Leaksmart water valve?
I've ordered the HE-supported Dome but I'd prefer zigbee. Anybody running the Leaksmart valve?
Yes, I have one and it works. Got it from Lowes.
Driver?
 *  LeakSMART Water Valve v 1.3
 *     (Mode: 8830000L)
 *  Capabilities:
 *      Configuration, Refresh, Switch, Valve, Polling
 *  Author:
 *     Kevin LaFramboise (krlaframboise)
 *  Url to Documentation:
 *      https://community.smartthings.com/t/release-leaksmart-water-valve/48669
 *  Changelog:
 *    1.3 (10/23/2017)
 *      - Added support for valve attribute events.
 *    1.2.1 (08/12/2017)
 *      - Create switch events when the open/close state changes.
 *    1.2 (08/20/2016)
 *      - Changed lower battery limit to 5.0
 *    1.1.3 (05/23/2016)
 *      - Changed lower battery limit to 5.5
 *    1.1.2 (05/22/2016)
 *      - Added battery capability and tile
 *      - Added debug logging for battery map.
 *      - Changed poll method  read instead of configure.
 *      - Changed minimum batterr reporting interval to 10 minutes
 *        to avoid duplicates.
 *      - Changed upper battery voltage to 6.0.
 *    1.0.3 (05/22/2016)
 *      - Initial Release
 *      - Bug fixes
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "LeakSmart Water Valve", namespace: "krlaframboise", author: "Kevin LaFramboise") {
		capability "Actuator"
		capability "Battery"
		capability "Configuration"
		capability "Refresh"
		capability "Switch"
		capability "Valve"
		capability "Polling"
		attribute "lastPoll", "number"
		fingerprint profileId: "0104", inClusters: "0000,0001,0003,0006,0020,0B02", outClusters: "0019"
	preferences {
		input "debugOutput", "bool",
			title: "Enable debug logging?",
			defaultValue: true,
			displayDuringSetup: false,
			required: false
	tiles(scale: 2) {
		standardTile("contact", "device.contact", width: 4, height: 4, canChangeIcon: true) {
			state "closed",
				label:'Closed',
				action: "valve.open",
				nextState: "opening",
				icon:"st.valves.water.closed",
				backgroundColor:"#e86d13"
			state "opening",
				label:'Opening',
				action: "valve.close",
				icon:"st.valves.water.open",
				backgroundColor:"#ffe71e"
			state "open",
				label:'Open',
				nextState: "closing",
				backgroundColor:"#53a7c0"
			state "closing",
				label:'Closing',
		standardTile("refresh", "device.refresh", width: 2, height: 2, canChangeIcon: true) {
			state "default",
				label: 'Refresh',
				action: "refresh.refresh",
				icon: ""
		valueTile("battery", "device.battery", width: 2, height: 2, canChangeIcon: true) {
			state "battery",
				label: 'Battery ${currentValue}%',
				unit: "%"
				icon: ""
		main "contact"
		details(["contact", "refresh", "battery"])
def updated() {
	if (!state.configured) {
		return response(configure())
	def result = []
	def evt = zigbee.getEvent(description)
	if (evt) {
		if (evt.name == "switch") {
			def val = (evt.value == "on") ? "open" : "closed"
			logDebug "Valve is $val"
			result << createEvent(name: "contact", value: val)
			result << createEvent(name: "valve", value: val)
			result << createEvent(name: "switch", value: evt.value, displayed:false)
			result << createEvent(name: "lastPoll",value: new Date().time, isStateChange: true, displayed: false)
		else {
			logDebug "Ignored Event: $evt"
		result << createEvent(evt)
	else {
		def map = zigbee.parseDescriptionAsMap(description)
		if (map) {
			if (map.clusterInt == 1) {
				def batteryLevel = getBatteryLevel(zigbee.convertHexToInt(map.value))
				logDebug "Battery Level is ${batteryLevel}%\nMap: $map"
				result << createEvent(name: "battery", value: batteryLevel, unit:"%")
			else {
				logDebug "Ignored Map: $map"
		else {
			logDebug "Ignored Description: $description"
	return result
private getBatteryLevel(rawValue) {
	def maxVolts = 6.0
	def minVolts = 5.0
	def volts = (rawValue / 10)
	def batteryPercentages = (volts - minVolts) / (maxVolts - minVolts)
	def batteryLevel = (int) batteryPercentages * 100
	if (batteryLevel > 100) {
		return 100
	else if (batteryLevel < 0) {
		return 0
	else {
		return batteryLevel
def on() {
	open()
def off() {
	close()
def open() {
	logDebug "Opening"
	zigbee.on()
def close() {
	logDebug "Closing"
	zigbee.off()
def poll() {
	def minimumPollMinutes = (3 * 60) // 3 Hours
	def lastPoll = device.currentValue("lastPoll")
	if ((new Date().time - lastPoll) > (minimumPollMinutes * 60 * 1000)) {
		logDebug "Poll: Refreshing because lastPoll was more than ${minimumPollMinutes} minutes ago."
