I've been having trouble syncing my devices with Hubitat and Google Home lately. When I try to give Home oath access to my Hubitat (C5) I get an error message: "The parameter "state" must be set in the query string."
Seems to only be a problem with my C5. My C8 and C7 sync just fine.
Any ideas?
***Edit: changed the title of this thread to reflect the bigger project at hand.
Making kinda sorta progress maybe. I noticed the C5 had no cloud connection but I was able to access via 8081 and update to the latest version. Now I have connection and I'm able to start the process and select devices, until it gives me this error:
I really have no idea what to do here. I am about to give up and just move everything to the C8 and sell the C5...
Edit: It may have something to do with the fact that there are no devices actually on this C5. All the devices are hubmeshed. The Z-Wave and Zigbee radios are disabled.
If you search the forum here for The parameter "state" must be set in the query string, you'll get some corresponding hits to review for solution ideas.
I've been reading and jumped through most of the hoops. But now's the time to simplify - I've been waiting to rebuild a 1-hub system instead of hubmeshing 3 hubs and juggling issues like this. So that's the plan tonight.
I love tinkering but time is less available these days for troubleshooting, so I think the sooner I get everything on a single C8 the better.
Add the Google Home app in the HE apps manually first. Can you select any devices in there? Its possible Hub Meshed devices are excluded from sharing (should be shared from the hub they are on instead).
The error you are getting I think is what happens when you have no devices selected in the app on the HE side to share and then GH bombs out with an error.
Some of the trouble is that HE has recently removed the ability to manually install the Google Home app. It's no longer in the app list. It can only be added via the official Google Home app during the authorization process. After that, the app appears in HE.
Buuuuut in my case it doesn't link anything. This all started a few months ago. My suspicion is hubmesh.
Add a virtual switch to the hub, then when you go to setup GH you can authorize that single virtual switch to get it started. Then you can at least get the app installed and see what other devices you can select.
I'm already several steps into migrating everything into a single C8. The old situation was Upstairs devices on the C8, downstairs devices on a C7, and a separate C5 doing 'whole house' apps on the meshed devices.
Today I've spent a few hours excluding all of the Downstairs devices from the C7, with no issues. The house is only 50% functional now.
I have moved almost all of the wired repeaters onto the C8 but somewhere along the line I acquired 3 ghost devices and now I can no longer include any new Z-Wave devices. Something is hanging it up "Z-Wave network is busy". I can't add a USB-Z stick either, using Simplicity Studio, to get rid of them. Cannot remove them via Z-Wave Settings either.
So I'm afraid I need to open a support ticket. @bobbyD can you take a look?
(The plan is to see how it performs as a single hub, and if it chokes, to easily migrate to a C8 Pro)
Just take it slow, and start w/the instructions for using the hub's built-in ghost removal devices.
Bobby won't be able to help you much - he can't reach out and remove your ghosts, unfortunately.
Take screen shots of your Z-Wave Details page and post them here. As you note, you will need to remove any ghosts you've created before you can proceed.
Oh yes, I have definitely been shutting down and unplugging.
Maybe I got lucky but I seem to remember ghosts did not wreak so much havoc on the older models... They existed and I occasionally had them, but they didn't bring my mesh to its knees like I've experienced with C7 and C8.
This morning I managed to remove 2 out of 3 by guessing what they were and excluding and re-including their respective real-world devices again. After that, I was able to do Refresh-->Remove on their former ghostly selves. I believe I was having so many issues last night because I was moving too fast (had the hub on an extension and long ethernet cable moving around the house) and it just didn't have time to settle and build any manageable topology.
I've got 1 last pesky ghost left haunting this house:
I'm almost certain it's a Ring Alarm Range Extender (gen2), so when I get home tonight I'll target that one and hopefully we'll be back on track!
I'm going to return the hub to its "forever spot" while I'm at work and let it settle, since all the remaining devices are either battery powered, or moveable plugs. And then as @rlithgow1 wisely suggests going forward, as soon as the next ghost appears, to STOP and get rid of it before proceeding!
Should be no issues with connecting to that router with the ethernet backhaul, its just acting like a network switch if the hub is connected via ethernet.
I didn't even notice the new "Restore Apps" and "Swap Apps Device" options until too late. Boy that would've been helpful!! Luckily my "controller" hub was still full of all the Offline meshed devices, so those rules stayed more or less intact and I was able to import them with minor corrections. I did take a screenshot beforehand of every single app too.
Thanks Hubitat. I'll see how this performs for a bit and may or may not need the Pro, but it's good to know future upgrades will be quick and painless. Oh, and I'm a new Hub Protect subscriber now, so I can sleep soundly. <3
