HI Mark, i seem to have a few in the groovy IDE so i'm not quite sure which one its using. However, i think this is the one. i can try deleting them, process of elimination if it helps...Stu
metadata {
definition (name: "Colorful Temperature Light Group Device", namespace: "kriskit-trendsetter", author: "Chris Kitch", vid: "generic-rgbw-color-bulb") {
capability "Actuator"
capability "Sensor"
capability "Switch"
capability "Switch Level"
capability "Color Control"
capability "Color Temperature"
command "resetLevel"
command "resetColorTemp"
command "resetSaturation"
command "resetHue"
attribute "onPercentage", "number"
attribute "levelSync", "string"
attribute "colorTempSync", "string"
attribute "colorSync", "string"
attribute "saturationSync", "string"
attribute "hueSync", "string"
simulator {
// TODO: define status and reply messages here
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off", icon: "st.lights.multi-light-bulb-on", backgroundColor: "#00a0dc", nextState: "turningOff"
attributeState "off", label: '${name}', action: "switch.on", icon: "st.lights.multi-light-bulb-off", backgroundColor: "#ffffff", nextState: "turningOn"
attributeState "turningOn", label: '${name}', action: "switch.off", icon: "st.lights.multi-light-bulb-on", backgroundColor: "#00a0dc", nextState: "turningOff"
attributeState "turningOff", label: '${name}', action: "switch.on", icon: "st.lights.multi-light-bulb-off", backgroundColor: "#ffffff", nextState: "turningOn"
attributeState "half", label: '${name}', action: "switch.on", icon: "st.lights.multi-light-bulb-on", backgroundColor: "#6bb3ce", nextState: "turningOn"
attributeState "mostlyOn", label: 'Onish', action: "switch.on", icon: "st.lights.multi-light-bulb-on", backgroundColor: "#2fa8d6", nextState: "turningOn"
attributeState "mostlyOff", label: 'Offish', action: "switch.off", icon: "st.lights.multi-light-bulb-off", backgroundColor: "#98c1d1", nextState: "turningOff"
tileAttribute ("device.color", key: "COLOR_CONTROL") {
attributeState "color", action: "color control.setColor"
tileAttribute ("device.onPercentage", key: "SECONDARY_CONTROL") {
attributeState "onPercentage", label:'${currentValue}% On'
attributeState "100", label:'All On'
attributeState "0", label:'All Off'
tileAttribute("device.level", key: "SLIDER_CONTROL") {
attributeState "default", label: '', action: "switch level.setLevel"
standardTile("levelLabel", "levelLable", height:1, width:1, decoration: "flat", inactiveLabel: true) {
state "default", label:"Level", unit:"", icon: "st.illuminance.illuminance.light"
controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 3, inactiveLabel: false) {
state "level", action:"switch level.setLevel"
valueTile("levelValue", "device.level", inactiveLabel: true, height:1, width:1, decoration: "flat") {
state "default", label:'${currentValue}%', unit:""
valueTile("levelSync", "device.levelSync", height:1, width:1) {
state "default", label:' Sync ', unit:"", action: "resetLevel", backgroundColor: "#ff9900"
state "ok", label:'', unit:"", backgroundColor: "#00b509"
standardTile("colorTempLabel", "colorTempLabel", height:1, width:1, decoration: "flat", inactiveLabel: true) {
state "default", label:"Temp", unit:"", icon: "st.illuminance.illuminance.bright"
controlTile("colorTempSliderControl", "device.colorTemperature", "slider", height: 1, width: 3, inactiveLabel: false, range:"(2000..6500)") {
state "level", action:"color temperature.setColorTemperature"
valueTile("colorTempValue", "device.colorTemperature", inactiveLabel: true, height:1, width:1, decoration: "flat") {
state "default", label:'${currentValue} K', unit:""
valueTile("colorTempSync", "device.colorTempSync", height:1, width:1) {
state "default", label:' Sync ', unit:"", action: "resetColorTemp", backgroundColor: "#ff9900"
standardTile("saturationLabel", "saturationLabel", height:1, width:1, decoration: "flat", inactiveLabel: true) {
