This series of drivers uses the SmartThings Cloud to control the referenced Samsung Appliance. It does not require a SmartThings Hub, but does require a SmartThings account as well as access to the SmartThings app on you phone. There are some special installation instructions contained in the references below.
Current Version is B0.1. I anticipate that there may be some issues as well as some enhancement requirements. Private Message me with issue descriptions as well as the text-version, log data showing the error. It is best if you set debug logging before capturing any errors.
Installation Instructions: HubitatActive/Install_Samsung_Appliance.pdf at master · DaveGut/HubitatActive (github.com)
HVAC (air conditioner): https://raw.githubusercontent.com/DaveGut/HubitatActive/master/SamsungAppliances/Samsung_HVAC.groovy
Oven Requires all of the below drivers (parent and two children):
- https://raw.githubusercontent.com/DaveGut/HubitatActive/master/SamsungAppliances/Samsung_Oven.groovy
- https://raw.githubusercontent.com/DaveGut/HubitatActive/master/SamsungAppliances/Samsung_Oven_cavity.groovy
- https://raw.githubusercontent.com/DaveGut/HubitatActive/master/SamsungAppliances/Samsung_Oven_probe.groovy
Refrigerator requires all of the below (parent and three children):
- https://raw.githubusercontent.com/DaveGut/HubitatActive/master/SamsungAppliances/Samsung_Refrig.groovy
- https://raw.githubusercontent.com/DaveGut/HubitatActive/master/SamsungAppliances/Samsung_Refrig_cavity.groovy
- https://raw.githubusercontent.com/DaveGut/HubitatActive/master/SamsungAppliances/Samsung_Refrig_cvroom.groovy
- https://raw.githubusercontent.com/DaveGut/HubitatActive/master/SamsungAppliances/Samsung_Refrig_icemaker.groovy
