Ikea repeaters not working any more
HI
They has stopped working. Tried to re pair them again but the hub doesnt recognise them (all 4). No driver associated with them.
Reboot the HE hub and try again.
What is the LED status after you push the Reset button and HE is in Zigbee pairing mode?
it connects to the hub but no driver associated. When pairing it flashes. When connected solid.
There is no need for a driver for a Zigbee repeater.
But there should be a device created, and driver name will be ‘device’
Does the LED blinking stops after 4-5 seconds, or continues flashing for long time (1-2 minutes) ?
As above re: @kkossev
From the Hubitat Documentaion:
IKEA TRÅDFRI Signal Repeater
Join instructions
  1. Select the Start Zigbee Pairing button.
  2. Using a straightened paperclip, insert it into the small hole at the end of the repeater next to the USB port.
  3. Press and hold the paperclip in the hole for 2-4 seconds (you will feel the paperclip depressing a tiny button inside the repeater).
  4. The LED will pulse slowly when pairing and will be steady when pairing has been successfully completed.
  5. The signal repeater will pair as Device. No driver will be assigned and it is not necessary to have one since this device only repeats Zigbee radio signals.
Edit: Although I do have some IKEA repeaters using a built in driver called:
:man_shrugging:
Unfortunately, there is not an easy way to get a notification if the IKEA repeater goes offline to HE for any reason.
Even if the custom commands 'Get Link Quality' or "Get Route Table" are called from an RM5 rule and the repeater responds properly, the "Last Activity At" is never updated :
dev:22612023-01-18 11:56:28.188inforoute info- Destination:This Hub, Next Hop:This Hub, Status:Inactive
dev:22612023-01-18 11:56:28.184traceroute info- Destination:Button Sonoff SNZB-01, Next Hop:TS0207 Tuya Zigbee Repeater, Status:Active
dev:22612023-01-18 11:56:28.181inforoute info- Destination:This Hub, Next Hop:This Hub, Status:Inactive
dev:22612023-01-18 11:56:28.177inforoute info- Destination:This Hub, Next Hop:This Hub, Status:Inactive
dev:22612023-01-18 11:56:28.174traceroute info- Destination:TS004F remote, Next Hop:TS0121 MyRoom, Status:Active
dev:22612023-01-18 11:56:28.171inforoute info- Destination:This Hub, Next Hop:This Hub, Status:Inactive
dev:22612023-01-18 11:56:28.167traceroute info- Destination:Button Smart Knob TS004F, Next Hop:TS0121 MyRoom, Status:Active
dev:22612023-01-18 11:56:28.163traceroute info- Destination:Unknown:1573, Next Hop:Power Plug Ikea TRADFRI , Status:Discovery Underway
dev:22612023-01-18 11:56:28.159traceroute info- Destination:This Hub, Next Hop:This Hub, Status:Active
dev:22612023-01-18 11:56:26.689traceDevice:Power Plug Ikea TRADFRI , Type:Router, RxOnWhenIdle:True, Relationship:Sibling, Permit Joining:Unknown, LQI:137
dev:22612023-01-18 11:56:26.683traceDevice:TS011F (Krisi Room), Type:Router, RxOnWhenIdle:True, Relationship:Sibling, Permit Joining:Unknown, LQI:54
dev:22612023-01-18 11:56:26.677traceDevice:This Hub, Type:Coordinator, Relationship:Sibling, LQI:95
this is what I have just said. no driver gets associated with them and if I select them manually they still don't work. I'm on the latest firmware.
If you do the get link quality, do you see anything in the logs for them?
Also do one of these and see if you see them in the details:
http://your.hub.ip.here/hub/zigbee/getChildAndRouteInfo
Interesting - Are these URL/TOOLS documented somewhere ?
Question - I am assuming that all my ZigBee devices should be in there somehow...right ?
In the mean time I found this : Zigbee Child and Route Info Table Help / Explanation
PS
I see only one - link - what do u mean by one of these ? I was expected more than one :wink:
Zigbee Logs
Nope. With ZigBee there's no easy answers. :wink:
But these are definitely some good starter ones:
If you want to get the full picture you'll need an Xbee:
No, just that one. That's my poor choice of words. :slight_smile:
From my understanding, that only shows devices that connect directly to your hub, and devices that connect to that first layer of repeaters.
You can try the driver published here : [Project] Device Health Status [Tuya, Aqara, Ikea, Sonoff, Lidl and others] - #20 by kkossev
Thank you Mr Kossev
Just i was thinking you could take further Marcuss generic zigbee motion sensor as well. It has present too.
Thank you for your work
Kind Regards
Zsolt Toth
Can you give some more details about what did you do exactly? Step by step?
imported your driver.
Aded the repeater.
It comes up as "device" doesnt not automaticly employs your driver.
ofcourse your driver works with it if i select it manually.
If its working ? that takes time to find out
The most possible reason is that you have a new version of the IKEA repeater and it's fingerprint is not yet in the driver. My Ikea repeater was purchased probably a year ago, Markus's fingerprints are even older.
Please delete the device ( 'REMOVE DEVICE' at the bottom right of the web page). Then, pair it again to HE. When paired as a new device, this is the only time when the most detailed information about the device will be shown - there will be a link 'More Info'. Click on it and try to copy and paste as text all the information that will appear in the popup window.
Then I will add the new model fingerprint into modified Markus's Zigbee - Generic Repeater (w/ healthStatus) driver, and next time you pair it to HE it should be selected automatically.
Manufacturer: IKEA of Sweden
Endpoint 01 application: 21
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0000,0003,0009,0B05,1000
Endpoint 01 initialized: true
Endpoint 01 manufacturer: IKEA of Sweden
Endpoint 01 model: TRADFRI Signal Repeater
Endpoint 01 outClusters: 0019,0020,1000
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
Endpoint F2 application: unknown
Endpoint F2 endpointId: F2
Endpoint F2 idAsInt: 242
Endpoint F2 inClusters: 0021
Endpoint F2 initialized: true
Endpoint F2 manufacturer: unknown
Endpoint F2 model: unknown
Endpoint F2 outClusters: 0021
Endpoint F2 profileId: A1E0
Endpoint F2 stage: 4
this one got recognised straight away
That repeater fingerprint was already defined in the driver.
Can you do the same for the repeater that didn't pick up Markus's driver automatically?
