Is there an easy way to do this with all of my devices , automations etc. or am I basically having to start from scratch by de pairing devices within ST and repairing them all within Hubitat and creating all automations again ?
I bought the Hubitat hub months ago and it’s still sitting in its wrapper due to how time consuming this will take.
There is a solution called HubConnect which will allow HE to use devices connected to an ST hub, but I'm pretty sure it relies on Groovy. As I understand, ST is removing support from the platform shortly. I don't know any other way of avoiding the arduous task you foresee. If you use webcore on ST it is also available on HE. That eased my transition, though eventually I moved away from webcore and tackled RM.
When you decide to take the plunge be sure and read these documents. Even though you have familiarity with zwave and zigbee networks coming from ST, it's worth the read.
Yeah that’s my main reason for moving. I’ll likely have a huge task dealing with ST transitioning over to edge so with that I may as well just move from Hubitat now and get tackled into it. I use web core for some automations but like you, If I move to everything to Hubitat I’ll probably just bite the bullet and start fresh. Be great if there was a magic tool that somehow moved everything across did all of this for me
It would be great indeed. But at least you didn't make the mistake I did. I jumped from Wink to ST and redid everything only to then abandon ST and start again for the third time.
Just confirming that statement. I do not recommend HubConnect for anyone at this point. ST will be starting the migration by the end of this month or beginning of September. This means devices will be switched to Edge Drivers from Device Handlers.
Slight correction - migration to Edge only occurs for those devices connected directly to the ST hub.
One thing you can do it prep is make sure all of your devices are compatible with HE, either natively or using a community-based driver. Chances are you'll be fine. The only thing that caught me was my Lutron Caseta switches, which on HE require the PRO version of the Lutron hub.
I jumped over from ST a couple years ago -- welcome to HE!
First researching your existing device compatibility is a good idea -- that gives you the luxury of time to address any compatibility issues instead of discovering it mid-implementation and forcing yourself into a hurried fix. Then read the recommended stuff about building solid ZW and ZB meshes.
Setting up & managing ZW devices on HE tends to be more finicky / less-forgiving compared to ST -- the "why" a long story, but in terms of prepping your conversion gameplan ahead of time, pay particular attention to z-wave related best-practices. That planning & prep helped me a lot, and I didn't have any issues bringing my stuff over.
I know it seems daunting to do a whole "do-over" as part of any conversion, but it's also a good opportunity to optimize things from the ground up -- after all, you're smarter on this stuff now than when you first started -- take advantage of that
I one thing I would add is don't be afraid to use Smartthings as a cloud integrator. There are two great ways for bringing things in from Smartthings into HE that use the new Smartthings API. I use HE as my primary HA system, but do lean on Smartthings mainly for cloud integrations that just exist in HE.
A always on PC(even a raspberry pi will work) with Node-Red using the Hubitat and Smartthings Automation Studio Pallets. This combination if setup properly can event use event triggers from Smartthings to get near instant notification of events and not use polling. Here is the thread I created discussing this method. Node Red with Smarthings using Samsung Automation Studio - Get Help / Integrations - Hubitat
I have Node-Red with the suggested pallets above setup to manage integration with Arlo Cameras as my example. I wouldn't do this for anything that can integrate directly with HE, but it is a decent solution for things that aren't supported in HE but work in Smartthings.
One last question folks. Now I know ( think ) everything runs local on Hubitat? Is that true?
Does this even include community made drivers for devices that are not natively supported by Hubitat?
And if everything runs local, does that mean that if anything were to happen to Hubitat ( an outage there end, or worst case, they close shop) everything would still run in my home?
Community-made drivers for zigbee/z-wave devices run locally on the hub. Community-made drivers for locally-controlled WiFi devices are also not internet dependent. Community-made drivers for cloud-connected devices are cloud dependent.
Cloud integrations would stop working (eg. built-in integrations for Alexa, GH, ecobee). However, everything else would remain working as it was before.
I think there may need to be a distinction made to about services that use Hubitat's cloud to interface with external cloud tools vs cloud connections between the hub and lets say Govee's cloud. I think there is even a community google home integration that i wonder if it would work if hubitats systems were down.
So given that I have all of my devices currently on ST. Before I go through the tedious job of unpairing everything , is there a way to go through Hubitat and start making my rules and automations without pairing them just now, leaving them on ST so things still work just now, whilst I make all of my automations on Hubitat? I suspect the answer is no but I part of me hopes I could set them all up prior and them just go back into them once paired to Hubitat and insert devices into the rules.
You can create virtual devices and create rules using those devices. Then, after resetting the actual devices and pairing them to Hubitat, you can swap them with the virtual ones.
