New Hubitat C7 user here... newbie to the C7 but not to Z-Wave, which I've used for years with Home-Assistant.
I've set up the C7 (ver 2.2.2.129) and started moving some ZWave devices across. I note these are all Australian Z-Wave devices on the AU frequency. All devices were working in a home mesh with Home Assistant previously (as in, until I excluded them / factory reset them).
First I moved three Aeotec Nano Dimmers ZW111 (with Wallswipe units) over. No issues connecting them, once I got the light configuration details input again.
At this point, I did shutdown the hub (to physical move it) and removed all my config and devices for no reason. Fortunately with only 3 devices, I simply re-did them. PITA but
Then I added a Fibaro FGS-212 (the 2.5kW switch) ... after swearing at it a lot to reset it ("hold B button for 3 sec just after but not while inserting the power, then release, then power cycle again" seem to do it in the end) I was able to add it fine. However it doesn't have a built-in driver, so I selected "Fibaro Switch" and it works fine. This is the most important device in the house... it lets me turn on the espresso machine from bed. Simply 'on/off' on dashboard is fine and seems to work.
Now... to the problem... I added an Aeotec Dual Nano Switch ZW132 and it didn't recognise the device. I selected it from the list and it added the 2 component devices. The problem is these do nothing - the on/off does not work.
I have excluded it (that works fine from the menu - no need to reset the device) and re-added it. Fails to work as a switch.
I have excluded it again, updated the firmware (using a Z-stick and Aeotec's software) just to make sure it was on the latest firmware... excluded from stick, re-added. It shows up on the C7 but I can't get current state or anything.
The Dual Nano Switch throws the following errors in the log when you press a button (change a light state):
groovy.lang.MissingMethodException: No signature of method: aeotecDualNano.parse() is applicable for argument types: (hubitat.zwave.commands.hailv1.Hail, java.lang.Short) values: [Hail(), 2]
Possible solutions: parse(java.lang.String), wait(), run(), run(), grep(), any() (parse)
(I spotted another user having a similar log event - First Device Fail - Switching from Indigo - #29 by mattias)
I then though "maybe it's me" (kinda like "it's always DNS...") and thought I'd try another device - the Aeotec Multisensor 6 - ZW100-B... no dice. It includes fine, can exclude again (and updated to v1.13 firmware) and re-included... but no temp/humidity/lux was showing... until over 45mins later when it finally updated! (USB-powered so should have updated more regularly!)
All devices are nearby (the switches within 3m of the C7, the multisensor about 1m away in the same room).
I have a Zniffer and sat there with my laptop, watching the traffic pass between the nodes... nothing I can see that is an issue... devices hail when something changes, etc. At this range all at 100kbps by the looks of things.
As a Hubitat newbie... any ideas what I can do to make the C7 work with the Dual Nano Switch?
For reference, my Z-Wave devices & details, as the details often matter!
Aeotec Nano Dimmer (ZW111 - AU version)
For reference:
- deviceType: 515
- zwaveSecurePairingComplete: true
- inClusters: 0x5E,0x86,0x72,0x5A,0x73,0x98,0x85,0x59,0x25,0x26,0x27,0x32,0x70,0x81,0x71,0x2C,0x2B,0x7A
- zwNodeInfo: D3 9C 80 04 11 01 5E 86 72 5A 73 98 85 5C 59 25 26 27 32 70 81 71 2C 2B 7A EF 82 68 23 F1 00 85 5C 59 25 26 27 32 70 73 81 71 2C 2B 7A 5A
- outClusters: 0x82
- secureInClusters: 0x85,0x59,0x25,0x26,0x27,0x32,0x70,0x73,0x81,0x71,0x2C,0x2B,0x7A,0x5A
- deviceId: 111
- S2: 128
- manufacturer: 134
Fibaro FGS-212 (AU version)
- deviceType: 1026
- inClusters: 0x72,0x86,0x70,0x85,0x8E,0x60,0x25,0x27,0x7A,0x73
- zwNodeInfo: 9C 00 04 10 01 72 86 70 85 5C 8E 60 25 27 7A 73 EF 25 60 68 23
- outClusters: 0x25,0x60
- deviceId: 12290
- manufacturer: 271
Aeotec Dual Nano Dimmer ZW132 (AU version)
- deviceType: 515
- inClusters: 0x5E,0x25,0x27,0x32,0x81,0x71,0x60,0x8E,0x2C,0x2B,0x70,0x86,0x72,0x73,0x85,0x59,0x98,0x7A,0x5A
- zwNodeInfo: 9C 80 04 10 01 5E 25 27 32 81 71 60 8E 2C 2B 70 86 72 73 85 5C 59 98 7A 5A EF 82 68 23 F1 00 86 72 25 27 32 81 71 60 8E 2C 2B 70 73 85 5C 59 7A
- outClusters: 0x82
- secureInClusters: 0x86,0x72,0x25,0x27,0x32,0x81,0x71,0x60,0x8E,0x2C,0x2B,0x70,0x73,0x85,0x59,0x7A
- deviceId: 132
- S2: 128
- manufacturer: 134
Aeotec Multisensor 6 - ZW100-B (AU version)
- deviceType: 514
- configured: true
- inClusters: 0x5E,0x98,0x84,0x5A
- zwNodeInfo: 9C 80 04 21 01 5E 98 84 5A EF 68 23 F1 00 5E 86 72 84 59 85 5C 73 71 80 30 31 70 98 7A
- secureInClusters: 0x5E,0x86,0x72,0x84,0x59,0x85,0x73,0x71,0x80,0x30,0x31,0x70,0x98,0x7A
- deviceId: 100
- S2: 128
- manufacturer: 134