state "default", label:"Sat", unit:"", icon: "st.Kids.kids2"
controlTile("saturationSliderControl", "device.saturation", "slider", height: 1, width: 3, inactiveLabel: false) {
state "saturation", action:"color control.setSaturation"
valueTile("saturationValue", "device.saturation", inactiveLabel: true, height:1, width:1, decoration: "flat") {
valueTile("saturationSync", "device.saturationSync", height:1, width:1) {
state "default", label:' Sync ', unit:"", action: "resetSaturation", backgroundColor: "#ff9900"
standardTile("hueLabel", "hueLabel", height:1, width:1, decoration: "flat", inactiveLabel: true) {
state "default", label:"Hue", unit:"", icon: "st.Kids.kids2"
controlTile("hueSliderControl", "device.hue", "slider", height: 1, width: 3, inactiveLabel: false) {
state "hue", action:"color control.setHue"
valueTile("hueValue", "device.hue", inactiveLabel: true, height:1, width:1, decoration: "flat") {
valueTile("hueSync", "device.hueSync", height:1, width:1) {
state "default", label:' Sync ', unit:"", action: "resetHue", backgroundColor: "#ff9900"
standardTile("onButton", "onButton", height:1, width:3, decoration: "flat", inactiveLabel: true) {
state "default", action: "switch.on", label:"On", unit:""
standardTile("offButton", "offButton", height:1, width:3, decoration: "flat", inactiveLabel: true) {
state "default", action: "switch.off", label:"Off", unit:""
main "switch"
details([
"switch",
"levelLabel",
"levelValue",
"levelSync",
"colorTempLabel",
"colorTempValue",
"colorTempSync",
"saturationLabel",
"saturationValue",
"saturationSync",
"hueLabel",
"hueSliderControl",
"hueValue",
"hueSync",
"onButton",
"offButton"])
def groupSync(name, values) {
try {
"sync${name.capitalize()}"(values)
} catch(ex) {
log.error "Error executing 'sync${name.capitalize()}' method: $ex"
def mapAttributeToCommand(name, value) {
switch (name) {
case "switch":
if (value == "on")
return [command: "on", arguments: null]
if (value == "off")
return [command: "off", arguments: null]
break;
case "level":
return [command: "setLevel", arguments: [value.toInteger()]]
case "color":
return [command: "setColor", arguments: [value]]
case "hue":
return [command: "setHue", arguments: [value.toInteger()]]
case "saturation":
return [command: "setSaturation", arguments: [value.toInteger()]]
log.error "Could not map '$name' attribute with value '$value' to a command."
// SWITCH
def on() {
on(true)
def on(triggerGroup) {
sendEvent(name: "switch", value: "on")
sendEvent(name: "onPercentage", value: 100, displayed: false)
if (triggerGroup)
parent.performGroupCommand("on")
def off() {
off(true)
def off(triggerGroup) {
sendEvent(name: "switch", value: "off")
sendEvent(name: "onPercentage", value: 0, displayed: false)
if (triggerGroup)
parent.performGroupCommand("off")
def syncSwitch(values) {
log.debug "syncSwitch(): $values"
def onCount = values?.count { it == "on" }
def percentOn = (int)Math.floor((onCount / values?.size()) * 100)
log.debug "Percent On: $percentOn"
if (percentOn == 0 || percentOn == 100) {
if (percentOn == 0)
off(false)
else
on(false)
return
def value = null
if (percentOn == 50)
value = "half"
else if (percentOn > 0 && percentOn < 50)
value = "mostlyOff"
else if (percentOn > 50 && percentOn < 100)
value = "mostlyOn"
sendEvent(name: "switch", value: value)
sendEvent(name: "onPercentage", value: percentOn, displayed: false)
// LEVEL
def setLevel(val) {
setLevel(val, true)
def setLevel(val, triggerGroup) {
log.debug "Setting level to $val"
if (val < 0)
val = 0
if( val > 100)
val = 100
if (triggerGroup) {
if (val == 0)
off()
else
on()
sendEvent(name: "level", value: val, isStateChange: true)
sendEvent(name: "switch level.setLevel", value: val, isStateChange: true)
if (triggerGroup)
parent.performGroupCommand("setLevel", [val])
def syncLevel(values) {
log.debug "syncLevel(): $values"
