Child:
V2.0.4 - 10/03/19 - LOTS of changes, added some rule machine options, lock codes can be used as presence sensors and name will be added to the announcement. Greetings have returned! Be sure to load up each child app and fill in the missing pieces!
Previous implementation would announce welcome and arrival and because the person also used the lock would announce them again because of the lock. Did I miss this configuration?
Nope, no need to select lock users, simply select the lock you want to keep track of. It will check who unlocked it (based on Lock Code Manager) and add the name to the arrival list. It will also remove any duplicates before making the announcement.
Is it based off the Presence Sensor name or the Friendly name? Just checking to see which names I need to keep in sync between Lock Code Manager, Presence and Home Tracker.
Under, Message Options, Departed Message Options, make sure the 'Closing message' is not blank. If you don't want to use it, simply put a '.' (period) in there.
I don't know if it's an error that happens just to me, but Hubitat doesn't allow me to save message settings because required fields (greeting messages) are missing, even if I have strings inside them..
Just noticed that you have released a combined version of Welcome Home and Departures and Arrivals which I love both of these. Is there an advantage to updating to this version?
According to the logs, it says that it spoke but I didn't hear anything. I am using echo dots. Do I have to select that they are a speaker proxy device? Also, I have them selected under Music Devices.
