Saw the "security" set sold by Linkind on amazon and noticed a security keyfob. Curious if anyone is using the keyfob on HE?
I bought plug/button combos about a year ago. The plugs worked but the buttons did not. The devs even looked at it and there is something funky with their zigbee buttons and likely will never work on Hubitat. They do work on Home Assistant. Anyways long story short....dont buy.
was this the button? because they have a round dimmer button also
Do you still have this keyfob?
When paired to HE, is the model shown in the device Data section as "ZB-KeyfodGeneric-D0001" ?
No thats not it, it was a single button. Here is the thread where it wass discussed.
This old thread mixes several different devices... If someone owns a particular single-button or 4-button device that does not work, please post the model and the manufacturer from the Data section when paired to HE.
Interesting, I found this Amazon review.
Added to hubitat system
Reviewed in the United States on January 31, 2021
Actually used these to at to my hubitat system because the price could not be best. The sensors all written great so far. I even added the key fob to my system
āā THIS is what I was looking for. So the keyfob, from my OP, does work with HE? That would be fantastic
That isnt my quote i just copy and pasted from Amazon. I guess you can try, Amazon is generous with their return policy. Plz report back your findings.
Oh, opps, sorry. Well right now it's 20 bucks for the system and to me the sensors alone are worth 20 bucks. Looks like the last set at 20 USD is gone from amz USA
Hello Krassimir,
Here is the info for the keyfob and yes it paired exactly as you described, here's the info.
PMinfoZigbee parsed:[raw:catchall: 0000 0006 00 00 0040 00 AA39 00 00 0000 00 00 03FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:AA39, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[03, FD, FF, 04, 01, 01, 19, 00, 00]]
dev:20722022-12-27 04:10:31.498 PMinfofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0500,0B05", outClusters:"0003,0019,0501", model:"ZB-KeyfodGeneric-D0001", manufacturer:"lk"
dev:20722022-12-27 04:10:30.487 PMtraceZCL version:03
dev:20722022-12-27 04:10:30.483 PMtraceSoftware Build Id:3.14
dev:20722022-12-27 04:10:30.482 PMtraceModel:ZB-KeyfodGeneric-D0001
dev:20722022-12-27 04:10:30.480 PMtraceManufacturer:lk
dev:20722022-12-27 04:10:30.179 PMdebuggetting info for unknown Zigbee device...
dev:20722022-12-27 04:10:25.443 PMinfofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0500,0B05", outClusters:"0003,0019,0501", model:"ZB-KeyfodGeneric-D0001", manufacturer:"lk"
dev:20722022-12-27 04:10:24.411 PMtraceZCL version:03
dev:20722022-12-27 04:10:24.409 PMtraceSoftware Build Id:3.14
dev:20722022-12-27 04:10:24.407 PMtraceModel:ZB-KeyfodGeneric-D0001
dev:20722022-12-27 04:10:24.406 PMtraceManufacturer:lk
dev:20722022-12-27 04:10:24.188 PMdebuggetting info for unknown Zigbee device...
dev:20722022-12-27 04:10:22.157 PMdebugconfigure() called...
dev:20722022-12-27 04:09:47.090 PMinfofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0500,0B05", outClusters:"0003,0019,0501", model:"ZB-KeyfodGeneric-D0001", manufacturer:"lk"
dev:20722022-12-27 04:09:47.069 PMinfofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0500,0B05", outClusters:"0003,0019,0501", model:"ZB-KeyfodGeneric-D0001", manufacturer:"lk"
dev:20722022-12-27 04:09:46.084 PMtraceZCL version:03
dev:20722022-12-27 04:09:46.081 PMtraceSoftware Build Id:3.14
dev:20722022-12-27 04:09:46.079 PMtraceModel:ZB-KeyfodGeneric-D0001
dev:20722022-12-27 04:09:46.077 PMtraceManufacturer:lk
dev:20722022-12-27 04:09:44.260 PMdebuggetting info for unknown Zigbee device...
dev:20722022-12-27 04:09:42.225 PMdebugconfigure() called...
Show more...
DId you try [Release] Heiman Zigbee Key Fob Driver ?
