Hub Update 2.0.3
#1
Hubitat Elevation Platform update 2.0.3 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.0.2:
Platform Additions / Changes
  • Added ability to disable any App from App list view and Devices from Devices list view
  • LAN data received with no matching driver now logs to live logging
  • sendHubCommand supports HubMultiAction
  • Add websocket helper methods for drivers.
  • Device List now truncates the DNI and shows full on hover if longer than 20 chars
Drivers and Devices
  • New drivers:
    • Fibaro RGBW (beta)
    • Qubino Shutter Module
    • Qubino Relay Module
    • Neo Coolcam Light Switch
    • Neeo Remote
  • New devices:
    • Marantz AVR using Denon AVR driver
  • New driver features:
    • Virtual Thermostat: Improved default operational enhancements.
    • Pioneer AVR: Added Telnet port selection option.
New Built-in App Features
  • Rule Machine
    • Allows multiple Thermostat Schedulers to be selected.
    • Allows seconds and minutes of delay for all rule-to-rule actions.
    • Allows number of repeats to be selected.
  • Thermostat Scheduler
    • Allows additional named time periods and removal of time periods.
    • Updates setpoints when current period or mode settings changed.
  • Motion Lighting
    • Enhancements to mode change adjustments.
  • Mode Lighting
    • Added switches off per mode.
New Integrations
  • Chromecast Integration (beta)
Bug Fixes
  • Virtual Thermostat: Fixed various bugs.
  • Hue Bridge Lan announcements disabled unless Amazon Echo App is installed.
  • Thermostat Scheduler:
    • Fixed bug with hold on/off from Rule Machine.
    • Fixed bug with setting Away temps for days/time schedule.
  • Amazon Echo Skill: Reduce device is not responding replies.
  • Hubitat Safety Monitor:
    • Fixed bug for Keypad selection for intrusion-away.
    • Fixed arm-night button number bug. If you are using an arm-night button, you will have to reselect the button number due to this fix.
  • Maker API: Fixed secondary value should now convert to Number properly if command is set to a number.
  • New User Getting Started fixed issue with missing button on small desktop screens.
  • Device now returns same last activity time as UI.
  • Nanoleaf Aurora: Updated eventing and corrected hue mapping (now 0..100).
  • Fibaro RGBW: Fix level now respected in setColor map.
  • Life360: Fixed issue with clearing out credentials on error from Life360 server.
[TUTORIAL] How to disable Apps and Devices (platform v2.0.3 or newer)
Feature request: Device health
Sending a fixed number of repeated actions
#2
Hot Fix Released
We have released 2.0.3.117.
There were two bugs in Thermostat Scheduler fixed, both concerning restoring setpoints after a temporary change. One was after Hold is returned to Scheduled, and the other was after Away mode changed to a different mode.
We also made a change to Chromecast discovery, that possibly will fix a discovery problem that some users reported. We could not replicate the problem, but hope this change may fix it.
