Newbie help with OWON THS317-ET multi-Sensor
Hi, new to Hubitat in the last 2 weeks, and have run into 1 issue which i'm struggling to resolve.
I have 3 x OWON THS317-ET Multi sensors with external probes, which I plan to use to measure the bath temps and swimming pool.
I went through the usual Zigbee pair process very easily, and configured them as
  1. Generic Zigbee Temp and Humidity sensors
  2. Set the interval to 10 mins
  3. pressed configure and refresh.
now 1 device is feeding data and shows the temp in the dashboard tile I created for it.
the other two do not, and have tried everything including hard resets for them both and reconnecting/setting
The image includes screenshots of the working device details page and the not working device details page, it just does not seem to be showing activity.
Hoping one of the community can point me in the right direction.
mike
Welcome to the community!
To post pics you need to go to Hub owners - Hubitat , join the group and then you'll be able to post lots of stuff. :grin:
Often with ZigBee devices it's helpful to run the pairing process a second time without actually deleting the device from Hubitat.
Just put both the device and the hub in pairing mode again and let the clock run down.
And also try changing the distance between the device and the hub, some need to be close.
After testing the "working" one in some hot water, it seems that's actually not updating temp based on the probe, but probably the main unit (room temp) as it didn't change temp reading, but it has been changing marginally (in line with room temp).
So i think this is likely needing a specific driver to ensure it uses the probe.
Really not sure where to go from here.
I will give the pairing a shot for the others but probably need to work out the right setup for the first one before i worry about the other two.
Can anyone suggest a solution?
Cheers
Not a solution, but start with a screenshot of the Data Details section (H in linked page) from your device detail page.
Or...
This driver is always worth a shot for those slightly strange temp sensors. :wink:
Paging @kkossev :slight_smile:
endpointld: 01
application: 04
inClusters: 0001,0020,0000,0003,0402
manufacturer: OWON
model: THS317-ET
outClusters: 0003
That all looks pretty normal... :thinking:
All three sensors are showing the same?
I added the driver you linked and here are the screenshots.
Its showing the stats in the tile but does not appear to be actually updating data. Its sat at 22.8C and 100% and does not change. (Same as it was doing with the generic driver).
Hi @Mikeyb , welcome to Hubitat community forum!
This device is rather not standard, that's why the existing drivers will not show any readings from it.
Please do the following :
  • Delete the device from its web page (the 'REMOVE DEVICE' red button at the bottom of the page).
  • Start the pairing procedure as a new Zigbee device.
  • When the device is found, Do not enter the device name immediately!. You will see a hyperlink or button labeled 'Device Info' or something like that. Click on it.
  • Copy and paste all the information in that popup window. It should be like this (link)
Based on this extended information available only during the pairing as a new device process, a modification of a custom driver will be needed to support it in Hubitat.
Thats super helpful.
Once done, how do i go about customizing the driver?
Thank you, what a super community.
This is what it shows "pairing info" link.
@Mikeyb it seems that there are two variants of this device that have different firmware and behave differently.. : (
Plese update the driver to version 1.3.8 2023/08/10 2:23 PM from this link.
Then click on the Initialize button, next press F5 to refresh the browser if on a PC.
The State Variables 'modelGroup' should now show 'OWON'.
If the temperature from the external probe is still not shown, I will need the debug logs that follow clicking on the Initialize button. Or even better, the debug logs that follow immediately the paring of the device to HE (just pair it again, no need to delete it before).
@kkossev I'm struggling to find out how to update using the link, could you outline the steps i need to take to update to 1.3.8 as your mentioned?
thanks
Mike
Look at the screenshot from in this post on using the Import button within Hubitat Driver Code editor.
@kkossev thank you so much, these are now working perfectly, reading the temp every 10 seconds from the probe, and showing battery life too.
Tile
HI,
Just got the device as well but having trouble initializing.
Followed the steps above with driver version ver. 1.3.10 2023-10-23 kkossev
After initialize & refresh it says:
Current States
  • _info : installed
State Variables
  • lastTx : {"cfgFailure":false,"cfgTimer":0,"humiCfg":"-1,-1,-1","humiCfgOK":false,"tempCfg":"-1,-1,-1","tempCfgOK":false}
  • modelGroup : OWON
  • lastRx : {"tempTime":1699634976560,"humiTime":1699634976560,"tempCfg":"-1,-1,-1","humiCfg":"-1,-1,-1"}
  • stats : {"date":"2023-11-10","rejoins":0,"rxCtr":0,"txCtr":7}
  • driverVersion : 1.3.10 2023/10/23 5:57 PM
  • notPresentCounter : 0
  • configState : 0
Shouldn't it list temp, hum, in the current States?