You will need first to manually change to Muxa's driver and secondly to pair again to HE hub,
Can you try with [RELEASE] Tuya Zigbee Multi-Sensor 4 In 1 (PIR motion sensors and mmWave presence radars) ? Of course It does not support keyfobs, but I will see familiar debug logs... : )
Add the fingerprint the same way, and pair with debug logging on.
Okay, as per your instructions, here are the zigbee logs and the hub logs
Zigbee Logs
6A702022-12-28 11:25:40.468 profileId:0x0, clusterId:0x8021, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-29
6A702022-12-28 11:25:40.465 profileId:0x0, clusterId:0x8021, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-30
6A702022-12-28 11:25:40.462 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-30
6A702022-12-28 11:25:39.552 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-29
6A702022-12-28 11:25:39.549 profileId:0x0, clusterId:0x13, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-29
Hub Logs
dev:2512022-12-28 11:27:39.040 AMinfoping()
dev:20522022-12-28 11:26:56.129 AMinfoApplication ID Received
sys:12022-12-28 11:26:26.042 AMinfoZigbee Discovery Stopped
dev:20722022-12-28 11:26:25.769 AMdebugLinkind Keyfob sendZigbeeCommands (cmd=[he raw 0x823B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x823B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x823B 0x02 0x01 0x0402 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x823B 0x02 0x01 0x0405 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x823B 0x03 0x01 0x0400 {588E81FFFE2738FA} {}])
dev:20722022-12-28 11:26:25.676 AMinfoLinkind Keyfob configure()..
dev:7962022-12-28 11:26:10.455 AMinfoMotion 2nd Floor Hue illuminance is 13 Lux
sys:12022-12-28 11:25:39.446 AMinfoFound previously joined Zigbee device Linkind Keyfob
dev:20722022-12-28 11:25:39.437 AMdebugLinkind Keyfob sendZigbeeCommands (cmd=[he raw 0x823B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x823B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x823B 0x02 0x01 0x0402 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x823B 0x02 0x01 0x0405 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x823B 0x03 0x01 0x0400 {588E81FFFE2738FA} {}])
dev:20722022-12-28 11:25:39.382 AMinfoLinkind Keyfob configure()..
sys:12022-12-28 11:25:39.213 AMinfoFound previously joined Zigbee device Linkind Keyfob
dev:20722022-12-28 11:25:39.204 AMdebugLinkind Keyfob sendZigbeeCommands (cmd=[he raw 0x6A70 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x6A70 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x6A70 0x02 0x01 0x0402 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x6A70 0x02 0x01 0x0405 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x6A70 0x03 0x01 0x0400 {588E81FFFE2738FA} {}])
dev:20722022-12-28 11:25:39.141 AMinfoLinkind Keyfob configure()..
sys:12022-12-28 11:25:36.877 AMinfoFound previously joined Zigbee device Linkind Keyfob
dev:20722022-12-28 11:25:36.861 AMdebugLinkind Keyfob sendZigbeeCommands (cmd=[he raw 0x823B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x823B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x823B 0x02 0x01 0x0402 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x823B 0x02 0x01 0x0405 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x823B 0x03 0x01 0x0400 {588E81FFFE2738FA} {}])
dev:20722022-12-28 11:25:36.789 AMinfoLinkind Keyfob configure()..
