No. The Samsung Button is capable of sending three events to the Hubitat hub - pushed, held, double tapped. That's it. Releasing the physical button on the Samsung button does not send any data to the Hubitat hub. This is a function of the Samsung firmware on the device.
This was explained much better by @bertabcd1234 above
i wouldn't use any button controller here since i doubt any of them were designed to have the button activated forever as would be the case in this application...
I would look into contact sensors, they just have the binary states and are designed to remain in one state or the other indefinitely...
I understood this in the first place. My question was mere curiosity since it was all about how it was possible that the firmware could be designed like this while it had to have a 0 and 1 states of its digital port being read when pressed and released (hence the mock C code in my post above).
Okay. I understand now. Yes, the firmware of the device is simply watching a digital input and then applying some timing logic. If the input goes high and low in less than the 'heldThresholdTime', then send 'pushed', else send 'Held'.
My Arduino Code with HubDuino does exactly this in order to support both 'pushed' and 'held' button events. If you're curious, the code is available in my ST_Anything github repository as the IS_Button.cpp file.
That's what I did but it's bulky. I was hopping for a more elegant and easy to implement solution. For years I had a contact sensor doing this using my app "Thermostat manager" but I find it awfully ugly and far too binary which results in false positives due to the weight of the mattress. Also tried
Another solution, which has been working for a couple days has been to use a resistive film pressure sensor on a 30"*30" aluminum plate (from an old 3D printer) with a couple layers of foam tape strong enough to push the plate back against the bed but soft enough to receive pressure from body weight. It works but... 30x30... It's big...
Hi everybody,
Am I missing something or is there something missing in this implementation? I can't call for hasCapability() or hasCommand() for any of my buttons... Smartthings buttons. Is this normal?
buttonPause.hasCapability("PushableButton") or any other capability throws this error message:
ava.lang.IllegalArgumentException: Command 'hasCapability' is not supported by device
How do I re-trigger a RM4.1 rule based on a button push event from my driver?
With capability "PushableButton", my device driver is sending an event:
sendEvent(name:"pushed", value:1)
This is triggering a Rule Machine 4.1 rule fine for the first time, but subsequent "pushed" event of the same button number doesn't trigger the rule. If I send another button as a pushed event (say, button 2), then send pushed event button 1 again, the rule will re-trigger. I don't know what I'm doing wrong. I also tried adding ReleasableButton capability and sending a "released" event immediately following the "pushed", but the next "pushed" event still doesn't re-trigger the rule.
I don't know if I'm missing something. As a test of Rule Machine, I used a Minimote with the built-in drivers and I can press the same button repeatedly to retrigger the rule over and over. I have a another test rule that triggers on "pushed" and "released" events and it doesn't seem like the Minimote is sending release events. So, it feels like calling my driver repeatedly calling sendEvent() with the same button # doesn't actually cause an event to be sent??
I'm having trouble adapting this button driver
I already replaced "button" to capability "PushableButton"
But i don't know how to continue modifying the driver
I would like to ask help with this modification. Please
Watched a YouTube review the other day, for an Inovelli brand in-wall paddle switch that allowed you to program some crazy number of taps, I believe up to six?!
Enough to choke any button implementation on the spot.
