a287.f93b4","type":"change","z":"9e28a145.80b4c","name":"hub = OZWA","rules":[{"t":"set","p":"hub","pt":"msg","to":"OZWA","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":240,"wires":[[]]},{"id":"ee11f083.f9355","type":"change","z":"9e28a145.80b4c","name":"hub = MNZW","rules":[{"t":"set","p":"hub","pt":"msg","to":"MNZW","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":360,"wires":[[]]},{"id":"1f8cc23e.0b944e","type":"hubitat request","z":"9e28a145.80b4c","name":"Control Hub / CTRL","server":"bc9b2ba4.2458c8","path":"","x":570,"y":60,"wires":[["9abab016.1391"]]},{"id":"8ef7fcff.46751","type":"switch","z":"9e28a145.80b4c","name":"hub = CTRL \\n hub = OMNF \\n hub = OZIG \\n hub = OZWA \\n hub = OUPS \\n hub = MNZW","property":"hub","propertyType":"msg","rules":[{"t":"eq","v":"CTRL","vt":"str"},{"t":"eq","v":"OMNF","vt":"str"},{"t":"eq","v":"OZIG","vt":"str"},{"t":"eq","v":"OZWA","vt":"str"},{"t":"eq","v":"OUPS","vt":"str"},{"t":"eq","v":"MNZW","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":290,"y":200,"wires":[["1f8cc23e.0b944e"],["ccd2f8bb.864ac8"],["c875db14.d98708"],["d62999a5.474738"],["ee51458c.5f4338"],["1ef39202.40cbbe"]]},{"id":"ccd2f8bb.864ac8","type":"hubitat request","z":"9e28a145.80b4c","name":"Main Hub / OMNF","server":"5664ca29.3af904","path":"","x":570,"y":120,"wires":[["ec167371.9e589"]]},{"id":"c875db14.d98708","type":"hubitat request","z":"9e28a145.80b4c","name":"Main Hub - Zigbee / OZIG","server":"623daead.b1d2b","path":"","x":590,"y":180,"wires":[["40eaa66d.4bd218"]]},{"id":"d62999a5.474738","type":"hubitat request","z":"9e28a145.80b4c","name":"Main Hub - Zwave / OZWA","server":"7631dfd4.02862","path":"","x":600,"y":240,"wires":[["ef08a287.f93b4"]]},{"id":"1ef39202.40cbbe","type":"hubitat request","z":"9e28a145.80b4c","name":"Main Hub C7 / MNZW","server":"106ae29b.a1d83d","path":"","x":580,"y":360,"wires":[["ee11f083.f9355"]]},{"id":"368409fd.864856","type":"change","z":"9e28a145.80b4c","name":"hub = OUPS","rules":[{"t":"set","p":"hub","pt":"msg","to":"OUPS","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":300,"wires":[[]]},{"id":"ee51458c.5f4338","type":"hubitat request","z":"9e28a145.80b4c","name":"Upstairs Hub / OUPS","server":"925818a7.4a4018","path":"","x":580,"y":300,"wires":[["368409fd.864856"]]},{"id":"925818a7.4a4018","type":"hubitat config","name":"Upstairs Hub","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook_upstairs","autoRefresh":true,"useWebsocket":false},{"id":"52da5ceb.f5efa4","type":"subflow","name":"HubGrpEvents","info":"","category":"","in":[],"out":[{"x":940,"y":180,"wires":[{"id":"fecb2a55.280378","port":0},{"id":"190e2933.bc97c7","port":0},{"id":"7f4e9570.890b4c","port":0},{"id":"8f1321f9.9cb4b","port":0},{"id":"fb90e9a9.67a1a8","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"5ee947d2.aac928","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Control Hub - CTRL","server":"bc9b2ba4.2458c8","x":190,"y":80,"wires":[["fecb2a55.280378"]]},{"id":"dd1d273.772d9d8","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Main Hub / OMNF","server":"5664ca29.3af904","x":190,"y":140,"wires":[["190e2933.bc97c7"]]},{"id":"da0c1a72.241788","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Main Hub - Zigbee / OZIG","server":"623daead.b1d2b","x":210,"y":200,"wires":[["7f4e9570.890b4c"]]},{"id":"226988d4.2fbc28","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Main Hub - Zwave / OZWA","server":"7631dfd4.02862","x":210,"y":260,"wires":[["8f1321f9.9cb4b"]]},{"id":"2dada7ec.57be98","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Main Hub C7 / MNZW","server":"106ae29b.a1d83d","x":200,"y":320,"wires":[["fb90e9a9.67a1a8"]]},{"id":"fecb2a55.280378","type":"change","z":"52da5ceb.f5efa4","name":"hub = CTRL","rules":[{"t":"set","p":"hub","pt":"msg","to":"CTRL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":80,"wires":[[]]},{"id":"190e2933.bc97c7","type":"change","z":"52da5ceb.f5efa4","name":"hub = OMNF","rules":[{"t":"set","p":"hub","pt":"msg","to":"OMNF","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":140,"wires":[[]]},{"id":"7f4e9570.890b4c","type":"change","z":"52da5ceb.f5efa4","name":"hub = OZIG","rules":[{"t":"set","p":"hub","pt":"msg","to":"OZIG","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":200,"wires":[[]]},{"id":"8f1321f9.9cb4b","type":"change","z":"52da5ceb.f5efa4","name":"hub = OZWA","rules":[{"t":"set","p":"hub","pt":"msg","to":"OZWA","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":260,"wires":[[]]},{"id":"fb90e9a9.67a1a8","type":"change","z":"52da5ceb.f5efa4","name":"hub = MNZW","rules":[{"t":"set","p":"hub","pt":"msg","to":"MNZW","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":320,"wires":[[]]},{"id":"bc9b2ba4.2458c8","type":"hubitat config","name":"Control Hub","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook_control","autoRefresh":false,"useWebsocket":false},{"id":"5664ca29.3af904","type":"hubitat config","name":"Main Hub","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook","autoRefresh":true,"useWebsocket":false},{"id":"623daead.b1d2b","type":"hubitat config","name":"Main Hub - Zigbee","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook_main_zigbee","autoRefresh":true,"useWebsocket":false},{"id":"7631dfd4.02862","type":"hubitat config","name":"Main Hub - Zwave","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook_main_zwave","autoRefresh":true,"useWebsocket":false},{"id":"106ae29b.a1d83d","type":"hubitat config","name":"Main Hub C7","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook_c7","autoRefresh":true,"useWebsocket":false},{"id":"7e71de96.77727","type":"subflow","name":"DevGrpEvent","info":"","category":"","in":[{"x":60,"y":120,"wires":[{"id":"2feace6b.d14dc2"}]}],"out":[{"x":1720,"y":200,"wires":[{"id":"db3390b.b70b57","port":0},{"id":"ee37dbfb.f47708","port":0}]},{"x":1720,"y":280,"wires":[{"id":"26ad91b7.ae866e","port":0}]}],"env":[{"name":"TOPIC","type":"str","value":"swGroupName"},{"name":"DEVICES","type":"str","value":""},{"name":"TYPE","type":"str","value":"switch"},{"name":"ACTIONS","type":"str","value":"on/off"},{"name":"ALL_ACTION1","type":"bool","value":"true"},{"name":"ALL_ACTION2","type":"bool","value":"true"},{"name":"SEND_EVENTS","type":"bool","value":"true"}],"color":"#DDAA99","status":{"x":1720,"y":360,"wires":[{"id":"26ad91b7.ae866e","port":0}]}},{"id":"fb5a0d32.35fce","type":"switch","z":"7e71de96.77727","name":"does event match specified deviceId?","property":"DEVICES","propertyType":"env","rules":[{"t":"cont","v":"hub & \"/\" & payload.deviceId","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":1,"x":1070,"y":40,"wires":[["81abc8d5.998a58"]]},{"id":"778ec673.85ac28","type":"function","z":"7e71de96.77727","name":"Gen related device msgs","func":"// walk thru device list and set commands\ndevices = env.get(\"DEVICES\").split(\",\");\ntopic = env.get(\"TOPIC\");\nlen = devices.length;\nflow.set(\"State_MAX\", len);\n\n\nvar icnt = 0;\ndevices.forEach( o => {\n var dev = o.split(\"/\");\n var hub = dev[0];\n var device = dev[1];\n var path = \"/devices/\" + device;\n var parts = {\n \"id\":topic,\n \"index\": icnt,\n \"count\": len,\n \"type\":\"object\",\n \"ch\":\"\",\n \"key\": o,\n \"len\":\"\"\n }\n \n icnt++;\n msg.topic = topic;\n msg.path = path;\n msg.parts = parts;\n msg.hub = hub\n\n \n node.send(msg);\n }\n);\n\n\n\nreturn;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":150,"y":220,"wires":[["61c08ebe.0a8ba"]]},{"id":"61c08ebe.0a8ba","type":"delay","z":"7e71de96.77727","name":"","pauseType":"random","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"50","randomUnits":"milliseconds","drop":false,"x":360,"y":220,"wires":[["836e4fce.3b2e"]]},{"id":"c9807839.b005f8","type":"join","z":"7e71de96.77727","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":970,"y":220,"wires":[["392ba79a.a06c58"]]},{"id":"81abc8d5.998a58","type":"change","z":"7e71de96.77727","name":"Initialize flow vars","rules":[{"t":"set","p":"State_1","pt":"flow","to":"0","tot":"jsonata"},{"t":"set","p":"State_2","pt":"flow","to":"0","tot":"jsonata"},{"t":"set","p":"State_MAX","pt":"flow","to":"0","tot":"jsonata"},{"t":"set","p":"devices","pt":"flow","to":"{\"devList\":[]}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":120,"wires":[["778ec673.85ac28"]]},{"id":"392ba79a.a06c58","type":"change","z":"7e71de96.77727","name":"","rules":[{"t":"set","p":"state.State_1","pt":"msg","to":"State_1","tot":"flow"},{"t":"set","p":"state.State_2","pt":"msg","to":"State_2","tot":"flow"},{"t":"set","p":"state.State_MAX","pt":"msg","to":"State_MAX","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":300,"wires":[["e0050d3.909bbf"]]},{"id":"b6398b5.f1c4978","type":"function","z":"7e71de96.77727","name":"accumulate stats","func":"\nvar state1 = flow.get(\"State_1\");\nvar state2 = flow.get(\"State_2\");\nvar devType = env.get(\"TYPE\");\nvar actions = env.get(\"ACTIONS\").split(\"/\");\nvar retMsg;\nvar hub = msg.hub;\nvar devId = hub + \"/\" + msg.payload.id;\nvar dev = flow.get(\"devices\");\n\n\nvar devList = [];\n\nif (dev) {\n devList = dev.devList;\n}\n\n//node.warn(devList);\n\n\nif (!devList.includes(devId)) {\n \n devList.push(devId);\n dev.devList = devList;\n flow.set(\"devices\",dev);\n \n // set flow counting vars\n var attr = msg.payload.attributes;\n //node.warn(attr);\n var osw = attr.find(od => od.name === devType );\n msg.payload.value = osw.currentValue;\n \n if (osw.currentValue === actions[0]) {\n state1++;\n flow.set(\"State_1\",state1);\n } else if (osw.currentValue === actions[1]) {\n state2++;\n flow.set(\"State_2\",state2);\n }\n \n // strip \"path\"/\"hub\" for tidiness\n delete msg.path;\n delete msg.hub;\n \n retMsg = msg;\n}\n\n\nreturn retMsg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":790,"y":220,"wires":[["c9807839.b005f8"]]},{"id":"e0050d3.909bbf","type":"function","z":"7e71de96.77727","name":"Set payload","func":"var topic = env.get(\"TOPIC\");\nvar devices = env.get(\"DEVICES\");\nvar bAll1 = env.get(\"ALL_ACTION1\");\nvar bAll2 = env.get(\"ALL_ACTION2\");\nvar devType = env.get(\"TYPE\");\nvar actions = env.get(\"ACTIONS\").split(\"/\");\n\n\nvar cnt1 = msg.state.State_1;\nvar cnt2 = msg.state.State_2;\nvar cntNum = msg.state.State_MAX;\nvar calcVal = \"\";\n\nvar newPayld = {\n \"name\": topic,\n \"currentValue\": \"\",\n \"value\": \"\",\n \"displayName\": topic,\n \"dataType\": \"ENUM\",\t\n \"values\": {\"0\":actions[0],\"1\":actions[1]},\n \"deviceId\": devices\n};\n\nif ( bAll1 && bAll2 ){\n if (cnt1 === cntNum){\n calcVal = actions[0];\n } else if (cnt2 === cntNum){\n calcVal = actions[1];\n } else {\n calcVal = \"pending\";\n }\n}\nelse if ( bAll1 && !bAll2 ){\n if (cnt1 === cntNum){\n calcVal = actions[0];\n } else {\n calcVal = actions[1];\n }\n \n}\nelse if ( !bAll1 && bAll2 ){\n if (cnt2 === cntNum){\n calcVal = actions[1];\n } else {\n calcVal = actions[0];\n }\n \n}\nelse{\n calcVal = \"undefined\";\n}\n\nnewPayld.value = calcVal\nnewPayld.currentValue = calcVal\n\nmsg.topic = topic\nmsg.payload = newPayld\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":990,"y":300,"wires":[["26ad91b7.ae866e","ee37dbfb.f47708"]]},{"id":"e82be6d9.b86718","type":"switch","z":"7e71de96.77727","name":"SEND_EVENTS = true?","property":"SEND_EVENTS","propertyType":"env","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":390,"y":40,"wires":[["bc8384ad.287788"]]},{"id":"db3390b.b70b57","type":"rbe","z":"7e71de96.77727","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload.value","x":1530,"y":260,"wires":[[]]},{"id":"f79df937.2dc538","type":"switch","z":"7e71de96.77727","name":"value != pending and != undefined","property":"true","propertyType":"jsonata","rules":[{"t":"eq","v":"payload.value != \"pending\" and payload.value != \"undefined\"","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":1,"x":1300,"y":260,"wires":[["db3390b.b70b57"]]},{"id":"26ad91b7.ae866e","type":"function","z":"7e71de96.77727","name":"set status payload","func":"/*\n\n{\n\"fill\": (payload.value = \"on\" ? \"green\" : (payload.value = \"off\" ? \"blue\" : \"black\")),\n\"shape\":\"dot\",\n\"text\":'Status: \"' & payload.value & '\"'\n}\n\n*/\n\n\nvar devType = env.get(\"TYPE\");\nvar actions = env.get(\"ACTIONS\").split(\"/\");\n\nvar payload = {\n\"fill\": (msg.payload.value === actions[0] ? \"green\" : (msg.payload.value === actions[1] ? \"blue\" : \"black\")),\n\"shape\":\"dot\",\n\"text\":'Status: \"' + msg.payload.value + '\"'\n};\n\nmsg.payload = payload;\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1250,"y":360,"wires":[[]]},{"id":"ee37dbfb.f47708","type":"switch","z":"7e71de96.77727","name":"override = true/false","property":"override","propertyType":"flow","rules":[{"t":"true"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1260,"y":200,"wires":[[],["f79df937.2dc538"]]},{"id":"2feace6b.d14dc2","type":"change","z":"7e71de96.77727","name":"override = true","rules":[{"t":"set","p":"override","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":120,"wires":[["81abc8d5.998a58"]]},{"id":"bc8384ad.287788","type":"change","z":"7e71de96.77727","name":"override = false","rules":[{"t":"set","p":"override","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":40,"wires":[["fb5a0d32.35fce"]]},{"id":"ff11f9ac.a1dc08","type":"subflow:52da5ceb.f5efa4","z":"7e71de96.77727","name":"","x":120,"y":40,"wires":[["e82be6d9.b86718"]]},{"id":"836e4fce.3b2e","type":"subflow:9e28a145.80b4c","z":"7e71de96.77727","name":"","x":540,"y":220,"wires":[["b6398b5.f1c4978"]]},{"id":"29102dd4.c88fb2","type":"debug","z":"af91369d.586338","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":500,"wires":[]},{"id":"9b30373e.7864f8","type":"inject","z":"af91369d.586338","name":"On","props":[{"p":"command","v":"on","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":110,"y":480,"wires":[["f1c84278.5de4b"]]},{"id":"33147b0b.f47114","type":"inject","z":"af91369d.586338","name":"Off","props":[{"p":"command","v":"off","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":110,"y":520,"wires":[["f1c84278.5de4b"]]},{"id":"520a03bd.66998c","type":"debug","z":"af91369d.586338","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":420,"wires":[]},{"id":"220cdb4f.808114","type":"subflow:7e71de96.77727","z":"af91369d.586338","name":"","env":[{"name":"TOPIC","value":"OfficeLights","type":"str"},{"name":"DEVICES","value":"OZIG/1773,OZIG/1774","type":"str"},{"name":"SEND_EVENTS","value":"false","type":"bool"}],"x":380,"y":420,"wires":[["520a03bd.66998c"],[]]},{"id":"f1c84278.5de4b","type":"subflow:5f0d4ee4.54595","z":"af91369d.586338","name":"","env":[{"name":"TOPIC","value":"OfficeLights","type":"str"},{"name":"DEVICES","value":"OZIG/1773,OZIG/1774","type":"str"}],"x":390,"y":500,"wires":[["29102dd4.c88fb2"]]},{"id":"70412c3c.829824","type":"debug","z":"af91369d.586338","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":560,"wires":[]},{"id":"dff81a81.d917c8","type":"subflow:7e71de96.77727","z":"af91369d.586338","name":"","env":[{"name":"TOPIC","value":"OfficeLights","type":"str"},{"name":"DEVICES","value":"OZIG/1773,OZIG/1774","type":"str"}],"x":380,"y":560,"wires":[["70412c3c.829824"],[]]},{"id":"2d55ccab.9fa964","type":"inject","z":"af91369d.586338","name":"nothing","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"nothing","payloadType":"str","x":110,"y":420,"wires":[["220cdb4f.808114"]]}]
Groupings in NR - Further tweaks and updates. 11/30/20
