Because we are so happy with your app and drivers, Rob + David, I've gone and purchased some additional LIFX bulbs. This time for our back patio. Two of the bulbs are the nightvision type, and they don't seem to be recognized during the discovery process.
I don't see any "Night Vision" models not accounted for here: Our Products
Best recommendation would be to add a new log at line 1501 of LIFXMasterApp (first line in private Map deviceVersion(Map device)):
log.debug("LIFX Product ID: ${device.product}")
Ideally this product id should match one of the case statements in that same function, which will correlate it to a driver, identified by the deviceName attribute assigned in that case.
It might be a good idea to just treat any unknown device as a LIFX Color (or maybe Mono) I suppose, along with a message that explains that you can change the device type manually.
Thanks for rapid replies. The bulbs are type 110. And it turns out your app knows that type well already.
The gap here was user error. The link I have used over the past year or more to refresh my LIFX Master App from github pointed directly to an old version. The mismatch between the line number and the function definition was the hint.
The only downlights that the code is currently aware of have product ids of 36, 37 and 40, I'm guessing that LIFX have released a new one with a new product id.
All you'd have to do is add another case statement for the new id at around line 1677. Please let me know what the new id is so it can be added to the code.
Hmm, 49 is already in the code as a LIFX Mini Color (line 1715) - the positioning of that log will generate one for each device being discovered, are there others? Or errors in processing (Driver not installed)?
In this case however it wouldn't matter since they both use the LIFX Color driver.
Adding an extra case 49 in the switch statement may be considered an error (or perhaps Groovy only uses the first occurrence). IntelliJ certainly flags that as an error.
@James_be just to be clear - is the issue that the light is not discovered at all? Or that the App cannot correlate it to a driver, and create a Device?
Assuming the lights are permanently switched on I'd suggest opening the LIFX Master app, increasing the settings Time between commands (perhaps to 60 or 70) and Maximum number of passes (to 3) and then try discovering devices again (or discover only new devices).
I can't add any new lights using lifx master. Is there a new way of using lifx since I set this up years ago?
All the new lights show "No driver installed for null".
I started keeping some apps "updated" using Hubitat Package Manager so maybe that is the problem?
