New: Third Reality Power monitoring plug
FFS..., this device is hopeless...
I guess it makes sense, since it doesn't need a binding to report in the first place, makes sense that there's nothing to unbind...
I will send an email to the contact that I have that sends us the firmware updates and lodge my complaint (er.. feature request)...
And maybe point them at the Zigbee spec, which apparently they have never bothered to read.
while your at it if you could get them to fix the fw in this as well otherwise it is a nice product..
ie
its all the same "feature", ie no implementation of reporting configurations...
If you can get them to get freaking double-taps on their buttons to be consistent, I'll give you a dollar :laughing:.
Hope they look at this, most like their product(s), but if there is no support then...I got 16 days left to return, lol.
Those should go on the "do not use with hubitat" list. That's crap,
EDIT: Ok, to be fair, this is something that could be fixed with new firmware. I guess we should give them a chance to say if they will fix it or not. And I do say "fix", as that is broken - not a "feature".
yeah, kind of where I'm headed with these guys, i certainly intend to play that card...
The fellow that sends me the firmware updates does post here from time to time.
FWIW, @ThirdReality - I recently needed a couple power reporting plugs. Wanted to get ThirdReality. Saw this topic, got a two-pack of Sengled power-reporting plugs instead.
It will be a crying shame if they dont help out. This thread clearly shows there is interest in their products. I hope they come through because at battery change time this spring I was planning on replacing all my battery sensors left in my house with theirs because of the AAA batteries.
Agreed.
I like their offerings. But as much as I like the features/price point, it doesn't make any difference if they don't work well / cause other issues.
For those who do not need the power monitoring feature, I see that Amazon has the Third Reality Gen1 plugs back in stock. For a while, they only had the Gen 2 plugs available. The Gen 1 plugs work well without the added traffic on the mesh. The Gen1 plugs are also cheaper.
https://www.amazon.com/THIRDREALITY-Zigbee-Function-Certified-Required/dp/B09KNDM4VV/
Thanks! I also saw that a few days ago and snapped up the gen1 plugs.
I’m glad I revived this thread and asked about how chatty the gen2 plugs are. No way I’m touching those unless there is a confirmed firmware update that makes them function in a way that ‘the elders’ (using that term with due respect, and not an age reference) deem proper.
be sure to put labels on em! A year from now, I'll forget there was a difference and stumble into this again lol
Yeah! I did purchase 4 of the power monitoring plugs as I occasionally want to check power draw. For most applications, the Gen1 plugs without power monitoring are adequate. There are a few smart plugs I use for their switching capability, but many I just use as repeaters. The Third Reality Gen 1 plugs are great repeaters. At the low price, you can get several.
I was playing with Wireshark as I learn how to really use its capabilities for Zigbee sniffing and thought I'd see just how much of my Zigbee traffic is the electrical monitoring traffic from my 4 Third Reality power monitoring plugs:
Top line is total Zigbee packets, bottom line is traffic excluding the Metering and Measurement clusters. This tells me I really do NOT want to add any more of these to my network :frowning:
Now i want to see what other monitoring plugs are doing. I use Iris v1 plugs and was told to use them sparingly.
Yeah... That's the reason I only have Wi-Fi power mongering plugs. Of course I have to integrate them through home assistant or node red, and then back into hubitat, but I don't have to worry about update rates in any practical way.
My unifi APs can handle quite a lot of traffic and clients.
You have to do that with a Kasa?
Good point. I'm sure there are some that natively integrate with hubitat.
I'm not using kasa right now, I think mine are sonoff s31s - which may also be able to integrate locally to hubitat, I'm not sure.
I tend to not put lan integrations on my hubitat to avoid loading issues.
My home assistant and node-red containers have much higher spec hardware, so they're a better place for lan integration that could be chatty in my opinion.
