Should not any holdable button also have the released capability since in order to distinguish between pushed and held the device needs to send a released event?
Yup. You need to add the releasable button capability and handle it.
https://docs.hubitat.com/index.php?title=Driver_Capability_List#ReleasableButton
It really depends on the device. If it's not a real button and you're making things up, you can do whatever, but for real/physical buttons, the landscape varies. Some send events on push (or release but really counted as a push) only. Some send separate events for push and hold, and that's it. Some, but not all, send an event for release after a hold. In rare cases, the device sends just a push and release, and Hubitat calculates the rest based on your driver, but the only device I'm aware of that natively works like that with Hubitat are Lutron's Picos (quite possibly because the mesh protocols wouldn't work well for this).
On the Hubitat side, all buttons must implement Pushable. You can optionally implement Holdable and, if Holdable, Releaseable. (There's also DoubleTapable [sic.] that is not related to any of the latter two.)
Thank you @bertabcd1234 for your answer.
So, in that case, I have to write my own driver for my Samsung Buttons? HE's driver seems to allow them to work as pushable and holdable but not releasable. Am I correct?
Thanks again.
Push and held are not the same as buttons that support this would send different events for both of these. Therefore not every button will send the release event so that is why it is a separate capability.
As an example I have a button device that will send events on push, doubletapped and held but nothing when held is released.
I'm pretty sure the SmartThings Button only sends a message under one of these three circumstances:
- shortly after a short press of the button ("pushed" on Hubitat)--this slight delay is necessary to make sure you aren't doing the next (hold) action instead
- immediately after a long press of the button ("held" on Hubitat)
- immediately after two quick, successive presses of the button ("double tapped" on Hubitat)
I do not believe the Hubitat driver is doing anything special here--the button decides when to send what event, and there appears to be no way you could make "released" make sense here (it does not send something when the button is first pressed down and then something on release of that same press; i.e., Hubitat's driver is not doing any time-based calculations here...the only driver I'm aware of that does is the Lutron Pico drivers, an oddity they presumably made an exception for due to the better reliability of timing here compared to a mesh protocol).
Thank you,
However, I'm surprised that despite being able to detect a long press, it cannot detect a release. In order to detect a long press it must have, inside the device/chip code itself, a corresponding event to the "pressing" being stopped, hence it should be able to parse a released event... I don't see how it can know that the button is being held without distinguishing pressed and not-pressed (or released)...
There are many button devices which don't report both, many even report held before actually releasing the button. The combinations on how press/hold/release is (not) reported exist in all possible combinations of the three. As for the why you'd have to ask the manufacturers.
I'm fully aware I'm being stubborn here but I can't shake it: how does the core programming of the device itself detects that the press has lasted longer than a simple push, then?
if must look like something like this:
if(digitalRead() == 1) // button pressed
startingTime = millis() // time stamp
while(millis() - startingTime < 2000 millis && digitalRead() == 1)
wait for as long as the digital port reads 1, meaning button is being pressed
if(millis() - startingTime < 300) // if elapsed time is less than 1 second
parse a "pushed" event
else if(millis() - startingTime >= 300) // if more than 1 second
then parse a "held" event
In other words the device core system must have a digitalRead() = 0 and a digitalRead() = 1 values and, therefore, should be able to parse a released option. The only issue seems that it has been decided to simply ignore this possibility within the core programming of the chipset itself and that's what bugs me: why? and, most of all, why most buttons do the same. I must be missing something, for sure, but I can't help think that a button is a the simplest device one can build... as a matter of fact I do have buttons built on my own and paired with my hub which I use on a daily basis. I only purchased those buttons because they have a nicer look...
Just because the device "tracks" something internally--and it undoubtedly does so it knows the difference between a push or hold--doesn't mean that it gets sent as a message over Zigbee.
1 second is an eternity for held, held is more natural when it's in the range of 250 to 500ms, it begins to be feel awkward after 750ms
Exactly!
And then we devices like a Lutron Pico Remote that only sends "Pushed" and "Released". In order for Hubitat to use "Held" for these devices, the Hubitat Driver has to implement the logic to infer whether the button was simply pushed, or held. This is why Pico remotes, on Hubitat, have a user selectable setting for how long the button must be 'held' for.
Indeed, you stand me corrected!
Hi @ogiewon,
If it can do that then it should be able to infer the released state too, shouldn't it? There's no way it can infer that the button has been held for a period of time without being able to detect the release of the button.
The Pico remote sends to Hubitat a Pushed event and a Released event. There is no need to infer Released from a Pico remote. Hubitat has to infer "Held" from the only two events that a Pico remote is capable of sending.
Just trying to explain how some Button Controller devices behave differently, and the Hub has to make do with whatever it receives.
sure, something could generate a synthetic release, however it won't have any absolute correlation with the physical release and would just be annoying...
So you can generate a synthetic hold if the device produces pushed and released, other than that you're screwed...
Oh, I see. And how does it work with the Samsung button?
I'm asking this (and being insistent, sorry), because I wish to use them as sensors for beds and sofas (for which pico devices design are really not good, unlike samsung buttons).
No. The Samsung Button is capable of sending three events to the Hubitat hub - pushed, held, double tapped. That's it. Releasing the physical button on the Samsung button does not send any data to the Hubitat hub. This is a function of the Samsung firmware on the device.
This was explained much better by @bertabcd1234 above
the samsung button doesnt do release...
i wouldn't use any button controller here since i doubt any of them were designed to have the button activated forever as would be the case in this application...
I would look into contact sensors, they just have the binary states and are designed to remain in one state or the other indefinitely...
Just use a Contact Sensor with external wiring connections. Problem solved.
@mike.maxwell beat me to it!
