I also have mine connected to SmartThings (built in driver) and bridged to Hubitat through HubConnect. Works fine but is clearly suboptimal with cloud latency and you only can use them as buttons, not dimmers.
These are really nice buttons, super cheap but the metal gives a nice quality feel to them. Definitely a keeper despite Hubitat’s current non-support.
You cannot use them as dimmers in Smartthings either because they do not expose the "release" event. I don't know how they are doing it when directly connected to a bulb. In ST it only has pushed and held.
Thanks! mine is giving me some grief. Ive tried using the Ikea Button DH on smartthings with it through hubconnect also tried switching over the Smartthings DH to the hubconnect button and no luck. It wont show up in the select devices to sync menu under buttons. checked all the others as well. I can get it to show up if i make a custom handler but cant get the pushes to show in Hubitat going that route.
Yeah it's a shame these don't work. The build quality seem great - I really only want to use them as a button but I'm not going to get a Smarthings Hub to make that happen (Already have Hubitat, Hue, Ring and Wink hubs so it's getting ridiculous). I already have a couple of Smarthings buttons working with Hubitat so I'll just throw the Tradfri's in a drawer somewhere in case they work one day.
Bought one of these. I do like the traditional rocker design for sure. Anyway, while waiting for the day this may be supported I'm using zigbee2mqtt with a pi zero and a CC2351 stick (eventually to be rolled into my main pi).
Was there anything "tricky" you had to do to pair it? Or is it pretty much fully supported by Zigbee2mqtt? I'm planning to try this out, but I haven't got around to it, yet.
Only needed to press the button on the dimmer 4 times to initiate pairing, pretty painless. The only tricky bit was installing the right version of nodejs and npm as the pi is based off arm6 architecture.
Same here I have a bunch of these and my wife is lost without them. @mike.maxwell can you throw us a bone here regarding the future of ikea device support?
I second that I am in the process of moving from Smartthings to Hubitat. I have a lot of these Ikea remotes both types and the are a great low cost way to control groups of lights and scenes. Very disappointing that they don't work with Hubitat the same way they work with Smartthings. I hope someone can help figure out how to make them work.
Have you tried leaving them on ST Hub and sharing them thru HubConnect? I did that for some other remotes that used Inbound Group Messaging that HE doesn't support. Not ideal but keeps them from being paperweights. I have no idea what Inbound or Outbound Group Messaging means .
There is a HubConnect Button driver on the HubConnect website. I am pretty sure that is the one I used. I installed my remotes back in January so I am not 100% sure and I quit using them about 6 weeks ago.
I did it with remotes mentioned in this thread that have the same group messaging issue w/ HE:
If you go down to my post #241, there are people helping me get the remotes connected. However I don't know if the Tradfri is a completely different issue.
Is HubConnect on the ST not letting you select the Tradfri remote or is the Button Device not being created on your HE hub after selecting the remote on the ST side?
I don't believe that's the case. The new hub has had some obvious issues with the new ZWave chip so that has been their focus since coming out but that's only been there case since then. Once this major transition is settled, the company can focus on other things. It looks like you joined in August right in the middle of the ZWave storm so you haven't gotten an accurate view.
If can search for Release Notes of updates prior to the introduction of the C7 hub, I think you will see that the HE is not ZWave focused on its updates.
