I plumbed back through the logs and did find an error coming from the Inovelli driver:
2020-07-27 05:12:02.384 pm errorgroovy.lang.MissingMethodException: No signature of method: user_driver_InovelliUSA_Inovelli_Dimmer_Red_Series_LZW31_SN_359.componentStartLevelChange() is applicable for argument types: (com.hubitat.app.DeviceWrapper, java.lang.String) values: [Office Main Dimmer (LED Color), up] (componentStartLevelChange)
I took a look at my log throughout the entire day (on All), and didn't see any of the errors like what you have. Just the errors I have been posting on this thread.
I was really hoping inovelli had their older drivers cached away somewhere so I could try those. It seems that the dimmer ones are fairly recent. Maybe it is an issue with the inovelli drivers.
Brand new C7. I'm trying to move over a few of my inovelli. I've tried dimmers and switches.
NO LUCK.
I get get it to exclude on both the old and new hub but can't get it to get past the initialization on the new hub.
The switches and hub are in the same room.
I get a prompt for security and deselect all just to try and make it easy.
i then get a prompt to fill in a key and its already populated so I just click ok.
I was able to add my two door locks that are in another room very easily. I was actually shocked at how easy they were because they were problematic on the C4.
Going to have to track the previous versions down... Although, I wonder if changing the device drivers will mess up everything I have got to work so far.
I spent today trying to add my LZW31-SN both with and without the Inovelli driver installed and it didn't seem to make any difference. The one time (of dozens) I actually got it to pair, I tried it assigned to both the default driver and the Inovelli driver and it didn't respond to commands under either of them.
Ok.. As of right now.. We are able to re-produce.. And until we have a fix there is a work-around...
try to include the device with security unchecked
When it gets stuck on initializing, do a safe shutdown. (settings -> shutdown)
Unplug and re-plug the hub when it gets to the red light
After logging back into the hub go back to z-wave discovery and triple click the button on the device again (donโt exclude we just want to finish discovery as itโs already included)
As of right now it seems to be limited to some inovelli dimmers.. Please let me know if any other devices are having similar issues..
This did not work for me. The dimmer times out trying to get included, and the inclusion mode times out on the hub with no new devices discovered. Still nothing in the Devices list, but I can see the anonymous node in the Z-Wave Radio Devices list.
Update to my situation. I was finally able to pair the last 2 switches I needed. Just kept excluding and including them over and over and over again. I did play around with the amount of time I waited to put the switch into pairing mode. I seemed to have more success when I took it slow (I acted like I was reading the words on the screen that I have seen many times prior, before clicking checkboxes, etc).
What's the definition of insanity they say..... exactly!
The hub is maybe 8 feet from the initial switch (where it was when I tried the very first time). Doesn't seem to be any rhyme or reason (at least to me) on why it failed so many times before and it just all of a sudden worked now. If it was a range issue, you would think that it would only work when it was moved closer to the switch, but I tested that and it wasn't the case.
5 out of 6 switches I unchecked all securities. Only 1 switch I kept it default.
