Minoston power meter reporting in Dashboard
Hi All. I'm trying to get all of the "Current States" to show up in my dashboard as a tile but can only select one attribute. Does anyone have any suggestions on how I can add this?
Thanks for the help!
There are a couple of community apps/driver that can create multi-attribute tile data. I don't really use any of them so not sure which one is best at the moment. I think there is one more that I may be missing as well.
Have a look at Tile Builder Multi Attribute Monitor. It does everything you are asking for and a whole lot more. Also, it’s very easy to use.
This is the module you need for your scenario.
Yes I knew I was missing a newer one. I would probably start with this one:
Thanks!!! I will give this a shot today.
