But they don't actually support HE. Someone intercepted the API calls from the mobile app to create the "awesomeness" of the Life360 connector.
FYI... If you delete the Life360 connector before HE does a fix for the login, you end up with orphaned push notifications showing up as warnings in the log. They will be a web IP that can no longer connect to the app Id for the now deleted Life360 Connector. Hopefully they just expire on Life360 and eventually stop.
Personally I would recommend installing Life360+ if you don't feel like waiting for a fix. It took me 5 minutes to install using Hubitat Package Manager and maybe a half-hour to change over my pistons so I didn't have to go through breaking them all again in the future.
Life360+ is much more feature-rich than Life360 Connector and, should Life360 make further changes, appears to get updated faster. No shade on the HE staff as they have dang good reason not to be updating until the "dust settles."
Simon I really appreciate your advice, this is what makes this such a great community!
Ironically, I did reach back out to Life360, twice. The first time, to inform them I wasn't requesting anything new; it has been working great for the past year. I also informed them no configuration changes were made, but recently started getting a "Life360 login failed" error in the Hubitat "Life360 Connector" app. They responded very quickly but the response was nothing more than a link to their password reset portal.
I fired right back to inform them this isn't a password issue as I'm able to log into their website and phone app without issue, but that's the last communication I've had with them.
As others suggested, I Installed the Life360+ app thru HPM but can't find where to add any devices or log into Life360 (no Life360+ under apps but app & driver are installed). Think I'm just going to follow BobbyD's advise and just wait for a fix (hopefully).
I haven't used Life360+ - I might be forced to do it if this app fails. But I would definitely post over there and get advice on this - [RELEASE] Life360+. Worth putting in the time to switch over as last time this was not working for some time.
Gave the Life360+ install another shot & realized, after installing with HPM, I had forgotten to add Life360+ with the "+ Add User App" button. Once that was done, Life360+ appeared with the rest of my apps. The only other issue was that Life360+ wouldn't let me use my email address to authenticate. Had to enter my cell phone number with +1 in front of 10-digit phone number that is registered with the actual life360 app. After pulling in circle members, places & updating rules with the newly presence sensors that were created by Life360+, everything is once again functioning properly for all family members!
You may want to drop some logs or additional info on what you’re encountering. Someone may be able to see an issue or something that could help resolve what you’re running into.
I am trying to migrate to the Life360+ app since the Life360 Connector hasn't worked for months, despite the guidance to wait for them to fix a problem. I tried accessing the Life360+ app. It asked for my Login Credentials which I provided. However, I got this message:
Select Life360 Circle
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: No signature of method: java.net.SocketTimeoutException.getResponse() is applicable for argument types: () values: [] Possible solutions: getMessage()
I go to Logs but there is nothing there. I'm at a loss as to what to do now.
