No cloud dashboards
Selecting a hub that's not on my local network. Go to the dashboard tab at the bottom. Instant error:
  • This hub doesn't have any dashboards created.
  • I have remote admin and can access the hub remotely thru the other app.
  • Android on an S21+
  • Hub is a C7 running 2.3.9.136.
For a specific problem report like this, it's best to start a new topic in the appropriate category...this is more a general discussion topic.
Take a quick look in the Mobile Apps/Android to see if anyone else has posted w/your same issue , and if not, create a new topic there.
FWIW, I can use the new mobile app to access and control my devices via the Devices and Dashboards tabs when I'm on mobile data (Wi-Fi off)...
But please start a topic in the correct mobile apps forum I linked to above for the best help and so the HE mobile developer will be most likely to see/track your post. Thanks! :slight_smile:
Perhaps a moderator can move the post over. Honestly I don't use dashboards anyway so it won't affect me either way. I was just trying to share a result the easiest way possible.
I too can't access dashboards when outside my home network in the new app. Seems only local dashboards.
Same issue here when away from local network, Webpage not found
Pixel 7A Android 14 AP2A.240605.024
app v2.0 (234)
Hub C-4 2.3.9.157
Im getting the same error in regards to dashboard
I posted on hubitat android app page
@flanier
@bobbyD
AFAIK known issue, being worked on.
Seems my cloud dashboards on 5g are working in new app!?
