23 posts were split to a new topic: Request for Expanded Functionality in Room Lights
You kind of gave us a fix for this a while back by creating a contact motion app for us. I've been using it ever since.
The new Wiz integration added another possible value to colorMode - "Scene". So when setting up a RL instance Scene is a possible starting value. Unfortunately RL doesn't have Scene as a choice and so isn't able to set the Wiz scene. Is it possible to add the Wiz scenes to RL? If not, you may want to find a way to not show Scene as a starting point in the app.
How did you get to that? Was that from importing a Scene?
No, just setting up a new RL instance and choosing Wiz color bulbs that are currently running a scene. From one of the devices page:
OK, I will look into this.
Would you post a screenshot of the portion of Application State from App Status page that shows the capDevs
entry.
Never mind. This will take some sorting out, but needless to say that "Scene" is not a valid value in Room Lights for those devices, and they need to be set to RGB.
Thanks, I get that. But was hoping that you could add the scenes that are part of your new built-in Wiz driver to RL. It would make it a lot simpler to use RL to set Wiz scenes. Maybe you could be an official "works with" partner
I understand. Have to get it sorted out, as presently the Wiz driver isn't offering a command to set the Scene.
It's got the setScene command. My work around is to set up a virtual button device and a Button Controller app that uses custom commands that then get used in a Room Lighting app.
Your device screenshot above does not show that command. Where do you find it? I don't have any of these bulbs.
I see the command in the driver. I was thrown by your screenshot. Did you not show the whole thing?
Thanks. We will get it sorted out for the next release.
Question and possible enhancement request. Or maybe there's some other way to do this.
My bedroom lights. Ceiling lights are on a Jasco switch. Table lamps are Hue bulbs. Ceiling lights come on during the day. Lamps come on in the evening and asleep. All of this works fine.
This evening I needed a little extra light, so I turned on the ceiling lights. RL turned them off again. I notice in the Activate Options there's "don't activate if turned off manually."
I think what I need is "don't activate if turned on manually." Any chance of adding this?
There's no way to limit activation via a switch per mode. That also might work. But I don't want to limit activation during the day when I want the ceiling lights to come on.
This is what the Evening and Home (day) modes look like:
I will look at this. So, the problem is that RL is turning the light off, that you had turned on, right? At first blush it seems that "Don't turn off if turned on manually" should perhaps apply for a case where Activation means to turn off. Would that work for you?
This is similar to e problem another use had who wanted to be able to turn on a light that was turned off like yours is, and have it come on to preset levels. These are sort of thorny cases. They are understandable -- it's just not obvious (yet?) how best to deal with them.
Update: But, there's an inherent contradiction here. How is the app supposed to know when you want the light turned off, and when not to turn off. You've told it to turn if off. It can't read your mind.
It seems as though, just with the other request, this needs to be handled outside of Room Lights. For example, you could use RM for that one light. It has complex logic to determine what should be done with it. Room Lights doesn't really have that sort of logic.
Yes, that's the problem. I think that would work. In this case it appears to be the same as "don't activate if turned on manually."
I keep getting mixed up between "activate" and "turn on/off." I know that activate means the indicated state, and turned on/off means the light, but it still seems confusing to me in the lists of available options. Does "don't activate if turned off manually" mean "don't turn on if turned off manually"? It seems redundant if activation means the light is off.
See the update to my prior post. I don't think this is doable to get what you want in Room Lights.
What's the difference, then, between "don't activate if turned off manually" β which is available β and "don't activate if turned on manually"? Both, it seems to me, say to RL ignore the state if I override it manually.
And that's what I want. I want RL to automate the state as I've specified it, unless I override that state by doing the opposite manually.
What about changing "don't activate if turned off manually" to "don't activate if overridden manually" which would handle both?
I'm doing something very similar and glad I was able to find this post. A couple of comments:
- "Stays Off Pending" (as is the phrase in the current app) is not particularly descriptive IMO. I think something like "Off Timer Pending" or "Elapsed Time to Off Pending" is easier to tie to the "Elapsed time" selection for Means to Turn Off. Unless "Stays Off Pending" applies to other means?
- The combination of Means to Turn Off and Conditions to Limit Turning Off essentially turns the multiple means into an "All Off" condition for all the timers (similar to the All selection for motion and contact sensors). Which is exactly what I was looking for but was not able to easily figure out. I suggest this behavior/information to be added to the documentation, that I realize is a WIP.
All in all I'm very pleased with this app. This was the last of my lighting RM rules to port over to RL.
These options apply to the entire automation, while you want it to apply only to a single device. That's a problem. You don't want the automation NOT to activate at all, you only want it not to turn off that one device. As if you had an option (which there isn't) to 'Don't turn off devices upon Activation if already turned on'.
