Hubitat for AUS/NZ Chat
What feels like a long time ago now I (Dec '19) mentioned on this thread I was working on an integration with Mitsubishi Electric's MELCloud service for Aus/NZ AC's. For now I'm happy to send the drivers I have via a message to anyone interested, mostly for speed, unitil I setup a GitHub profile and get around to writing some notes for how to install and use it.
@pjam73 - I'll send you the code shortly.
Thanks,
Simon
hey guys, I've got a rule for my garage light that runs on motion sensors, I keep ending up with a blinking light when I'm in and out of the garage a bit.
What I've done is tried to stop it turning the lights off if it re-triggers , but also not leave the light on indefinitely, Can you please logic check this for me ?
Have you tried Simple Lighting ?
Apologies for not answering the question you posted
@stevebott123 nope I hadn't might go play with that now. Think I might have out clevered myself...……..
Motion Lighting app as well, has good in-built options.
Looks like I'll be playing in the garage all afternoon...……
Thankyou both, didn't even think to look for those two apps
Motion lighting seems to be the go as it looks like I can use a virtual switch to set an override
sorry - you did say motion.
Both apps are pretty handy
all good @stevebott123 anything that makes me think is a win !!
Does anyone know if this Wiz WiFi Filament Bulb from Bunnings will work with Hubitat?
Other Wiz bulbs work with Tasmota, but this one specifically, I wouldn’t know:
EDIT: They’re not easy to flash it looks like though
Thanks for posting that link. I guess I can live with using IFTTT to integrate Hubitat and the Wiz bulb.
“Will work” or works well ??
Very very different questions, especially if IFTTT is involved.
Not sure if this interests anyone or not but I posted the question about a performance HE over here.
37m
Hi
First time on this forum. Hence sorry for any errors in advance.
Many thank to veeceeoh and rest of the contributors for developing the Hubitat driver for WSDCCQ11LM Xiaomi temperature humidity sensor. I've tested last night with a a similar new sensor fitted with an LCD screen which I believe is non-branded version of the Blitzoolf BW-IS4 LCD Screen Smart Home Temperature Humidity sensor. Almost looking like the Xiaomi bluetooth units but being Zigbee. All went well with the above mentioned driver and the only parameter that I cannot get is the battery but nevertheless the unit is displaying this on the screen. I'll try now to attach some photos as well.
2020-02-13%20IMG_8625
SolutionReply
bogdan.mailOwner
35m
SolutionReply
bogdan.mailOwner
4m
More photos2020-02-13%20IMG_8623-1 2020-02-13%20IMG_8622 Also offset function in the driver seems to work well so the calibration should be easy. Many thanks again
Have you learned anything more here? Our new house is almost finished, it will have 3 zone ducted heating and cooling using Brivis networker. I want to be able to integrate it with Hubitat and Alexa/Google. Looks like one of those brands you mentioned might be what I need but not quite sure.
Nothing other than whats been posted. @jchurch said he has izone and is working well. I also noted that izone has an alexa skill.
Im yet to have my aircon guy out to discuss
Thanks again @njanda for this suggestion. I have just now gotten around to buying it (Option H - Zigbee AU if you’re looking at ordering one). So far it’s just sitting on my kitchen table but it was detected by HE without any issues. I’m using it with the generic Zigbee switch driver and that works perfectly. It’s a pretty strong wee fella.
I’m just waiting for the plumber to come around now to install a mains water valve with a lever. The one he installed to begin with was the knob version. Once he’s been, I’ll be able to test it for real. :slight_smile:
Oh brilliant.
That’s exactly what I’ll have to do - have a plumber install a lever ball valve.
Hard to find a Sydney plumber for such a small job - and do it at a reasonable price.
My plumber hasn’t finished plumbing up the house yet (new house build) so I’ve just tacked it on to that :slight_smile:
Smartthings Smart Plug
Finally a small Australian zigbee plug..(with power monitoring and a repeater)
Not sure if it's already been mentioned or not.
Don't know if we need drivers either.
Got some on order..