[{"id":"4e1e6fde.a5bbf","type":"subflow","name":"HubGrpCommand","info":"","category":"","in":[{"x":40,"y":40,"wires":[{"id":"b47983a7.7b5f7"}]}],"out":[{"x":1220,"y":180,"wires":[{"id":"e076de00.f88b6","port":0},{"id":"320acf5d.6b427","port":0},{"id":"b706dd3b.cf87a","port":0},{"id":"47e952f6.d8d37c","port":0}]}],"env":[],"color":"#FC7A5E"},{"id":"2a44d5ee.875b7a","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Main Hub / OLDMAIN","server":"5664ca29.3af904","deviceId":"","command":"","commandArgs":"","x":520,"y":120,"wires":[["e076de00.f88b6"]]},{"id":"448a391d.a21278","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Main Hub - Zigbee / OLDZIGB","server":"623daead.b1d2b","deviceId":"","command":"","commandArgs":"","x":550,"y":180,"wires":[["320acf5d.6b427"]]},{"id":"e65b768b.ab1f68","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Main Hub C7 / MAIN","server":"106ae29b.a1d83d","deviceId":"","command":"","commandArgs":"","x":520,"y":300,"wires":[["47e952f6.d8d37c"]]},{"id":"ddcc8d55.8b128","type":"hubitat command","z":"4e1e6fde.a5bbf","name":"Upstairs Hub / UPSTAIRS","server":"925818a7.4a4018","deviceId":"","command":"","commandArgs":"","x":530,"y":240,"wires":[["b706dd3b.cf87a"]]},{"id":"e076de00.f88b6","type":"change","z":"4e1e6fde.a5bbf","name":"hub = OLDMAIN","rules":[{"t":"set","p":"hub","pt":"msg","to":"OLDMAIN","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":840,"y":120,"wires":[[]]},{"id":"320acf5d.6b427","type":"change","z":"4e1e6fde.a5bbf","name":"hub = OLDZIGB","rules":[{"t":"set","p":"hub","pt":"msg","to":"OLDZIGB","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":840,"y":180,"wires":[[]]},{"id":"47e952f6.d8d37c","type":"change","z":"4e1e6fde.a5bbf","name":"hub = MAIN","rules":[{"t":"set","p":"hub","pt":"msg","to":"MAIN","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":830,"y":300,"wires":[[]]},{"id":"b47983a7.7b5f7","type":"switch","z":"4e1e6fde.a5bbf","name":"hub = OLDMAIN \\n hub = OLDZIGB \\n hub = UPSTAIRS \\n hub = MAIN","property":"hub","propertyType":"msg","rules":[{"t":"eq","v":"OLDMAIN","vt":"str"},{"t":"eq","v":"OLDZIGB","vt":"str"},{"t":"eq","v":"UPSTAIRS","vt":"str"},{"t":"eq","v":"MAIN","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":210,"y":200,"wires":[["2a44d5ee.875b7a"],["448a391d.a21278"],["ddcc8d55.8b128"],["e65b768b.ab1f68"]]},{"id":"b706dd3b.cf87a","type":"change","z":"4e1e6fde.a5bbf","name":"hub = UPSTAIRS","rules":[{"t":"set","p":"hub","pt":"msg","to":"UPSTAIRS","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":240,"wires":[[]]},{"id":"5f0d4ee4.54595","type":"subflow","name":"DevGrpCommand","info":"","category":"","in":[{"x":20,"y":80,"wires":[{"id":"12bc27d.a7615d8"}]}],"out":[{"x":1520,"y":140,"wires":[{"id":"5033935.2de806c","port":0}]}],"env":[{"name":"TOPIC","type":"str","value":"swGroupName"},{"name":"DEVICES","type":"str","value":""},{"name":"TYPE","type":"str","value":"switch"},{"name":"ACTION","type":"str","value":"on/off"}],"color":"#FC7A5E","icon":"node-red-contrib-hubitat/command.svg","status":{"x":1520,"y":220,"wires":[{"id":"eb697deb.09311","port":0}]}},{"id":"12bc27d.a7615d8","type":"switch","z":"5f0d4ee4.54595","name":"does msg.command exist \\n and exists within ACTION?","property":"$exists(command) ? \t ($contains($env(\"ACTION\"),command) ? true : false )\t: false\t\t","propertyType":"jsonata","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":200,"y":80,"wires":[["5716210f.80d6f"],[]]},{"id":"fd492199.dfaea","type":"join","z":"5f0d4ee4.54595","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":790,"y":140,"wires":[["5033935.2de806c"]]},{"id":"5033935.2de806c","type":"change","z":"5f0d4ee4.54595","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload_send","tot":"msg"},{"t":"delete","p":"deviceId","pt":"msg"},{"t":"delete","p":"payload_send","pt":"msg"},{"t":"delete","p":"response","pt":"msg"},{"t":"set","p":"topic","pt":"msg","to":"TOPIC","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":140,"wires":[["eb697deb.09311"]]},{"id":"eb697deb.09311","type":"change","z":"5f0d4ee4.54595","name":"payload = payload.value","rules":[{"t":"set","p":"payload","pt":"msg","to":"\t{\t\"fill\": (payload.value = \"on\" ? \"green\" : (payload.value = \"off\" ? \"blue\" : \"black\")),\t\"shape\":\"dot\",\t\"text\":'Command: \"' & payload.value & '\"'\t}\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1270,"y":220,"wires":[[]]},{"id":"caefe429.207cc8","type":"subflow:4e1e6fde.a5bbf","z":"5f0d4ee4.54595","name":"","env":[],"x":510,"y":140,"wires":[["fd492199.dfaea"]]},{"id":"5716210f.80d6f","type":"function","z":"5f0d4ee4.54595","name":"Gen related device msgs","func":"// walk thru device list and set commands\n\nvar topic = env.get(\"TOPIC\");\nvar devList = env.get(\"DEVICES\");\n//var devices = devList.split(\",\");\n// devices = env.get(\"DEVICES\").split(\",\");\n\n// if passing devices via deviceId \nif (msg.deviceId) {\n devList = msg.deviceId;\n}\n\nvar devices;\nvar isString;\nif (typeof devList === \"string\") {\n isString = true;\n devices = devList.split(\",\");\n} else {\n isString = false;\n devices = devList;\n}\n\nvar len = devices.length;\n\nvar icnt = 0;\ndevices.forEach( o => {\n\n // var dev = o.split(\"/\");\n // var hub = dev[0];\n // var devId = dev[1];\n var hub;\n var devId;\n var key;\n\n\n if( isString ) { \n var dev = o.split(\"/\");\n hub = dev[0];\n devId = dev[1];\n key = o;\n } else {\n hub = o.hub;\n devId = o.deviceId;\n key = o.hub + \"/\" + o.deviceId;\n }\n\n\n var parts = {\n \"id\":topic,\n \"index\": icnt,\n \"count\": len,\n \"type\":\"object\",\n \"ch\":\"\",\n \"key\": key,\n \"len\":\"\"\n }\n\n var newPayld = {\n \"name\": \"switch\",\n \"value\": msg.command,\n \"displayName\": topic,\n \"deviceId\": devList,\n \"descriptionText\": topic,\n \"unit\": null,\n \"type\": null,\n \"data\": null\n };\n\n icnt++;\n msg.parts = parts;\n msg.deviceId = devId;\n msg.payload = {\"deviceId\": devId};\n msg.payload_send = newPayld;\n msg.hub = hub;\n \n //node.warn(o)\n\n node.send(msg);\n}\n);\n\n\n\nreturn;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":530,"y":80,"wires":[["caefe429.207cc8"]]},{"id":"9e28a145.80b4c","type":"subflow","name":"HubGrpRequest","info":"","category":"","in":[{"x":80,"y":200,"wires":[{"id":"8ef7fcff.46751"}]}],"out":[{"x":1140,"y":200,"wires":[{"id":"ec167371.9e589","port":0},{"id":"40eaa66d.4bd218","port":0},{"id":"368409fd.864856","port":0},{"id":"ee11f083.f9355","port":0}]}],"env":[],"color":"#FC7A5E"},{"id":"ec167371.9e589","type":"change","z":"9e28a145.80b4c","name":"hub = OLDMAIN","rules":[{"t":"set","p":"hub","pt":"msg","to":"OLDMAIN","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":860,"y":120,"wires":[[]]},{"id":"40eaa66d.4bd218","type":"change","z":"9e28a145.80b4c","name":"hub = OLDZIGB","rules":[{"t":"set","p":"hub","pt":"msg","to":"OLDZIGB","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":860,"y":180,"wires":[[]]},{"id":"ee11f083.f9355","type":"change","z":"9e28a145.80b4c","name":"hub = MAIN","rules":[{"t":"set","p":"hub","pt":"msg","to":"MAIN","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":300,"wires":[[]]},{"id":"8ef7fcff.46751","type":"switch","z":"9e28a145.80b4c","name":"hub = OLDMAIN \\n hub = OLDZIGB \\n hub = UPSTAIRS \\n hub = MAIN","property":"hub","propertyType":"msg","rules":[{"t":"eq","v":"OLDMAIN","vt":"str"},{"t":"eq","v":"OLDZIGB","vt":"str"},{"t":"eq","v":"UPSTAIRS","vt":"str"},{"t":"eq","v":"MAIN","vt":"str"}],"checkall":"false","repair":false,"outputs":4,"x":310,"y":200,"wires":[["ccd2f8bb.864ac8"],["c875db14.d98708"],["ee51458c.5f4338"],["1ef39202.40cbbe"]]},{"id":"ccd2f8bb.864ac8","type":"hubitat request","z":"9e28a145.80b4c","name":"Main Hub / OLDMAIN","server":"5664ca29.3af904","path":"","x":580,"y":120,"wires":[["ec167371.9e589"]]},{"id":"c875db14.d98708","type":"hubitat request","z":"9e28a145.80b4c","name":"Main Hub - Zigbee / OLDZIGB","server":"623daead.b1d2b","path":"","x":610,"y":180,"wires":[["40eaa66d.4bd218"]]},{"id":"1ef39202.40cbbe","type":"hubitat request","z":"9e28a145.80b4c","name":"Main Hub C7 / MAIN","server":"106ae29b.a1d83d","path":"","x":580,"y":300,"wires":[["ee11f083.f9355"]]},{"id":"368409fd.864856","type":"change","z":"9e28a145.80b4c","name":"hub = UPSTAIRS","rules":[{"t":"set","p":"hub","pt":"msg","to":"UPSTAIRS","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":240,"wires":[[]]},{"id":"ee51458c.5f4338","type":"hubitat request","z":"9e28a145.80b4c","name":"Upstairs Hub / UPSTAIRS","server":"925818a7.4a4018","path":"","x":590,"y":240,"wires":[["368409fd.864856"]]},{"id":"52da5ceb.f5efa4","type":"subflow","name":"HubGrpEvents","info":"","category":"","in":[],"out":[{"x":940,"y":180,"wires":[{"id":"190e2933.bc97c7","port":0},{"id":"7f4e9570.890b4c","port":0},{"id":"fb90e9a9.67a1a8","port":0},{"id":"3360de68.b23be2","port":0}]}],"env":[],"color":"#FC7A5E"},{"id":"dd1d273.772d9d8","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Main Hub / OLDMAIN","server":"5664ca29.3af904","x":200,"y":140,"wires":[["190e2933.bc97c7"]]},{"id":"da0c1a72.241788","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Main Hub - Zigbee / OLDZIGB","server":"623daead.b1d2b","x":220,"y":200,"wires":[["7f4e9570.890b4c"]]},{"id":"2dada7ec.57be98","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Main Hub C7 / MAIN","server":"106ae29b.a1d83d","x":190,"y":260,"wires":[["fb90e9a9.67a1a8"]]},{"id":"190e2933.bc97c7","type":"change","z":"52da5ceb.f5efa4","name":"hub = OLDMAIN","rules":[{"t":"set","p":"hub","pt":"msg","to":"OLDMAIN","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":140,"wires":[[]]},{"id":"7f4e9570.890b4c","type":"change","z":"52da5ceb.f5efa4","name":"hub = OLDZIGB","rules":[{"t":"set","p":"hub","pt":"msg","to":"OLDZIGB","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":200,"wires":[[]]},{"id":"fb90e9a9.67a1a8","type":"change","z":"52da5ceb.f5efa4","name":"hub = MAIN","rules":[{"t":"set","p":"hub","pt":"msg","to":"MAIN","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":260,"wires":[[]]},{"id":"74b24021.1e4e4","type":"hubitat event","z":"52da5ceb.f5efa4","name":"Upstairs Hub / UPSTAIRS","server":"925818a7.4a4018","x":210,"y":80,"wires":[["3360de68.b23be2"]]},{"id":"3360de68.b23be2","type":"change","z":"52da5ceb.f5efa4","name":"hub = UPSTAIRS","rules":[{"t":"set","p":"hub","pt":"msg","to":"UPSTAIRS","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":80,"wires":[[]]},{"id":"5664ca29.3af904","type":"hubitat config","name":"Main