I need help adding my Kasa KS205
This is one of the Kasa devices that uses the Tapo API and can connect to Hubitat through the Tapo Integration. Once installed in Hubitat, all control is local.
See: Kasa and Tapo Switches, Plugs, and Bulbs - Hubitat Support - :bellhop_bell: Get Help / Devices - Hubitat
Also see : [RELEASE] TP-LINK TAPO Plug, Switch, Bulb, Hub and Robovac Integration - :construction: Developers / Code Share - Hubitat
Hint: If you had done a search for "KS205" from the search icon, you would have found both of these articles.