Log
ev:44392023-11-10 08:54:16.673trace00 owon sendZigbeeCommands(cmd=[he raw 0x42F3 1 0x01 0x0001 {10 00 00 21 00}, delay 200, he raw 0x42F3 1 0x01 0x0402 {10 00 00 00 00}, delay 200, he raw 0x42F3 1 0x01 0x0405 {10 00 00 00 00}, delay 200])
dev:44392023-11-10 08:54:06.189info00 owon Initialization finished version=1.3.10 (Timestamp: 2023/10/23 5:57 PM)
dev:44392023-11-10 08:54:06.186info00 owon manufacturer = OWON ModelGroup = OWON
dev:44392023-11-10 08:54:04.270trace00 owon sendZigbeeCommands(cmd=[zdo bind 0x42F3 0x01 0x01 0x0001 {3C6A2CFFFED3AC64} {}, delay 200, zdo bind 0x42F3 0x01 0x01 0x0402 {3C6A2CFFFED3AC64} {}, delay 200, zdo bind 0x42F3 0x03 0x01 0x0001 {3C6A2CFFFED3AC64} {}, delay 200, zdo bind 0x42F3 0x03 0x01 0x0402 {3C6A2CFFFED3AC64} {}, delay 200, zdo bind 0x42F3 0x01 0x01 0x0001 {3C6A2CFFFED3AC64} {}, delay 200, he cr 0x42F3 0x01 1 33 32 60 3600 {01} {}, delay 200, zdo bind 0x42F3 0x01 0x01 0x0402 {3C6A2CFFFED3AC64} {}, delay 200, he cr 0x42F3 0x01 1026 0 41 60 300 {3200} {}, delay 200, he raw 0x42F3 1 0x01 0x0001 {10 00 08 00 2100}, delay 250, he raw 0x42F3 1 0x01 0x0402 {10 00 08 00 0000}, delay 250])
dev:44392023-11-10 08:54:04.257info00 owon initializeDevice...
dev:44392023-11-10 08:54:04.254info00 owon Debug logging will be turned off after 24 hours
dev:44392023-11-10 08:54:04.218info00 owon Debug logging is true; Description text logging is true
dev:44392023-11-10 08:54:04.213info00 owon Updating 00 owon (Device) model THS317-ET manufacturer OWON modelGroupPreference = Auto detect (OWON)
dev:44392023-11-10 08:54:03.089trace00 owon sendZigbeeCommands(cmd=[he raw 0x42F3 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x42F3 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, zdo bind 0x42F3 0x01 0x01 0x0001 {3C6A2CFFFED3AC64} {}, delay 200, zdo bind 0x42F3 0x01 0x01 0x0402 {3C6A2CFFFED3AC64} {}, delay 200, zdo bind 0x42F3 0x03 0x01 0x0001 {3C6A2CFFFED3AC64} {}, delay 200, zdo bind 0x42F3 0x03 0x01 0x0402 {3C6A2CFFFED3AC64} {}, delay 200, zdo bind 0x42F3 0x01 0x01 0x0001 {3C6A2CFFFED3AC64} {}, delay 200, he cr 0x42F3 0x01 1 33 32 60 3600 {01} {}, delay 200, zdo bind 0x42F3 0x01 0x01 0x0402 {3C6A2CFFFED3AC64} {}, delay 200, he cr 0x42F3 0x01 1026 0 41 60 300 {3200} {}, delay 200, he raw 0x42F3 1 0x01 0x0001 {10 00 08 00 2100}, delay 250, he raw 0x42F3 1 0x01 0x0402 {10 00 08 00 0000}, delay 250])
dev:44392023-11-10 08:54:03.077info00 owon initializeDevice...
dev:44392023-11-10 08:54:03.065info00 owon configure()..
dev:44392023-11-10 08:54:02.955info00 owon Statistics were reset. Press F5 to refresh the device page
dev:44392023-11-10 08:54:02.952info00 owon InitializeVars()... fullInit = true
dev:44392023-11-10 08:54:02.942info00 owon installed()...
dev:44392023-11-10 08:54:02.837info00 owon Statistics were reset. Press F5 to refresh the device page
dev:44392023-11-10 08:54:02.832info00 owon InitializeVars()... fullInit = true
dev:44392023-11-10 08:54:02.799info00 owon Initialize()...
"rxCtr:0" means that nothing is received from this device - the pairing was unsuccessful.
Try pairing it again, very close to your hub (is it C-8 or other model?)
Also, press the F5 on the PC browser to refresh the State Variables when looking again at the stats - these are not refreshed automatically.
@kkossev
I have a couple of the Tuya Temp sensors that pair but I cannot seem to get any readings from. If you are willing and able, could you add them to the driver?
Manufacturer: _TZE204_yjjdcqsq
Endpoint 01 application: 49
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0004,0005,EF00,0000
Endpoint 01 initialized: true
Endpoint 01 manufacturer: _TZE204_yjjdcqsq
Endpoint 01 model: TS0601
Endpoint 01 outClusters: 0019,000A
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
Thank you!
Hi @clemsongt ,
Please first manually update the driver to ver. 1.6.3.
Then, obligatory - pair the sensor again to your hub (without deleting it).
If it still doesn't send T/H updates after the repairing - delete the device and pair it again as a new one, close to the hub.
