How many platforms do you have configured in your config.json. It looks like that you have a duplicate device id.
I have two platforms in the config.json file . This one and one for Smartthings. But I even tried removing smartthing from the config file I'm still getting the same error
Homebridge does create a cache file that sometimes gave me issues.
You can try to stop homebridge, remove the file ~/.homebridge/accessories/cachedAccessories and start homebridge again. Just as a note though, this will most-likely mess with your room assignments if you have any
I tried removing the cache file but for some reason I still can't get it to work maybe I missed something. I didn't even get to set it up in Home app yet so I don't have any rooms at the moment. Maybe I will try to start from scratch again and see how it goes.
besides .homebridge folder, the other homebrige folder and the plugin folder are there any other files I need to remove to make sure I'm starting over clean?
Dan,
I have one of the GE Smart Fan Controls as well. As of this writing, the fan only shows up as an on/off switchâno fan speed control. Here's my device's info from the Maker API:
"id": "130",
"name": "GE Smart Fan Control",
"label": "Ceiling Fan",
"attributes": [
"name": "level",
"currentValue": 32,
"dataType": "NUMBER"
"name": "switch",
"currentValue": "on",
"dataType": "ENUM",
"values": [
"on",
"off"
"capabilities": [
"Switch",
"attributes": [
"name": "switch",
"dataType": null
"Configuration",
"SwitchLevel",
"attributes": [
"name": "level",
"dataType": null
"Refresh",
"Actuator"
"commands": [
"configure",
"off",
"on",
"refresh",
"setLevel"
level
needs to map to the HomeKit Characteristic RotationSpeed
. The range for level
is 0-255
, while RotationSpeed
needs to be 0-100
Thanks for your all your work!
Andrew
Hey Andrew,
Can you make sure that you are on the latest version of the plugin? This one should be displayed as a Fan Controller in the latest version.
Updating the plugin is as easy as the installation, just run
npm -g install homebridge-hubitat-makerapi
Dan,
I had version 0.1.10 according to NPM, and it just upgraded to 0.1.12. No change in the fan, but I need to clarify something: It does show up as a fan controller (the Home UI's tile shows the fan icon). The problem is that when pressing in to the tile, there's only an on/off control instead of a slider:
I believe this happens when the RotationSpeed
Characteristic is not added to the Fan
Service. (I designed a Homebridge plugin once upon a time.)
Andrew
Hey Andrew,
I uploaded a new plugin for you. It has a workaround in there to allow you to set the speed. The problem with that driver is that it really doesn't present itself as a fan, it really just looks like dimmer.... Technically, a fan should have the attribute speed and not level. I still have hope that this will be cleaned up on the driver side at some point.
Give it a try and let me know how it works
I just installed 4 Hampton Bay Zigbee Fan Controllers and decided to go all-in on fanControl vs Dimmer (setLevel).
I am using the OTHER version of Homebridge though, the HubConnect version. My fans all show up with the fan icon and a slider. Looking at settings, there's no option to change to Fan like there is with a switch.
For me, the 4 fan controllers are attached to one of my Hubs (that has the only enabled Zigbee radio) and then to my 'coordinator' and out again to Homebridge (as a HubConnect Remote.)
The differences in the two implementations may be the difference in our result, but I chose to speak up because fanControl is not exactly new, but maybe 'newly used' with several supported devices switching to this method. (FanControl has enumerated speeds, high, low, off... while SmartThings still uses fanSpeed and itâs numeric value.)
The case is a bit different here. Your Hampton Bay Fan controllers have the attribute "speed", the GE Smart Fan Control only has level. You would have gotten the same result as Andrew with the "other" homebridge plugin.
Just FYI. My user driver for the GE Fan Control (zwave plus version only) has all of the expected speed settings/variables to support the Hubitat Dashboard fan template, and presumably other dashboard fan templates - although I only tested it on the Hubitat dashboard.
I don't use homebridge so have no comment on anything there.
Dan,
Thanks! NPM pulled down 0.1.13. No change in how the fan shows up (yes, I restarted Homebridge). Perhaps I need to remove the device from the Maker API and then add it back. I will try that after work today.
Jason,
I'd give that a try. Where could I find your code?
Hmmmm, those damn fans.......
Do me a favor when you have a moment, go to your MakerAPI instance and follow the linke "Get All Devices with Full Details" and get me the entry fior your fan. (BTW, it is different than requesting it only for that particular device). I have a mockup software that I can use to replicate your issue with that JSON output.
Here:
"type": "GE Smart Fan Control",
"id": "130",
"date": "2019-04-29T18:43:20+0000",
"model": null,
"manufacturer": null,
"capabilities": [
"Switch",
"Configuration",
"SwitchLevel",
"Refresh",
"Actuator"
"attributes": {
"level": "32",
"dataType": "ENUM",
"values": [
"on",
"off"
"switch": "off"
"commands": [
"command": "configure"
"command": "off"
"command": "on"
"command": "refresh"
"command": "setLevel"
Thanks! I'll try it after work.
Hey @swiss6th,
just published a new version of the plugin to get you GE Fan Controls working (with the current driver). @JasonJoel 's driver is technically still the right choice as it actually implements the Fan Control capability as it should be. But you should be ok now.
Updated but now it doesnât control the fans at all. It will say on and off but they donât turn on.
What type of fan do you have?
