I noticed Hubitat saying there are some errors in my rule, the code and errors are listed below. Anyone have any idea's why I am getting these errors? I thought the logic was pretty straight forward. I started out by using someone elses rule for a wash machine on here. Basically monitoring power for it to drop below 45w for 4 minutes, then triggering a repeat action to send a notification until someone opens the washer door.
IF (Power level of Wash Machine Outlet(42.6) is > 45.0(F) [FALSE]) THEN
Cancel Delayed Actions
Rule Boolean True: Monitor - Washing Machine Running
ELSE-IF (Private Boolean is true(T) [TRUE]) THEN
Rule Boolean False: Monitor - Washing Machine Running
Delay 0:04:00 (cancelable)
Set washer.ended to current time
Repeat every 0:05:00 (stopable)
IF (Wash Machine Door closed(T) [TRUE]) THEN
Notify Pixel 4, Pixel 4 XL and Speak on Craft Room Hub, Downstairs Speaker, Basement Speaker, Kitchen display, Garage Speaker: 'The clothes washing machine has finished running at %washer.ended%'
ELSE-IF (Wash Machine Door open(F) [FALSE]) THEN
Stop Repeating Actions
END-IF
END-IF
*** malformed REPEAT ***
