I finally finished installing the last of my z-wave plus switches (GE Enbrighten). And now I am noticing more than half of my switches are not updating in hubitat. If they are off I can turn them on from the dashboard or the device page, but hubitat still shows as off until I manually refresh it. (Same for devices which are off).
I have done the following:
Z-Wave repair (showed about a 3rd of my devices failed)
Shut down and unplugged the hub for about 5 minutes.
Removed all Apps which could be causing any lag at all, I am down to very minor automations.
I'm kind of seeing the opposite..
So I have had recent trouble with devices not firing on physical events, particularly my older Zooz switches. It's weird and seems to be at the device level not HE. Also the Ilumin bulbs in our master bedroom sconces have been randomly unresponsive as well. With this last upgrade and a little tweaking things actually seem to be a little better.
edit: the Zooz issue is likely separate and still a problem but the mesh overall seems okay.. still watching it carefully though.
Old models - "Generic Z-wave Smart Dimmer"
New models - "GE Enbrighten Z-Wave Smart Dimmer"
(obviously substitute SWITCH for DIMMER in the driver name if it is a switch and not a dimmer)
The drivers are not interchangeable, and do not work 100% right when applied to the wrong model.
Now, this may not even be your problem, but it is a good place to start as you need the right drivers on the right devices anyway long term.
Would having the wrong driver's effect the hops? Because to test I took one switch which isn't refreshing and used both drivers (+configure) and it doesn't fix it
Okay I do have some good news. My dimmers appear to be working again. I tried the Embrighten Dimmer and the Generic Z-Wave plus Dimmer and neither worked. But "Generic Z-Wave Smart Dimmer" does work!
I'll just have to go one by one and try different drivers.
The Hub will recognize the device fingerprint and pick the Enbrighten drivers...if it doesn't, then the Generic Z-Wave Plus drivers are the right ones.
I have a mixture of old and new GE/Jasco devices in my house. Some are branded "Enbrighten"...but the hub picked the Enbrighten driver when it recognized the device fingerprint on those.
Okay I am remembering now why my device handlers are all out of wack. I messed up the pairing on a few of the new switches and didn't enter the 5 digit code so some of my Enbrighten switches were reverted to generic switches.
After I make sure all the devices work I'll go to all the Enbrighten ones with generic drivers and exclude and reinclude them with the secure code.