def valueCount = values?.size()
def valueCountBy = values?.countBy { it }
def matchValue = "bad"
def level = device.currentValue("level")
valueCountBy.each { value, count ->
if (count == valueCount) {
level = value
matchValue = "ok"
return true
if (matchValue == "bad")
level = getResetLevel(values)
setLevel(level, false)
sendEvent(name: "levelSync", value: matchValue, displayed: false)
def resetLevel() {
def values = parent.getGroupCurrentValues("level")
if (!values)
return
def level = getResetLevel(values)
setLevel(level)
def getResetLevel(values) {
if (!values)
return
valueCountBy = valueCountBy?.sort { a, b -> b.value <=> a.value }
if (valueCountBy.size() > 1) {
if (valueCountBy.size() == values.size()) {
log.debug "Values are all different - making average"
level = Math.round(values.sum() / values.size())
} else {
log.debug "Some values are the same, choosing most popular"
def firstItem = valueCountBy.find { true }
level = firstItem.key
return level
// COLOR TEMPERATURE
def setColorTemperature(val){
setColorTemperature(val, true)
def setColorTemperature(val, triggerGroup) {
log.debug "Setting color temperature to $val"
if (val < 2000)
val = 2000
if( val > 6500)
val = 6500
if (triggerGroup)
on()
sendEvent(name: "colorTemperature", value: val, isStateChange: true)
if (triggerGroup)
parent.performGroupCommand("setColorTemperature", [val])
def syncColorTemperature(values) {
log.debug "syncColorTemp(): $values"
def colorTemp = device.currentValue("colorTemperature")
colorTemp = value
matchValue = "ok"
return true
colorTemp = getResetColorTemp(values)
setColorTemperature(colorTemp, false)
sendEvent(name: "colorTempSync", value: matchValue, displayed: false)
def resetColorTemp() {
def values = parent.getGroupCurrentValues("colorTemperature")
if (!values)
return
def colorTemp = getResetColorTemp(values)
setColorTemperature(colorTemp)
def getResetColorTemp(values) {
if (!values)
return
colorTemp = Math.round(values.sum() / values.size())
} else {
colorTemp = firstItem.key
return colorTemp
// COLOR
def setColor(value) {
setColor(value, true)
def setColor(value, triggerGroup) {
value.level = device.currentValue("level")
def hex = value.hex
if (!hex && value.hue && value.saturation)
hex = colorUtil.hslToHex((int)value.hue, (int)value.saturation)
sendEvent(name: "color", value: hex, displayed:false)
if (triggerGroup)
parent.performGroupCommand("setColor", [value])
if (value.saturation)
setSaturation(value.saturation, triggerGroup, false)
if (value.hue)
setHue(value.hue, triggerGroup, false)
def syncColor(values) {
log.debug "syncColor(): $values"
// SATURATION
def setSaturation(value) {
setSaturation(value, true, true)
def setSaturation(value, triggerGroup, sendColor) {
on(triggerGroup)
sendEvent(name: "saturation", value: (int)value, displayed:false)
if (triggerGroup)
parent.performGroupCommand("setSaturation", [value])
if (sendColor) {
def hex = colorUtil.hslToHex((int)device.currentValue("hue"), value)
def syncSaturation(values) {
log.debug "syncSaturation(): $values"
matchValue = "ok"
return true
sendEvent(name: "saturationSync", value: matchValue, displayed: false)
def resetSaturation() {
def saturation = (int)device.currentValue("saturation")
log.debug "resetSaturation $saturation"
setSaturation(saturation)
// HUE
def setHue(value) {
setHue(value, true, true)
def setHue(value, triggerGroup, sendColor) {
on(triggerGroup)
sendEvent(name: "hue", value: (int)value, displayed: false)
if (triggerGroup)
parent.performGroupCommand("setHue", [value])
if (sendColor) {
def hex = colorUtil.hslToHex(value, (int)device.currentValue("saturation"))
def syncHue(values) {
log.debug "syncHue(): $values"
matchValue = "ok"
return true
sendEvent(name: "hueSync", value: matchValue, displayed: false)
def resetHue() {
def hue = (int)device.currentValue("hue")
log.debug "resetHue: $hue"
setHue(hue)
