Hi,
I removed the device from my Hubitat, deleted the according custom driver, re-imported Thomas' driver from github.com again. Then re-installed the contact sensor using the freshly downloaded driver and afterwards I paired the sensor again. The sensor's 'Device'-site shows:
Commands
Initialize
Reset To Closed
Reset To Open
Current States
( empty )
State Variables
( empty too )
The Logs say:
2023-02-02 13:38:28.232infomsgMap: [raw:catchall: 0000 0013 00 00 0040 00 3965 00 00 0000 00 00 4C653968F790629638C1A480, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3965, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[4C, 65, 39, 68, F7, 90, 62, 96, 38, C1, A4, 80]]
dev:592023-02-02 13:38:02.325warnGeneral catch all - description:catchall: 0000 0013 00 00 0040 00 391C 00 00 0000 00 00 461C3968F790629638C1A480 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 391C 00 00 0000 00 00 461C3968F790629638C1A480, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:391C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[46, 1C, 39, 68, F7, 90, 62, 96, 38, C1, A4, 80]]
dev:592023-02-02 13:37:36.641warnGeneral catch all - description:catchall: 0000 0013 00 00 0040 00 6E5E 00 00 0000 00 00 405E6E68F790629638C1A480 | msgMap:[raw:catchall: 0000 0013 00 00 0040 00 6E5E 00 00 0000 00 00 405E6E68F790629638C1A480, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:6E5E, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[40, 5E, 6E, 68, F7, 90, 62, 96, 38, C1, A4, 80]]
dev:592023-02-02 13:33:48.723infofingerprint profileId:"0104", endpointId:"01", inClusters:"0001,0003,0500,0000", outClusters:"0003,0004,0005,0006,0008,1000,0019,000A", model:"TS0203", manufacturer:"_TZ3000_oxslv1c9"
dev:592023-02-02 13:33:48.527traceZCL version:03
dev:592023-02-02 13:33:48.524traceSoftware Build Id:unknown
dev:592023-02-02 13:33:48.522traceModel:TS0203
dev:592023-02-02 13:33:48.520traceManufacturer:_TZ3000_oxslv1c9
dev:592023-02-02 13:33:48.170debuggetting info for unknown Zigbee device...
dev:592023-02-02 13:33:46.139debugconfigure() called...
