Hi All. I'm trying to get all of the "Current States" to show up in my dashboard as a tile but can only select one attribute. Does anyone have any suggestions on how I can add this?
Thanks for the help!
There are a couple of community apps/driver that can create multi-attribute tile data. I don't really use any of them so not sure which one is best at the moment. I think there is one more that I may be missing as well.
*** BPTWorld apps are no longer being developed or maintained. Thanks ***
Introducing 'Tile Master'
Display multiple devices that can be Controlled from the tile!
Features:
Each Tile can have up to 9 lines (remember, we are still limited to 1024 characters)
Ability to copy one line to another for faster setup
Each line features up to 3 sections
Choose width of each section per line
Display a different device in each section
Devices can be CONTROLLED from within the tile. Game changer!
Each …
Have a look at Tile Builder Multi Attribute Monitor. It does everything you are asking for and a whole lot more. Also, it’s very easy to use.
This is the module you need for your scenario.
Some of you will already be familiar with Tile Builder which allows you to create tables of data for publication to a dashboard. The existing Attribute Monitor module allows you to specify an attribute you are interested in and generate a table of devices from that with a great deal of formatting. Multi Attribute Monitor allows to mix and match any combination of devices and attributes that you might be interested collating in a unified way.
Here is one for monitoring rainfall and weather from…
Yes I knew I was missing a newer one. I would probably start with this one:
Tile Builder is a novel way of presenting data on a Hubitat® Dashboard. Rather than each tile being a single unique device, Tile Builder allows data from multiple devices to be presented on the same tile in a variety of formats.
Tile Builder has five child apps for creating different kinds of tiles.
1) Attribute Monitor tiles contain any number of devices for a single attribute. In the following case it's temperature. The table can be sorted by the device name or the attribute value (text or n…
Thanks!!! I will give this a shot today.
