Could this be a regional thing ? I'm in Eastern Europe/Romania.
I mean, anything is possible really. I've checked their socials and they have no info on any outage yet. I was logged out of the iOS app between yesterday and today. At this rate, I'm going to have to switch to Life360+ and use the workaround modifications.
Any official updates to anything? I can't even find acknowledgement of the issue actually happening.
The official acknowledgement was posted 23 days ago.
Well, that’s what happens when I assume. My issues had cleared within a couple of days of that info being posted leading me to believe that all things were made right.
I was not aware this issue had been present for the last 20+ days. Thanks for the response! And sorry for being ignorant of the issue being this persistent.
It was fixed about 23 days ago, but then broke again last 4 days. But apparently, I heard the custom Life360+ app for Hubitat is working now, while the built-in Life360 Connector app for Hubitat is still broken.
Ran into the same problem with Life360 Connector, but installed Life360+, and am able to login and select the location and family members, so it appears to be working.
I have just started experiencing problem with Life 360 Connector. It is not reporting our comings and goings to Hubitat and as a result, none of my automations based on presence (or lack of presence) are functioning. Has anybody had success with removing and re-installing the Connector?
Where can I find Life360+?
So I tried deleting the Life360 Connector app and re-installing it. I'm still getting a Login(Failed). But now another problem exists. My 3 presence sensors (iPhones) are no longer listed as child devices and I have no idea how to get them back in. Is there anybody still reading this lengthy thread, or should I open a new thread?
No point in opening a new thread. The stock/native L360 integration is broken due to some recent changes L360 has made. The community L360+ integration seems to have found a workaround, so you can try that.
Since there's no confirmation yet whether L360's changes are transitionary or permanent, we're all in a bit of limbo with either choice.
I recall seeing a post lately that HE staff is planning to implement the change L360+ already has made sometime soon though.
I use the stock integration and I'm just waiting it out -- our presence not updating right is a bit annoying, but it doesn't seriously impact anything and I'm simply too lazy to switch integrations, so I choose to wait & see.
Thanks.
I stupidly forgot to take screenshots of the automations that depended on Life360 Connector, and now I have Broken Triggers all over the place. This sux!
Restore a backup from before you deleted it.
Try using the forum search, but put Life360+ in quotes.
If you have Hubitat Package Manager installed, you can find Life360+ app within there to install.
I know it doesn’t help those who are trying to connect but mine remains connected and working.
This was not the case 4 weeks ago when Life360 introduced these problems. When this happened I checked their support web site it said everything had been fixed and to email support if you were still having issues.
So I emailed their support and my connector was able to connect about 6 hours later and has remained connected and working. I did not get any response from them but was it a coincidence? A true test would be for me to disconnect and reconnect - but I am not brave enough for that!
So perhaps email their support? Couldn’t hurt.
My Life360 integration is no longer letting me log in. Bummer, hoping a fix happens soon.
Mine also stopped working in the last couple days.
There are a bunch of errors in the logs.
"Unable to get token for life360 authorization."
Well at least you got a response. I didn't. I think they used the opportunity to tell you that they don't support Hubitat vs. address your underlying issue. I would reply and say that you are using the REST API and that it is not authenticating?
I installed Life 360+ from HPM and was able to log in, so for the time being I'm up and running.