Hub","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook","autoRefresh":true,"useWebsocket":false},{"id":"623daead.b1d2b","type":"hubitat config","name":"Main Hub - Zigbee","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook_main_zigbee","autoRefresh":true,"useWebsocket":false},{"id":"106ae29b.a1d83d","type":"hubitat config","name":"Main Hub C7","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook_c7","autoRefresh":true,"useWebsocket":false},{"id":"925818a7.4a4018","type":"hubitat config","name":"Upstairs Hub","usetls":false,"host":"0.0.0.0","port":"80","appId":"000","nodeRedServer":"http://0.0.0.0:1880","webhookPath":"/hubitat/webhook_upstairs","autoRefresh":true,"useWebsocket":false},{"id":"7e71de96.77727","type":"subflow","name":"DevGrpEvent","info":"","category":"","in":[{"x":60,"y":120,"wires":[{"id":"2feace6b.d14dc2"}]}],"out":[{"x":1740,"y":240,"wires":[{"id":"db3390b.b70b57","port":0},{"id":"ee37dbfb.f47708","port":0},{"id":"497e1185.1ce5b","port":0}]},{"x":1740,"y":340,"wires":[{"id":"26ad91b7.ae866e","port":0}]}],"env":[{"name":"TOPIC","type":"str","value":"swGroupName"},{"name":"DEVICES","type":"str","value":""},{"name":"TYPE","type":"str","value":"switch"},{"name":"ACTIONS","type":"str","value":"on/off"},{"name":"ALL_ACTION1","type":"bool","value":"true"},{"name":"ALL_ACTION2","type":"bool","value":"true"},{"name":"SEND_EVENTS","type":"bool","value":"true"},{"name":"RETURN_ALL_MSGS","type":"bool","value":"false"}],"color":"#FC7A5E","outputLabels":["Event Result","Event Status"],"icon":"node-red-contrib-hubitat/device.svg","status":{"x":1740,"y":400,"wires":[{"id":"26ad91b7.ae866e","port":0}]}},{"id":"778ec673.85ac28","type":"function","z":"7e71de96.77727","name":"Gen related device msgs","func":"// walk thru device list and set commands\nvar topic = env.get(\"TOPIC\");\nvar devList = env.get(\"DEVICES\");\nvar activeVal = ( msg.payload.value ? msg.payload.value : \"\" );\n//var devices = devList.split(\",\");\n\n//node.warn(devList);\n\n// devices = env.get(\"DEVICES\").split(\",\");\nvar devices;\nvar isString;\nif (typeof devList === \"string\") {\n isString = true;\n devices = devList.split(\",\");\n} else {\n isString = false;\n devices = devList;\n}\n\n\n//node.warn(devices);\n\nvar len = devices.length;\n\nflow.set(\"State_MAX\", len);\n\nvar icnt = 0;\ndevices.forEach( o => {\n\n //var dev = o.split(\"/\");\n //var hub = dev[0];\n //var device = dev[1];\n var hub;\n var devId;\n var key;\n\n if( isString ) { \n var dev = o.split(\"/\");\n hub = dev[0];\n devId = dev[1];\n key = o;\n } else {\n hub = o.hub;\n devId = o.deviceId;\n key = o.hub + \"/\" + o.deviceId;\n }\n\n //var hub = dev.hub;\n //var devId = dev.deviceId;\n\n \n var path = \"/devices/\" + devId;\n var parts = {\n \"id\":topic,\n \"index\": icnt,\n \"count\": len,\n \"type\":\"object\",\n \"ch\":\"\",\n \"key\": key,\n \"len\":\"\"\n }\n \n icnt++;\n msg.topic = topic;\n msg.path = path;\n msg.parts = parts;\n msg.hub = hub\n msg.activevalue = activeVal;\n \n node.send(msg);\n node.done();\n}\n);\n\n\n\nreturn;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":930,"y":120,"wires":[["1c902085.1cf74f"]]},{"id":"c9807839.b005f8","type":"join","z":"7e71de96.77727","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1210,"y":180,"wires":[["392ba79a.a06c58"]]},{"id":"81abc8d5.998a58","type":"change","z":"7e71de96.77727","name":"Initialize flow vars","rules":[{"t":"set","p":"State_1","pt":"flow","to":"0","tot":"jsonata"},{"t":"set","p":"State_2","pt":"flow","to":"0","tot":"jsonata"},{"t":"set","p":"State_MAX","pt":"flow","to":"0","tot":"jsonata"},{"t":"set","p":"devCheck","pt":"flow","to":"[]","tot":"json"},{"t":"set","p":"LstState_1","pt":"flow","to":"","tot":"str"},{"t":"set","p":"LstState_2","pt":"flow","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":120,"wires":[["778ec673.85ac28"]]},{"id":"392ba79a.a06c58","type":"change","z":"7e71de96.77727","name":"","rules":[{"t":"set","p":"state.State_1","pt":"msg","to":"State_1","tot":"flow"},{"t":"set","p":"state.State_2","pt":"msg","to":"State_2","tot":"flow"},{"t":"set","p":"state.State_MAX","pt":"msg","to":"State_MAX","tot":"flow"},{"t":"set","p":"state.State1_devices","pt":"msg","to":"LstState_1","tot":"flow"},{"t":"set","p":"state.State2_devices","pt":"msg","to":"LstState_2","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":240,"wires":[["e0050d3.909bbf"]]},{"id":"b6398b5.f1c4978","type":"function","z":"7e71de96.77727","name":"accumulate stats","func":"\nvar state1 = flow.get(\"State_1\");\nvar state2 = flow.get(\"State_2\");\nvar devType = env.get(\"TYPE\");\nvar actions = env.get(\"ACTIONS\").split(\"/\");\nvar devices = env.get(\"DEVICES\");\n\n//var retMsg;\nvar hub = msg.hub;\nvar devId = hub + \"/\" + msg.payload.id;\n\n/*\nvar dev = flow.get(\"devs4stats\");\nvar devList = [];\n\nif (dev !== undefined ) {\n devList = dev;\n}\n*/\n\n//if (!devList) {\n// node.warn(\"No devices found for \" + hub);\n// return\n//}\n\n//node.warn(devList);\n\n//node.warn(devList);\nvar devList = flow.get(\"devCheck\") ? flow.get(\"devCheck\") : [];\n\n\n// Note: these only show devices with the same action either State1 or State2 not both.