no the problems are still there - I have just given up and reverted back to my C7 where everything works.
the C8 simply refuses to pair with any zigbee device or new old - at first I sent back the new devices claiming they did not work. feel a little foolish now.
and if any existing devices needs resetting you can say goodbye to that. unless you go back to C7 where everything works
have you tried add any new zigbee devices?
I migrated and thought everything went well - then I tried to add a new device.
then an existing device stopped working - many reboots, upgrades later I have given up and went back to the C7 where everything is working
They are all new zigbee devices as I was all zwave on the c7’s.
Since the last release I have been pairing and unpairing devices between hubs nine stop. Between c7 and c8 and to the same device.
The c7’s would not pair zigbee at all at one point. After the last release all hubs appear to be working fine and a Sonoff temp sensor that just stoped reporting or dropped off. Not sure which has now been solid for about 4 days.
One thing I did notice was that on one of the older versions if you unpaired a device it appeared to release it from the hub but after a few flashes the device led went solid like it’ll was paired. I tried factory reset and it would flash 5 times and the go solid. This would not then pair. I powered down the hub that it had been paired to and magically it was then able to pair with another hub.
On the c8’s I did a complete reset on all radios and a soft reset after the last update and a soft reset on the c7’s (no radio reset obviously as all the current network was on these) and to be honest it’s been stable since.
I have two of those and my logs are not showing that message.
dev:1998 2023-04-16 08:05:19.081 PM info Kids Fan Outlet 5 was turned on [digital]
dev:1998 2023-04-16 08:05:17.971 PM info Kids Fan Outlet 5 was turned off [digital]
dev:1998 2023-04-16 02:16:59.570 PM info Kids Fan Outlet 5 is on [physical]
I removed then re-paired my 3210-L (vs -L2) to be "Iris Smart Plug"
These are ZDO messages and are typically ignored in drivers, these aren't anything new or specific to a C8, we've been passing ZDO messages to drivers for some time now.
These frames are not a cause for logging a warning message.
I have six or seven Aqara contact sensors, three Aqara buttons. I paired all three buttons and two of the contact sensors after I got the C8, the rest were migrated from C7. So based on my experience I know the Aqara gear can be paired.
What devices are you trying to pair?
I'd return to .125 unless you find something particularly better on .148, .125 has changes that should make things better overall on Zigbee. (YYMV, of course.)
Something you could try, a step or further than just a hub reboot:
Use the Zigbee Rebuild network option on the Zigbee Details page
Shut down hub, remove power after red LED appears. Wait a minute. Plug in hub again and lt it boot up.
Go back to Zigbee Details select the Reboot radio option to reboot your Zigbee radio. (Just Reboot, don't rebuild again).
I will give that a try. I migrated for my c7 to a c8. My existing aqara/xiaomi devices moved over. It’s just new devices aren’t pairing. I’m trying to pair a button and motion sensor.
Thanks Dan but that was a no go. I have had it for about a month. Both sensors are xiaomi devices. I have some of the devices already paired as they were connected to my c7.
A lot of people have the aqara and xiaomi stuff drop off. They don't quite properly follow the zigbee protocol 100%. People have used ikea repeaters to stabelize... YMMV.... I gave up on them and sonoff. I got Moes and they've been rock solid.