		return refresh()
	else {
		logDebug "Poll: Skipped because lastPoll was within ${minimumPollMinutes} minutes"
def refresh() {
	logDebug "Refreshing"
	return zigbee.onOffRefresh() +
		getBatteryReport() +
		zigbee.onOffConfig() +
		configureBatteryReporting()
def configure() {
	logDebug "Configuring Reporting and Bindings."
	state.configured = true
	return zigbee.onOffConfig() +
		configureBatteryReporting() +
		getBatteryReport()
private configureBatteryReporting() {
	def minSeconds = (10 * 60) // 10 Minutes
	def maxSeconds = (4 * 60 * 60) // 4 Hours
	zigbee.configureReporting(0x0001, 0x0020, 0x20, minSeconds, maxSeconds, 0x01)
private getSwitchReport() {
	return readAttribute(0x0006, 0x0000)
private getBatteryReport() {
	zigbee.readAttribute(0x0001, 0x0020)
private logDebug(msg) {
	if (settings.debugOutput != false) {
		log.debug "$msg"
Thanks!
Is the hub required for this valve to work or can you just use the valve and leak sensors with the hubitat hub and forego the leaksmart hub?
You only need the Hubitat hub. No need to purchase the Leaksmart hub as these pair up directly.
I paired my Leaksmart Valve directly to Hubitat. I don’t have any Leaksmart branded sensors to try.
So you just use it as a means to remotely turn off your water to the house? Anyone know if those leak sensors work in Hubitat?
I have SmartThings And Iris Moisture Sensors that will turn off the water valve Incase of a leak.
Should work, ST driver installs directly in HE
https://raw.githubusercontent.com/ericvitale/ST-leakSmart-Sensor/master/devicetypes/ericvitale/leaksmart-sensor.src/leaksmart-sensor.groovy
VJV, can you please tell me if the valve is a repeater for zigbee? In particular I am wondering about xiaomi devices, as I need to stay away from incompatible repeaters.
I was worried about my Hampton Bay zigbee fan controller, but it is not a repeater, so perfect.
thank you
The valve does not repeat. I have one and the Xiaomi leak sensor right next to it does not route through the valve when I look at the Zigbee map with my Xbee. It instead prefers the Trådfri outlet I have upstairs, just above it.
HSM will shut the valve off when there's a leak. I have two of the leakSmart sensors. They work too, but the temp reading is out of wack. Here's the driver code.
Thanks "SHP". Just got my leaksmart valve and it connected right away. It is only an end device, and not a router, as mains powered devices can be, exactly as you pointed out.
Used the smartthings handler, open close works, albeit with a 2-3 second delay, and I'm getting battery voltage reports. Overall happy, especially for the 35 bucks I paid for open box(like new) from fleabay
Yeah, it's really a battery powered device with a power adapter. Sweet deal on that valve!
@vjv I'm new so bear with me... I can add this driver code, but then what? How do I make it control the valve?
Thanks for this BTW!
Go to the device details page for the valve and change the driver to use the custom driver you just added. User created drivers are near the bottom of the list.
@charlesrblack
To what @SmartHomePrimer has said, let me add one thing. After you change the driver, then you should hit the Configure button on the device page for the valve.
Just figured it out, thanks!
