Something like ( Jinvoo SM-SW102 WiFi Wall Switch) or if there are any wifi 3 gang switches that would work with Hubitat that anyone can suggest that would be great. I Still kinda new to Hubitat so please go easy on me.
The term gang describes how many switches the actual wall box will hold. Are you asking for a single gang switch that controls 3 separate loads? Otherwise if you have a 3 gang box you can install 3 separate Zigbee or Zwave switches.
The only Zwave multi switch I am aware of is the Zooz double switch that has a dimmer and on/off switch in a single gang.
I see that It is for LED lighting, Tho if bulbs got changed some how it might turn into a problem. That 3 gang switch was such a good idea at the time....
Have you see the Sonoff TX light switches, they work via wifi (you flash them with Tasmota first), not sure if you would be keen to do that? I have about 10 of these around the house and they working well.
I will look into them, I would have no problem with giving it a shot to flash them. Still so much to learn around hear.
edit. Looked into that SONOFF stuff gets me thinking off all the other stuff i can do as well. Why must I (we) try and make the simple task of hitting a light switch so complicated?
If i remember right the box is between 2 studs and there would not be room to put in a tri box. If only i had a crystal ball 10 years ago
There are solutions, but yeah, it can get costly, especially in Canada. You need to be extra diligent to find the deals and good products that are certified.
If I were you, I would jump on that Caseta Pro bridge that @SmartHomePrimer linked to. That is a phenomenally good price. Tempted to buy it myself as a spare.
I want a 3-gang Nue to try as idiot lights. AU/NZ zigbee should work fine in the US. I figure one will show up on Ebay soon enough. I try to stay away from Aliexpress.
