Hubitat Hub Generating Network Multicast 'Storm' Using mDNS
I've been having issues with one of my network devices resetting randomly. I believe I've tracked it down to Hubitat generating excessive multicast queries. Using wireshark I can see where normally the Hubitat hub sends 5-10 requests a second. Then randomly it will have a 'storm' and do in excess of a 1000 a second.
What can I do to start hunting down what's causing this?
Here's an example of some back to back requests:
109619 1450.522497 192.168.1.195 224.0.0.251 MDNS 76 Standard query 0x0000 PTR _http._tcp.local, "QM" question
109620 1450.522752 192.168.1.195 224.0.0.251 MDNS 76 Standard query 0x0000 PTR _http._tcp.local, "QM" question
109621 1450.522980 192.168.1.195 224.0.0.251 MDNS 76 Standard query 0x0000 PTR _http._tcp.local, "QM" question
What hub? What Platform Version, please?
Are you using the Homekit integration? I think that would be .hap though.
Since its showing as tcp.local I assume that is just something with the hubitat.local mDNS resolving. Seems awfully chatty for something that simple.
The Discovery App (mDNS) on my Mac shows:
_http._tcp. (World Wide Web HTTP) - 10 items
Those 10 items are: 6 Hubitat Hubs, 3 Amcrest Cameras, and SecuritySpy.
In other words, not hub specific.
Platform 2.3.8.123
Hardware C-7
I ran WireShark and captured several hours of traffic. The MDNS storms occur exactly every hour from each other. I'm not sure if that's also correlated to being on the hour or half hour and haven't seen a way to get a world time out of the logs.
I was using the Homekit integration and disabled it to see if it changed anything. No change in the sudden spamming of MDNS queries.
Maybe you can send your caps to @gopher.ny to see if he spots anything.
I didn't capture hours but I did run TCPDUMP for more than half an hour... On average there were 10 packets-per-second (pps) of mDNS data. Within that, there were bursts of ~200 packets in 2 seconds from a single Hubitat hub. I saw that burst twice, from different Hubs. I was not able to confirm any 1000 pps 'floods' during the sampling window.
I upgraded to the latest version: 2.3.8.139
Here's the traffic before with the storms:
I mis-read one of your statements and thought that I could capture 1 flood in any 35 min slice of time. I'll try again on the other half and see if I get one too.
I ran tcpdump to cover the half hour window, the 100pps burst I did see (and count) occurred at 22:13:37
I'll try again for the top of some hour.
Just curious - Do you have Matter enabled? - As that protocol is very dependent on mDNS
I just got home and was able to check - matter is disabled.
I collected data all day after updating to the newest firmware on Hubitat. Its no longer sending out a burst in the 1000's, but it is still doing a large jump every hour. It looks like the amount is growing each time, so maybe over the course of a week the amount would be even greater? Some type of error in the mDNS implementation maybe?
The startup time in the hubitat log shows it coming up at 6:02AM and the spikes are an hour apart at 2 minutes past the hour. This suggests the hub is doing this independently.
What is the network device that is resetting? I have recently had some issues with some WLED ESP32 boards randomly crashing consistently. I shut down the C7 and problem 100% went away. Now I need a workaround.
I have an ESP32 running the latest WLED, as well as an ESP8266 and this mDNS issue causes the ESP32 to reboot itself. My current theory is that the amount of messages the Hubitat hub transmits each hour grows and given enough time, it hits a level where the ESP32 can no longer handle it.
Unfortunately, I upgraded my hub before trying just a reboot. I can't tell if the behaviour change was due to the new firmware or the reboot, maybe both? I plan on sampling data tomorrow to see if the traffic is growing over time as predicted.
I finally got a moment to do that top-of-the-hour tcpdump and the average remains ~10pps
However, there is a burst and it's big enough to go up a category to Flood. 2375 packets: 1 second. One hub, almost 2400 packets in just under 1 second. Downright chatty :slight_smile:
Is this something that Victor should be made aware of?
@gopher.ny
I ran another capture last night and the amount of packets continues to grow. Below is data from last night to this AM. Note they are all around 300'ish. A day ago, just after resetting (see earlier post), the hourly surge was around 50. There is definitely growth of the issue.
Do you have any special setup to do this or are you just running Wireshark with promiscuous mode? If I recall correctly I think you may need to have a switch you can configure to send all packets to the sniffing device? I don't think I can do that on my basic home router. I would have to put a dumb switch inline with my hub and another PC so that it could capture the traffic.
mDNS are broadcast packets, you can just monitor port 5353
or:
time tcpdump port 5353