\nvar devLstState1 = flow.get(\"LstState_1\") ? flow.get(\"LstState_1\") : \"\";\nvar devLstState2 = flow.get(\"LstState_2\") ? flow.get(\"LstState_2\") : \"\";\n\nif (!devList.includes(devId)) {\n \n //node.warn(devId);\n \n devList.push(devId);\n //dev.devList = devList;\n flow.set(\"devCheck\",devList);\n \n // set flow counting vars\n var attr = msg.payload.attributes;\n //node.warn(attr);\n var osw = attr.find(od => od.name === devType );\n msg.payload.value = osw.currentValue;\n \n var pos;\n \n if (osw.currentValue === actions[0]) {\n state1++;\n flow.set(\"State_1\",state1);\n\n if (!devLstState1.includes(devId)){\n devLstState1 += ( devLstState1 ? \",\" : \"\" ) + devId;\n }\n \n pos = devLstState2.indexOf(devId)\n if (pos > -1){\n devLstState2 = devLstState2.replace( ( pos === 0 ? \"\" : \",\") + devId + ( pos === 0 ? \",\" : \"\"), \"\");\n }\n //devLstState2 = \"\";\n \n } else if (osw.currentValue === actions[1]) {\n state2++;\n flow.set(\"State_2\",state2);\n\n if (!devLstState2.includes(devId)){\n devLstState2 += ( devLstState2 ? \",\" : \"\" ) + devId;\n }\n pos = devLstState1.indexOf(devId)\n if (pos > -1){\n devLstState1 = devLstState1.replace( ( pos === 0 ? \"\" : \",\") + devId + ( pos === 0 ? \",\" : \"\"), \"\");\n }\n\n }\n\n flow.set(\"LstState_1\",devLstState1);\n flow.set(\"LstState_2\",devLstState2);\n\n \n //node.warn(msg)\n \n // strip \"path\"/\"hub\" for tidiness\n delete msg.path;\n delete msg.hub;\n \n //retMsg = msg;\n node.send(msg);\n node.done();\n}\n\n\nreturn;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":910,"y":180,"wires":[["c9807839.b005f8"]]},{"id":"e0050d3.909bbf","type":"function","z":"7e71de96.77727","name":"Set payload","func":"var topic = env.get(\"TOPIC\");\nvar devices = env.get(\"DEVICES\");\nvar bAll1 = env.get(\"ALL_ACTION1\");\nvar bAll2 = env.get(\"ALL_ACTION2\");\nvar devType = env.get(\"TYPE\");\nvar actions = env.get(\"ACTIONS\").split(\"/\");\n\nvar cnt1 = msg.state.State_1;\nvar cnt2 = msg.state.State_2;\nvar cntNum = cnt1 + cnt2;\n//var cntNum = msg.state.State_MAX;\nvar calcVal = \"\";\n\nvar newPayld = {\n \"name\": topic,\n \"currentValue\": \"\",\n \"value\": \"\",\n \"displayName\": topic,\n \"dataType\": \"ENUM\",\t\n \"values\": {\"0\":actions[0],\"1\":actions[1]},\n \"deviceId\": devices\n};\n\nif ( bAll1 && bAll2 ){\n if (cnt1 === cntNum){\n calcVal = actions[0];\n } else if (cnt2 === cntNum){\n calcVal = actions[1];\n } else {\n calcVal = \"pending\";\n }\n}\nelse if ( bAll1 && !bAll2 ){\n if (cnt1 === cntNum){\n calcVal = actions[0];\n } else {\n calcVal = actions[1];\n }\n \n}\nelse if ( !bAll1 && bAll2 ){\n if (cnt2 === cntNum){\n calcVal = actions[1];\n } else {\n calcVal = actions[0];\n }\n}\nelse{\n calcVal = \"undefined\";\n}\n\nnewPayld.value = calcVal\nnewPayld.currentValue = calcVal\n\nmsg.topic = topic\nmsg.payload = newPayld\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":630,"y":240,"wires":[["ee37dbfb.f47708","26ad91b7.ae866e"]]},{"id":"e82be6d9.b86718","type":"switch","z":"7e71de96.77727","name":"SEND_EVENTS = true?","property":"SEND_EVENTS","propertyType":"env","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":390,"y":60,"wires":[["bc8384ad.287788"]]},{"id":"db3390b.b70b57","type":"rbe","z":"7e71de96.77727","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload.value","x":1550,"y":320,"wires":[[]]},{"id":"26ad91b7.ae866e","type":"function","z":"7e71de96.77727","name":"set status payload","func":"/*\n\n{\n\"fill\": (payload.value = \"on\" ? \"green\" : (payload.value = \"off\" ? \"blue\" : \"black\")),\n\"shape\":\"dot\",\n\"text\":'Status: \"' & payload.value & '\"'\n}\n\n*/\n\n\nvar devType = env.get(\"TYPE\");\nvar actions = env.get(\"ACTIONS\").split(\"/\");\n\nvar payload = {\n\"fill\": (msg.payload.value === actions[0] ? \"green\" : (msg.payload.value === actions[1] ? \"blue\" : \"black\")),\n\"shape\":\"dot\",\n\"text\":'Status: \"' + msg.payload.value + '\"'\n};\n\nmsg.payload = payload;\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":910,"y":360,"wires":[[]]},{"id":"ee37dbfb.f47708","type":"switch","z":"7e71de96.77727","name":"actiontype = passthrough/event","property":"actiontype","propertyType":"msg","rules":[{"t":"eq","v":"passthrough","vt":"str"},{"t":"eq","v":"event","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":950,"y":240,"wires":[[],["7aa39d92.51b7d4"]]},{"id":"2feace6b.d14dc2","type":"change","z":"7e71de96.77727","name":"override = true","rules":[{"t":"set","p":"override","pt":"flow","to":"true","tot":"bool"},{"t":"set","p":"actiontype","pt":"msg","to":"passthrough","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":120,"wires":[["81abc8d5.998a58"]]},{"id":"bc8384ad.287788","type":"change","z":"7e71de96.77727","name":"override = false","rules":[{"t":"set","p":"override","pt":"flow","to":"false","tot":"bool"},{"t":"set","p":"actiontype","pt":"msg","to":"event","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":60,"wires":[["bbe4a1b7.76f8e"]]},{"id":"ff11f9ac.a1dc08","type":"subflow:52da5ceb.f5efa4","z":"7e71de96.77727","name":"","env":[],"x":120,"y":60,"wires":[["e82be6d9.b86718"]]},{"id":"836e4fce.3b2e","type":"subflow:9e28a145.80b4c","z":"7e71de96.77727","name":"","env":[],"x":640,"y":180,"wires":[["b6398b5.f1c4978"]]},{"id":"bbe4a1b7.76f8e","type":"function","z":"7e71de96.77727","name":"does event match specified deviceId?","func":"// walk thru device list and set commands\nvar topic = env.get(\"TOPIC\");\nvar devList = env.get(\"DEVICES\");\nvar isString;\nvar device;\nvar retMsg;\n\n//node.warn(\"Checking...