EDIT-failed to add fingerprint first to driver let me do it right, will edit post
here are the logs after adding fingerprint to driver and re-pairing keyfoD
HubLog
dev:20722022-12-28 01:03:56.479 PMdebugLinkind Keyfob write attribute response is FAILURE
dev:20722022-12-28 01:03:56.476 PMdebugLinkind Keyfob parse(lk) descMap = [raw:catchall: 0104 0000 01 01 0040 00 6A70 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6A70, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:20722022-12-28 01:03:56.461 PMinfoLinkind Keyfob Tuya device manufacturer is lk
dev:20722022-12-28 01:03:56.455 PMdebugLinkind Keyfob parse(lk) descMap = [raw:6A7001000068040042026C6B0000002003010000200305000042165A422D4B6579666F6447656E657269632D44303030310700003003FEFF86, dni:6A70, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:lk, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:03, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:ZB-KeyfodGeneric-D0001, encoding:42, attrId:0005, consumedBytes:25, attrInt:5], [value:03, encoding:30, attrId:0007, consumedBytes:4, attrInt:7], [status:86, attrId:FFFE, attrInt:65534]]]
dev:20722022-12-28 01:03:56.403 PMinfoLinkind Keyfob Received bind response, data=[76, 00] (Sequence Number:76, Status: Success)
dev:20722022-12-28 01:03:56.400 PMdebugLinkind Keyfob parse(lk) descMap = [raw:catchall: 0000 8021 00 00 0040 00 6A70 00 00 0000 00 00 7600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6A70, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[76, 00]]
dev:20722022-12-28 01:03:55.475 PMinfoLinkind Keyfob Received bind response, data=[75, 00] (Sequence Number:75, Status: Success)
dev:20722022-12-28 01:03:55.472 PMdebugLinkind Keyfob parse(lk) descMap = [raw:catchall: 0000 8021 00 00 0040 00 6A70 00 00 0000 00 00 7500, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6A70, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[75, 00]]
dev:20722022-12-28 01:03:55.438 PMinfoLinkind Keyfob Received bind response, data=[74, 00] (Sequence Number:74, Status: Success)
dev:20722022-12-28 01:03:55.435 PMdebugLinkind Keyfob parse(lk) descMap = [raw:catchall: 0000 8021 00 00 0040 00 6A70 00 00 0000 00 00 7400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6A70, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[74, 00]]
dev:20722022-12-28 01:03:55.352 PMinfoLinkind Keyfob Received device announcement, data=[8B, 70, 6A, FA, 38, 27, FE, FF, 81, 8E, 58, 80] (Sequence Number:8B, Device network ID: 6A70, Capability Information: 80)
dev:20722022-12-28 01:03:55.344 PMdebugLinkind Keyfob parse(lk) descMap = [raw:catchall: 0000 0013 00 00 0040 00 6A70 00 00 0000 00 00 8B706AFA3827FEFF818E5880, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6A70, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8B, 70, 6A, FA, 38, 27, FE, FF, 81, 8E, 58, 80]]
dev:16232022-12-28 01:03:53.114 PMinfoApplication ID Received
sys:12022-12-28 01:03:52.836 PMinfoFound previously joined Zigbee device Linkind Keyfob
dev:20722022-12-28 01:03:52.826 PMdebugLinkind Keyfob sendZigbeeCommands (cmd=[he raw 0x6A70 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x6A70 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x6A70 0x02 0x01 0x0402 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x6A70 0x02 0x01 0x0405 {588E81FFFE2738FA} {}, delay 200, zdo bind 0x6A70 0x03 0x01 0x0400 {588E81FFFE2738FA} {}])
dev:20722022-12-28 01:03:52.728 PMinfoLinkind Keyfob configure()..
here are zigbee logs
ZigLog
Linkind Keyfob2022-12-28 13:03:56.507 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-29
Linkind Keyfob2022-12-28 13:03:56.504 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-29
Linkind Keyfob2022-12-28 13:03:56.402 profileId:0x0, clusterId:0x8021, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-29
Linkind Keyfob2022-12-28 13:03:55.494 profileId:0x0, clusterId:0x8021, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-28
Linkind Keyfob2022-12-28 13:03:55.492 profileId:0x0, clusterId:0x8021, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-28
Linkind Keyfob2022-12-28 13:03:55.390 profileId:0x0, clusterId:0x13, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-29
Sorry, this driver didn't work for the tests. Hopefully I will have some more time in the next year to further look into this device.
It's okay. I am blessed beyond measure in many aspects, and keeping things in perspective, this is very minor. Thank you for all you do for the community, I'm very thankful.
Happy New Year
@Rxich did you manage to make this keyfob model:"ZB-KeyfodGeneric-D0001", manufacturer:"lk" to work in HE?
Hi Krassimir, No I haven't been able to get it to work. It's still sitting on my desk and I haven't been testing it. The battery went dead and opening the battery compartment is very difficult. So many toys, so little time
