I have been using Echo speaks for a while now, but recently my ISP has been having problems which has resulted in missed notifications for my kids. Are there any speakers that hook up easily to Hubitat, you all recommend?
Thanks for your help.
Sonos or Google speaker (it uses chromecast which is local) I have a few chromecast speakers for sale if you want them.....
@Keo - bear in mind that any TTS from Hubitat needs internet access.
Hubitat uses Amazon Polly to encode text into speech that is then played locally on Sonos speakers (and I think Chromecast works the same way).
Chromcast is local...
How is the encoding done?
Only 1st time.
Then created MP3 files become local unless announcement is using variable.
Correct. But most of my TTS announcements have a variable.
Eg. “Mail was delivered at %time%”
Yeah. Most of mine announce the time as well. So it sounds like even if I switch I will still be dependent on the internet.
@gopher.ny does the chromcast integration once set up use internet for announcements or only for the initial announcement?
Yes, it needs AWS to convert text to speech.
My bad, thought it was all local
MyCroft/PiCroft has a built-in TTS engine. If I can get a Pi, I'm going to mess around with it. There's a Hubitat integration now. It's fully local for everything - voice control and TTS.
One specific point.
There is a real difference between voice notification and voice control. In order to do local voice notification, you don't need the picroft approach, and there are drivers written to get TTS out of a local attached speaker.
However, to get local voice control work, there appear to be only 2 alternatives: picroft and rhasspy.
I personally will be working on a picroft approach in around a month's time, and at present I have no personal experience.
Which ones? Hubitat relies on the Amazon Polly engine to generate TTS that can be played locally on Sonos and Chromecast speakers.
While PiCroft has a built in engine.
There is the one written for the multi room Samsung speakers:
There is also VLC thing:
There is also Media renderer and dlna player
I don't really care for Local voice control
Right but it will allow for local tts
Sorry. That was I was trying to imply
I m currently using an Aeotec Gen 5 doorbell/siren, for custom voice messages. It is an Z-wave device that works locally. However, it does not use TTS. You have to produce the message files either by recording the message in your own voice, or using a program like Zabaware Reader to convert Text to speech and then save the file.
Since the Aeotec Gen 5 is no longer available commercially and the Gen 6 device no longer supports customer message files, it is not a viable an option as it once was. There is another member on the forum who has a Gen 5 for sale.
I just ordered an Ecolink ISZW7-ECO chime + siren that allows you to store custom audio file on an SD card, Like the Aeotec Gen 5, you have to create the custom files yourself, although some default sounds are included. That would allow you to keep your alerts local.
I like this solution, but I was hoping to push things via code to the speaker. I will definitely remember this as a backup!