\");\n//node.warn(devList);\n\nif (typeof devList === \"string\") {\n device = msg.hub + \"/\" + msg.payload.deviceId;\n if ( devList.includes(device)) {\n retMsg = msg;\n //node.warn(\"String ID = \" + device);\n }\n \n} else {\n if (devList.find( device => { return device.hub === msg.hub && device.deviceId === msg.payload.deviceId })) {\n //node.warn(\"Found match in JSON object.\");\n retMsg = msg; \n } else {\n //node.warn(\"Not Found!.\");\n //node.warn(devList);\n //node.warn(msg.payload);\n }\n}\n\nreturn retMsg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":970,"y":60,"wires":[["81abc8d5.998a58"]]},{"id":"f352de63.ef662","type":"inject","z":"7e71de96.77727","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":90,"y":180,"wires":[["adc8b319.affa5"]]},{"id":"fb041b21.135ec8","type":"no-op","z":"7e71de96.77727","name":"","x":1430,"y":120,"wires":[["836e4fce.3b2e"]]},{"id":"1c902085.1cf74f","type":"delay","z":"7e71de96.77727","name":"","pauseType":"delay","timeout":"50","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"50","randomLast":"100","randomUnits":"milliseconds","drop":false,"x":1230,"y":120,"wires":[["fb041b21.135ec8"]]},{"id":"adc8b319.affa5","type":"change","z":"7e71de96.77727","name":"override = init","rules":[{"t":"set","p":"override","pt":"flow","to":"false","tot":"bool"},{"t":"set","p":"actiontype","pt":"msg","to":"init","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":180,"wires":[["81abc8d5.998a58"]]},{"id":"7aa39d92.51b7d4","type":"switch","z":"7e71de96.77727","name":"Return All Msgs?","property":"RETURN_ALL_MSGS","propertyType":"env","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":910,"y":300,"wires":[["497e1185.1ce5b"],["78629b73.6f3d74"]]},{"id":"78629b73.6f3d74","type":"switch","z":"7e71de96.77727","name":"value != pending and != undefined","property":"true","propertyType":"jsonata","rules":[{"t":"eq","v":"payload.value != \"pending\" and payload.value != \"undefined\"","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":1,"x":1320,"y":320,"wires":[["db3390b.b70b57"]]},{"id":"497e1185.1ce5b","type":"change","z":"7e71de96.77727","name":"set payload.value to activevalue","rules":[{"t":"set","p":"payload.value","pt":"msg","to":"activevalue","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1310,"y":280,"wires":[[]]},{"id":"29102dd4.c88fb2","type":"debug","z":"af91369d.586338","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":320,"wires":[]},{"id":"9b30373e.7864f8","type":"inject","z":"af91369d.586338","name":"On","props":[{"p":"command","v":"on","vt":"str"},{"p":"deviceId","v":"[{\"hub\":\"OLDZIGB\",\"deviceId\":\"1773\",\"desc\":\"Office Left Light\"},{\"hub\":\"OLDZIGB\",\"deviceId\":\"1774\",\"desc\":\"Office Right Light\"}]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"str","x":110,"y":300,"wires":[["f1c84278.5de4b"]]},{"id":"33147b0b.f47114","type":"inject","z":"af91369d.586338","name":"Off","props":[{"p":"command","v":"off","vt":"str"},{"p":"deviceId","v":"[ \t{ \t\t\"hub\":\"OLDZIGB\", \t\t\"deviceId\":\"1773\", \t\t\"desc\":\"Office Left Light\" \t}, \t\t{ \t\t\"hub\":\"OLDZIGB\", \t\t\"deviceId\":\"1774\", \t\t\"desc\":\"Office Right Light\" \t} ]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":110,"y":340,"wires":[["f1c84278.5de4b"]]},{"id":"520a03bd.66998c","type":"debug","z":"af91369d.586338","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":260,"wires":[]},{"id":"220cdb4f.808114","type":"subflow:7e71de96.77727","z":"af91369d.586338","name":"","env":[{"name":"TOPIC","value":"OfficeLights","type":"str"},{"name":"DEVICES","value":"OLDZIGB/1773,OLDZIGB/1774","type":"str"},{"name":"SEND_EVENTS","value":"false","type":"bool"}],"x":380,"y":260,"wires":[["520a03bd.66998c"],[]]},{"id":"f1c84278.5de4b","type":"subflow:5f0d4ee4.54595","z":"af91369d.586338","name":"","env":[{"name":"TOPIC","value":"OfficeLights","type":"str"}],"x":390,"y":320,"wires":[["29102dd4.c88fb2"]]},{"id":"70412c3c.829824","type":"debug","z":"af91369d.586338","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":670,"y":380,"wires":[]},{"id":"dff81a81.d917c8","type":"subflow:7e71de96.77727","z":"af91369d.586338","name":"","env":[{"name":"TOPIC","value":"OfficeLights","type":"str"},{"name":"DEVICES","value":"[{\"hub\":\"OLDZIGB\",\"deviceId\":\"1773\",\"desc\":\"Office Left Light\"},{\"hub\":\"OLDZIGB\",\"deviceId\":\"1774\",\"desc\":\"Office Right Light\"}]","type":"json"},{"name":"ALL_ACTION1","value":"false","type":"bool"}],"x":380,"y":380,"wires":[["70412c3c.829824"],[]]},{"id":"2d55ccab.9fa964","type":"inject","z":"af91369d.586338","name":"nothing","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"nothing","payloadType":"str","x":110,"y":260,"wires":[["220cdb4f.808114"]]},{"id":"e3571bb5.35b4c8","type":"comment","z":"af91369d.586338","name":"Group Tests","info":"","x":120,"y":220,"wires":[]}]
